Go to Post My contention is that there is not a whit of difference between noting that a change like that has to be made, and making the change. - Kris Verdeyen [more]
Old 12-27-2016, 06:15 AM
Foster Foster is offline
Engineering Program Management
VRC #8081 (STEMRobotics)
Foster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond repute
Re: Rivnut Tool
I'd like to hear the results of the pullout test on the 1/8" bar where you don't think the nut really set well. It looks like it expanded enough to keep it from pulling out.
Thanks for giving up your holiday for Science!
Foster - VEX Delaware - 17 teams -- Chief Roboteer STEMRobotics.org
2010 - Mentor of the Year - VEX Clean Sweep World Championship
2006-2016, a decade of doing VEX, time really flies while having fun
Downingtown Area Robotics Web site and VEXMen Team Site come see what we can do for you.
Old 12-27-2016, 10:10 AM
bowmanb bowmanb is offline
AKA: Bruce Bowman
FRC #3991 (KnightVision)
bowmanb is an unknown quantity at this point
Re: Rivnut Tool
I have extensive experience with rivnuts from one of my former lives as an instrumentation installer. They work great with proper installation and care, but I have always been reluctant to introduce them to our FRC team because of this one problem-
If you ever manage to break one loose in a blind hole it can be a real bear to get the screw out of the hole.
The odds of this happening increase as the odds of incorrect installation increases. When I finally broke down last season and introduced them (our chassis design last year made our bumpers hard to attach/detach without them) I trained a special crew to use them and I demonstrated the spin-out problem and how to avoid it. It requires a combination of correct installation of the proper size and avoiding over-torquing the fasteners (I find that often teenage boys don't know their own strength!).
Old 12-27-2016, 03:00 PM
PVCMike PVCMike is offline
AKA: Mike Jr.
FRC #1058 (PVC Pirates)
PVCMike has a spectacular aura aboutPVCMike has a spectacular aura aboutPVCMike has a spectacular aura about
Re: Rivnut Tool
We have used riv-nuts also called nut-certs (or nut-serts) on 1058 for years. Really helps with fast repairs in the pit!
Step one is get the right tool. We have one similar to this which works MUCH better than the ones that look like a pop-rivet gun: https://www.amazon.com/Astro-1442-Th.../dp/B003TODXQW
Step two is to make sure you have the correct size drill bit. These things are sensitive to hole size so we double check we are using the correct drill every time.
As others have mentioned installation and placement is critical. We almost always have mentor supervision/help when installing any riv-nuts. They are also prone to under and over torquing so we usually teach a few students how to do it properly and supervise closely, or have a mentor install if necessary (with student help of course.) It helps to do some testing on a scrap piece to make sure your tool adjustments are correct.
We have run into situations where they come loose due to install error or just unexpected load and have had success drilling them out, although it's not fun. I would not recommend using loctite on the hardware you're placing in them, and if you do, very sparingly.
I would be interested in a part number or link to a pneumatic tool for installing these. We use a pneumatic pop-rivet gun and it's awesome.
Coming up on year 15 with the PVC Pirates!: www.team1058.com
https://www.thebluealliance.com/team/1058
Old 12-27-2016, 03:03 PM
Chris is me's Avatar
AKA: Pinecone
Re: Rivnut Tool
I vastly prefer riv-nuts to PEM nuts. PEM nuts have an awful tendency to fall out if mishandled, and because of that I don't really trust them. Once a riv-nut is properly installed, it has a much harder time coming lose. This is just my experience - both solutions are valid. But I don't think PEM nuts are almost ever preferable for me.
Old 12-27-2016, 05:01 PM
Fusion_Clint's Avatar
Fusion_Clint Fusion_Clint is offline
AKA: Clint Brawley
FRC #0364 (Fusion)
Fusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond repute
Re: Rivnut Tool
Ok,
Having never used a rivnut before, I started looking on youtube and came across this. https://youtu.be/3Og-tHIR_0I?t=66
For those of you that have rivnut experience, what are the cons of using this method?
Clint Brawley
USAF 1992-2013
Fusion 364, 2014 Season to present
Old 12-27-2016, 07:45 PM
dradel's Avatar
dradel dradel is offline
FRC #4557 (Full Metal Falcons)
dradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to behold
Time. Takes a while to do that method. Also the chance of pulling the threads out of the nut is greater.
If only doing a few no big deal.
Old 12-27-2016, 10:28 PM
RoboChair's Avatar
AKA: Devin Castellucci
Re: Rivnut Tool
Originally Posted by Fusion_Clint View Post
Ok,
Installation is time consuming and rather annoying. Anything larger than a #10 rivnut takes some considerable muscle and/or the use of a cheater bar(s).
11 Years and counting! Over a third of my life has been spent with FRC.
Old 12-27-2016, 10:54 PM
ollien ollien is offline
FRC #5202
ollien has a spectacular aura aboutollien has a spectacular aura aboutollien has a spectacular aura about
Re: Rivnut Tool
Originally Posted by Jon Stratis View Post
We've always used a wrench-driven tool, McMaster PN 96349A380.
Does this work for the non-self aligning rivet nuts?
Old 12-28-2016, 11:30 PM
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Re: Rivnut Tool
Initial results of rivnut pullout testing: (Due to budget constraints, only doing 10-32 steel thin-wall large flange inserts this year; if we're happy with the results, we'll expand our options next year).
