Go to Post Yeah those design flaws kill you in the end. You especially hate finding out about them in competition. - Koko Ed [more]
Unread 30-12-2016, 02:23
FRCTeam2906's Avatar
FRCTeam2906 FRCTeam2906 is offline
FRC #2906 (Sentinel Prime)
FRCTeam2906 is an unknown quantity at this point
Wiring LEDs into the control system/motor controllers
With this year's game in mind, my team is looking at using small single LEDs to light up various components on our robot. We have had trouble running multiple functions on our Arduino at once (randomized led fading and led strip program). Since this has not been working we are looking into other methods or powering this LEDs.
With regard to rules in the past, would it be possible to wire individual LEDs to each motor controller output, with a motor attached as well? This way we should see a dimming effect when powering that motor. We are not sure if this rule (R53), or others prohibits this.
"R53 Each power regulating device may control electrical loads per Table 4-4. Unless otherwise noted, each power regulating device shall control one and only one electrical load.
(2016 FRC Game Manual, firstinspires.org).
Would it make more sense to use a relay? Also, where would we find/buy a relay and what type should we purchase, if necessary?
2nd part of R53:
*Multiple low-load, pneumatic solenoid valves, electric solenoids or CUSTOM CIRCUITS may be connected to a single relay module. This would allow one (1) relay module to drive multiple pneumatic actions or multiple CUSTOM CIRCUITS. No other electrical load can be connected to a
relay module used in this manner."
If there are any other strategies that we should approach, or any comments/concerns please feel free to let us know.
Thank you,
FRC Team 2906
President Walker Ward
Unread 30-12-2016, 03:27
pilleya's Avatar
pilleya pilleya is offline
Elec+Mech
AKA: Alastair Pilley
FRC #4613 (Barker Redbacks)
pilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond repute
Re: Wiring LEDs into the control system/motor controllers
2nd part of R53:
First up it is illegal to run something such as LED's in parallel from the Motor Controller Output. Even if it wasn't they wouldn't light up at all when Motor isn't being drive and would be very dim most of the time depending on the Duty Cycle of the output. Also the LED's would actually be the brightest when the motor is at fully power( 100% duty cycle) rather than the dimmest. They would also probably not appreciate the Pulse Width Modulation and die.
If you are using single LED's rather than strips the LED's are probably quite high in power( and thus draw a lot of current) so you will most likely need to use a Spike Relay.
You can use the Solenoid Outputs on the PCM as these are basically inbuilt little "relays"(solid state) which then control the main solenoid which shuts/opens the air flow. But you need to be careful and each port on the PCM can't supply a lot of current and you risk blowing the fuse on the PCM which will mean no pneumatics.
Sponsors, parents, students and mentors love helping teams succeed. Denso Throttle motors also want to help, don't break their hearts. REDBOX(gearbox for the throttle motor)
Facebook
Unread 30-12-2016, 10:14
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
If you really mean single SMALL LEDs, you may be able to power them directly from the DIO ports (check the current requirements of the LEDs and the current providing capacity of the ports), and you could program some duty cycle dimming in your periodic functions for them. If you have a higher current draw requirement but are willing to give up on the dimming, you could use small 5V or 12V relay modules, switched from DIO or relay ports.
Unread 30-12-2016, 10:30
MrRoboSteve MrRoboSteve is offline
AKA: Steve Peterson
FRC #3081 (Kennedy RoboEagles)
MrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond repute
The PCM is an option for powering 12V LEDs. Note the 500mA aggregate limit on current for the solenoid ports.
2016-17 events: 10000 Lakes Regional, Northern Lights Regional, FTC Burnsville Qualifying Tournament
2011 - present · FRC 3081 Kennedy RoboEagles mentor
2013 - present · event volunteer at 10000 Lakes Regional, Northern Lights Regional, North Star Regional, Lake Superior Regional, Minnesota State Tournament, PNW District 4 Glacier Peak, MN FTC, CMP
http://twitter.com/MrRoboSteve · www.linkedin.com/in/speterson
Unread 30-12-2016, 10:34
Josh Tatum Josh Tatum is offline
FRC #0303 (T.E.S.T team)
Team Role: Electrical
Josh Tatum is an unknown quantity at this point
This is another way to wire leds on the robot. there are tutorials on their site how to wire and contol them. http://www.mindsensors.com/frc/181-c...for-frc-robots
