Go to Post When we design these systems ask " would I want my Mom (or daughter) standing next to this thing when it goes off? - Mike Betts [more]
Unread 12-26-2016, 12:13 PM
tjwolter tjwolter is offline
FRC #5826
tjwolter is an unknown quantity at this point
Re: Drill motors for go cart project
drill motors for this application are touchy. You need to very firmly support the "outboard" end of the shaft or the planetary gearbox will strip. If I recall some prior misadventures you also have to lock the clutch by putting in some set screws. Or find older drills without clutches. These are harder to find and tend to be 7.2 volts. They are nice and frisky at 12v. But unless you are sold on drill motors may I suggest the humble Barby Jeep gearbox? Cheap. Durable. Can handle 24 volts for a while. So many around that a four wheel drive machine, which you will want, will be bargain basement.
You would be happier with the end result
T. Wolter
"Well, its never actually been successfully tested"