I drilled a 19/64" hole using a drill press and inserted an SKL 10-32-130 steel thin nut with large flange into each of three pieces of aluminium:
  • 3/4" x 1/8" bar (Ace Hardware, looks like 6061, pictured above)
  • 0.1" wall Vex 1"x1" tubing (I used a factory hole as a pilot)
  • ~1/16" wall channel (sold as 1/2" plywood edging, also pictured)
I then centered a 1/2" hex nut over the rivnut (large enough hole for the rivet to pass freely), added three steel 1/16" thick fender washers, and inserted a 1" stainless 10-32 cap screw (allen drive). I did not have a 3/8" to 1/4" adapter handy, so I could not use my torque wrench, so I used my shortest 1/4" ratchet driver. In each case, I tightened with my index finger and thumb against the adapter socket. In each case, I was using roughly the same amount of torque (to within perhaps 50%) at failure. I shall repeat these tests with an adapter so I can measure torque, and with the longer rivnuts in coming days.
Each setup reached normal (tee-handle) torque with no noticeable deformation or stress relief (that is, yielding or breakage) of any part. On applying additional torque to failure, each case had a somewhat different failure mode. Consult the attached image for clarification.
1/8" bar - the bar did not noticeably deform on a large scale, but the small crimped area of the rivnut reamed its way through the aluminum to a depth of about 0.1" (I was able to put the versaframe tubing wall between the stock and rivet flange with no difficulty) when the machine screw sheared at the head end of the threads. Because the failure was through reaming not bending, I expect that if the force had not been applied normally to the surface, far less force would have been required to pull the insert from the material. I definitely intend that we shall use the longer .225 rivets for aluminum of this thickness. In steel, it is entirely possible that the stock would have held the rivnut to a rather greater pull out force.
0.1" Vex tubing: The crimped area of the rivnut was adequate to hold in the aluminum. However, the wall of the tubing was deformed (volcano style) until the hole was large enough for the insert to be pulled completely clear of the tubing. It appears that a longer rivnut would provide minimal additional capacity, though I shall test this when the longer inserts arrive.
1/16" plywood edging: The aluminum yielded "volcano style" to a height of 1/16" on one side and 7/64" on the other, then the machine screw broke at the top of the treads on the insert, presumably from the bending torque.
Curiously, the VF thick wall tubing deformed much farther than the hardware store grade aluminum bar and plywood edging.
Edit/Addition:
Ok,
I will add testing this method (with 10-32 thin wall steel inserts) to my next round of tests. It seems to me that you can get better torque with hex head bolts 1/4"-20 and larger than with any normal #12 and smaller heads. I am also concerned that applying torque to the threaded part of the insert during the crimp might result in a weaker/twisted crimp.
Old 12-29-2016, 02:34 AM
cbale2000's Avatar
cbale2000 cbale2000 is offline
AKA: Chris Bale
FRC #0703 (Phoenix)
cbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond repute
Re: Rivnut Tool
Not to get too off-topic, but as someone who had never even heard of Rivnuts before seeing this thread, I'm curious... What are the actual benefits of using a Rivnut? Most of the application examples I've seen so far look like it would have been far simpler and faster to just use a regular bolt+locknut.
You don't appear to be saving space since the rivnuts still stick out, and for that matter the rivnuts also appear to create an additional space on the front side of the material that wouldn't have otherwise been there.
Am I missing something here?
Old 12-29-2016, 02:54 AM
Ari423's Avatar
Ari423 Ari423 is online now
LabVIEW aficionado and robot addict
AKA: The guy with the yellow hat
FRC #5987 (Galaxia)
Ari423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant future
Re: Rivnut Tool
The way I understand it, the point is that the nut stays there when you remove the bolt, so it's better if the nut would be in a hard to reach position. Essentially, it lets you tap a threaded hole into a piece of sheet metal that would otherwise be too thin to tap.
My team has used rivnuts a few times in the past. This year we used them to attach our main breaker because the frame member we wanted to attach it to was surrounded by other components so we couldn't get a wrench behind it to hold a nut. There was probably another way that would have worked just as well, but we have found that aluminum rivnuts work well and are fairly easy to install for low-load applications. We have also used steel rivnuts for higher load applications, but they tend to be harder to install (and remove when they inevitably break) and not be as strong as a regular nut.
2017-present: Mentor FRC 5987
2017-present: CSA for FIRST in Israel
2012-2016: Member FRC 423
2013: Programmer
2014: Head Programmer, Wiring
2015: Head Programmer, Wiring
2016: Captain, Head Programmer, Wiring, Manipulator, Chassis, CAD, Business, Outreach (basically everything)
Old 12-29-2016, 03:18 AM
RoboChair's Avatar
Re: Rivnut Tool
If your ACE is selling 6061, good for them! But I would bet you $10 that it's 6063 and I HATE that stuff, super gummy and nowhere near as stiff.
Please don't buy hardware store aluminum. Please.
Old 12-29-2016, 03:52 AM
frcguy's Avatar
frcguy frcguy is offline
Unregistered Unuser
AKA: Nicholas Dal Porto
FRC #5940 (B.R.E.A.D.)
Team Role: Tactician
frcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond repute
Rivnut Tool
I shamefully admit that at least 50% of the metal on our robot was bought from Orchard Supply.
Never again...
2016: Team 5940 (Silicon Valley Regional Rookie All-Star and Quarterfinalist, Curie Quarterfinalist)
Volunteer: 2016 (Chezy Champs Field Reset, Capital City Classic FTA, MadTown ThrowDown FTA)
Old 12-29-2016, 08:02 AM
GeeTwo's Avatar
Technical Director
AKA: Gus Michel II
Re: Rivnut Tool
This was all just scraps from my garage. For structural robot parts above the drive train, we use versa frame and 6061 channel (and a small amount of tubing) usually from Bayou Metals. When I do the more complete testing, I'll be sure to get some 6061 scraps from the recycle bin at the robot workshop.
Gummy? Would you please elaborate?
Old 12-29-2016, 09:35 AM
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
Re: Rivnut Tool
Lots of applications where you cannot get to the back side to use a nut and the material is too thin to thread.
