Go to Post If only 5% of American entry level workers are proficient in algebra in 2022, I'm moving to Canada. - PVCpirate [more]
Go Back   Chief Delphi > Other > Math and Science
Old 12-23-2016, 09:52 PM
Hitchhiker 42's Avatar
Hitchhiker 42 Hitchhiker 42 is offline
Roboter
AKA: Mark Lavrentyev
FRC #4557 (FullMetal Falcons)
Rookie Year: 2015
Hitchhiker 42 is a splendid one to beholdHitchhiker 42 is a splendid one to beholdHitchhiker 42 is a splendid one to beholdHitchhiker 42 is a splendid one to beholdHitchhiker 42 is a splendid one to beholdHitchhiker 42 is a splendid one to beholdHitchhiker 42 is a splendid one to beholdHitchhiker 42 is a splendid one to behold
Re: numerical solution of differential equations
@Mark: Where did you get the accel formula for columns D and G.
Not sure. Must have been really tired . I did that over, and also added an error column to show the difference between Xa and the predicted X (Xm or Xe).
I set dt = 0.01 s and compared the errors at t = 1, 2, 4 s
For 1s:
Midpt error: 0.598
Euler error: 0.585
For 2s:
Midpt error: 2.834
Euler error: 2.748
For 4s:
Midpt error: 50.070
Euler error: 48.113
Seems that, at least for this function, the Euler method holds up better. Tomorrow, I'll try it with a function where the second derivative isn't always positive on the interval I'm testing.
2016 - NE District Championship Entrepreneurship Award
2016 - Hartford District Industrial Design Award
2016 - Waterbury District Engineering Inspiration Award
Old 12-23-2016, 09:53 PM
Roboter
Rookie Year: 2015
And the new sheets:
Old 12-23-2016, 09:57 PM
Originally Posted by Hitchhiker 42 View Post
And the new sheets:
where did you get the revised accel formula?
Old 12-24-2016, 03:22 PM
Roboter
Rookie Year: 2015
I took the derivative of the actual velocity function. Is this not correct?
Unread 12-24-2016, 03:40 PM
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
No, as I read it you're setting x''=3x/2. This would be solved by a function of the form x=Ae3x/2
Unread 12-24-2016, 04:43 PM
Roboter
Rookie Year: 2015
Could you explain what this means? I'm not sure I understand...
Unread 12-24-2016, 05:21 PM
I've attached your spreadsheets modified for 1/4*x^3 + 1.
I am assuming what you actually meant by that is
x(t) = 1/4*t^3 + 1
Is that correct?
If so, then in order to investigate the performance of Euler vs Midpoint numerical solution (in the context of this thread) you need to convert that to an initial value problem (IVP) consisting of a differential equation (involving only x, x', and x'') plus initial values for x(t) and x'(t) at some point t=to.
Unread 12-24-2016, 05:39 PM
Roboter
Rookie Year: 2015
x(t) = 1/4*t^3 + 1
Is that correct?
Yes, sorry about that. That was what I meant.
Unread 12-24-2016, 09:04 PM
OK.
x(t) = 1/4*t^3 + 1 is the analytical solution to the Initial Value Problem
a(t) = sqrt(3*v(t))
with initial values*
x(0.01) = 1.00000025
and
v(0.01) = 7.5e-5
As you can see from the spreadsheet, the Midpoint method gives much better results for that IVP than Forward Euler and Forward/Backward Euler.
* selected to avoid the stationary point at t=0
Unread 12-25-2016, 04:18 AM
GeeTwo's Avatar
Technical Director
AKA: Gus Michel II
Sorry, that should have been x''=Ae√3t/√2
if x=Ae√3t/√2,
then x'=√3Ae√3t/√2/√2 (chain rule)
and x''=3Ae√3t/√2/2 (chain rule again) = 3x/2.
Edit: I knew there was more to it, and just figured out the other part:
x''=3x/2 ==> x= Ae√3t/√2 + Be-√3t/√2
Unread 12-25-2016, 07:50 AM
x(t) = 1/4*t^3 + 1
Is that correct?
Yes, but you got x and t confused.
given:
x(t) = 1/4*t^3 + 1
... take time derivative of x(t) to get:
x'(t) = (3/4)*t^2
...take time derivative of x'(t) to get:
x''(t) = (3/2)*t
Now solve for the differential equation:
solve x'(t) for t:
x'(t) = (3/4)*t^2 => t=sqrt(4x'(t)/3)
... and then substitute for t in x''(t):
x''(t) = (3/2)*t = (3/2)*sqrt(4x'(t)/3) = sqrt(3*x'(t))
Unread 12-25-2016, 04:46 PM
Roboter
Rookie Year: 2015
given:
x(t) = 1/4*t^3 + 1
x'(t) = (3/4)*t^2
x''(t) = (3/2)*t
solve x'(t) for t:
I see... so that column is in terms of x', not t. I've updated the spreadsheet to reflect that and it seems to show that the Euler method does better.
dt = 0.01s, error measured at t=3s.
Euler error: 0.2061
Midpoint error: 5.0828
This, I presume, is for the reason I mentioned in my first post.
Unread 12-26-2016, 12:03 AM
You're still struggling with this, but I can't point out your error since you didn't post your spreadsheet.
I think you may have overlooked my earlier post #24. The attachment shows how to set up the formulas.
The Midpoint method is clearly better than either Forward/Forward Euler or Forward/Backward Euler for this IVP.
Unread 12-28-2016, 10:05 PM
Roboter
Rookie Year: 2015
I redid the midpoint spreadsheet - now at t=9.96s with dt=0.01s, the error is only 0.96. I replaced the Am column with the Am = sqrt(3*x').
Now to search for a possible explanation...
I did find this http://www.physics.drexel.edu/~steve...rs/simple.html
My guess would be that for this function, which, on the interval being examined, is concave up always (x'' > 0), the Euler method uses a point from farther back than the midpoint method to determine the slope (beginning of the interval slope vs. mid-interval slope). As it's concave up, the Euler method lags behind the midpoint method in growth, and so grows slower than the actual function by more than the midpoint method.
Now to test a method where it uses the end of the interval's slope...
Unread 12-28-2016, 10:18 PM
Roboter
Rookie Year: 2015
Drat... I tried it using the slope at the end of the interval instead of at the beginning, and it turned out to have a tad bit more error compared to the actual function.
