Go to Post You know what they say, the mind is the second thing to go and I can't remember the first. - GaryVoshol [more]
  #106   Spotlight this post!
Unread 24-12-2016, 20:03
Knufire Knufire is online now
Re: New AndyMark Product Game Hint???
Originally Posted by Cothron Theiss View Post
Ok, so does anyone have any recommendations for shooter wheels that aren't $30 each? Are Colsons the best cheap alternative?
Man, what's the point of teaser videos if nobody looks closely at them.
Team 469: 2010 - 2013
Team 5188: 2014 - 2016
NAR (VEX U): 2014 - Present
  #107   Spotlight this post!
Unread 24-12-2016, 20:06
Richard Wallace's Avatar
I live for the details.
FRC #3620 (Average Joes)
Considering the base price per axis in terms of speed control and motor, $30 per wheel really isn't that bad.
Yes, if you already know the wheel is going to do the job as expected.
$30/ea for trial and error can get expensive.
Richard Wallace
since 2003
  #108   Spotlight this post!
Unread 24-12-2016, 20:10
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
Depends on what you are shooting. I saw some pretty good shooters made from $5 AM stealth wheels this year.
  #109   Spotlight this post!
Unread 24-12-2016, 20:11
Cothron Theiss's Avatar
Cothron Theiss Cothron Theiss is offline
Are you referring to this wheel in the AndyMark teaser? That hex bore looks pretty small. Is that a wheel AndyMark just had laying around, or do you think that's an upcoming product?
  #110   Spotlight this post!
Unread 24-12-2016, 20:12
ollien ollien is offline
FRC #5202
ollien has a spectacular aura aboutollien has a spectacular aura aboutollien has a spectacular aura about
Hm... What's that plastic bit in the middle of the wheel? I hope it has some way to interface with a hex shaft nicely.
  #111   Spotlight this post!
Unread 24-12-2016, 20:18
It looks to me like a .375 or even .25" hex bore.
  #112   Spotlight this post!
Unread 24-12-2016, 20:34
pilleya's Avatar
pilleya pilleya is offline
Elec+Mech
AKA: Alastair Pilley
FRC #4613 (Barker Redbacks)
pilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond repute
Looks like it is the FTC bolt pattern so probably 6mm round or D bore with 6-32 bolts on a 16mm bolt circle. Most likely compatible with the new AM Nubs: http://www.andymark.com/AndyMark-Nub-p/am-nub.htm
Facebook
  #113   Spotlight this post!
Unread 24-12-2016, 20:45
I think you are right. That is likely an 8 mm (5/16") hex bore, so a nub would pilot in it.
Richard Wallace
since 2003
  #114   Spotlight this post!
Unread 24-12-2016, 20:51
FRC #5202
Doesn't look like there's a nice way to adapt this to hex though :/
  #115   Spotlight this post!
Unread 24-12-2016, 21:08
What "this" are you referring to?
I was looking at the hex bore in the white plastic hub. It appears to be 8 mm or 5/16" across the flats. If so, it will pilot on a nub's 8 mm boss. It also seems to have the 16 mm circle pattern of four holes that would suit a #6 screw.
So you could drive the wheel using 6 mm shaft through a nub, or you could drive it directly using 8 mm (5/16") hex shaft.
Or were you thinking about 3/8" hex?
Richard Wallace
since 2003
  #116   Spotlight this post!
pilleya's Avatar
Elec+Mech
Definitely not enough meat in the center to be able broach out to 1/2inch hex. The holes on the 16mm bolt circle would also clash with the points of the shaft.
Surely if you need to adapt it to use it, you might as well just make a hub from scratch.
Facebook
  #117   Spotlight this post!
Unread 24-12-2016, 21:09
Lireal Lireal is offline
AKA: Alex Colello
FRC #2141 (Spartonics)
Lireal has a spectacular aura aboutLireal has a spectacular aura aboutLireal has a spectacular aura about
It looks like there should be enough clearance to broach it.
  #118   Spotlight this post!
Unread 24-12-2016, 21:21
pilleya's Avatar
Elec+Mech
It would end up looking like this if you tried to broach it to 1/2inch hex.
Facebook
  #119   Spotlight this post!
Unread 24-12-2016, 21:40
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
That would work just fine.
2001-2004: Team 100
2006-Present: Team 254
  #120   Spotlight this post!
Unread 24-12-2016, 22:33
FRC #5202
Originally Posted by R.C. View Post
Downloaded the model last night and it was 1". Layout drawing and site say 1/2". Just wanted to verify with someone who has one. Thanks again.
Definitely half inch.
