Go to Post You mean how many Edible Data Analysis Metrics and Aggregated Measurable Entities (EDAMAME)? - Andrew Schreiber [more]
Unread 24-12-2016, 20:45
Richard Wallace's Avatar
I live for the details.
FRC #3620 (Average Joes)
Re: New AndyMark Product Game Hint???
Originally Posted by pilleya View Post
Looks like it is the FTC bolt pattern so probably 6mm round or D bore with 6-32 bolts on a 16mm bolt circle. Most likely compatible with the new AM Nubs: http://www.andymark.com/AndyMark-Nub-p/am-nub.htm
I think you are right. That is likely an 8 mm (5/16") hex bore, so a nub would pilot in it.
Richard Wallace
since 2003
Unread 24-12-2016, 20:51
ollien ollien is offline
FRC #5202
ollien has a spectacular aura aboutollien has a spectacular aura aboutollien has a spectacular aura about
Doesn't look like there's a nice way to adapt this to hex though :/
Unread 24-12-2016, 21:08
What "this" are you referring to?
I was looking at the hex bore in the white plastic hub. It appears to be 8 mm or 5/16" across the flats. If so, it will pilot on a nub's 8 mm boss. It also seems to have the 16 mm circle pattern of four holes that would suit a #6 screw.
So you could drive the wheel using 6 mm shaft through a nub, or you could drive it directly using 8 mm (5/16") hex shaft.
Or were you thinking about 3/8" hex?
Richard Wallace
since 2003
pilleya's Avatar
pilleya pilleya is offline
Elec+Mech
AKA: Alastair Pilley
FRC #4613 (Barker Redbacks)
pilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond repute
Definitely not enough meat in the center to be able broach out to 1/2inch hex. The holes on the 16mm bolt circle would also clash with the points of the shaft.
Surely if you need to adapt it to use it, you might as well just make a hub from scratch.
Sponsors, parents, students and mentors love helping teams succeed. Denso Throttle motors also want to help, don't break their hearts. REDBOX(gearbox for the throttle motor)
Facebook
Unread 24-12-2016, 21:09
Lireal Lireal is offline
AKA: Alex Colello
FRC #2141 (Spartonics)
Lireal is on a distinguished road
It looks like there should be enough clearance to broach it.
Unread 24-12-2016, 21:21
pilleya's Avatar
Elec+Mech
It would end up looking like this if you tried to broach it to 1/2inch hex.
Facebook
Unread 24-12-2016, 21:40
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
That would work just fine.
2001-2004: Team 100
2006-Present: Team 254
