FRCSim, Gazebo v7, and GearsBot example
Having difficulty getting FRCsim to work.
I installed the FRC simulator in accordance with the latest WPI procedure with the exception that I installed Gazebo version 7 instead of 6. I start frcsim as follows: frcsim ~/wpilib/simulation/worlds/GearsBotDemo.world Next I bring up the driver station with sim_ds. Finally I start up eclipse neon, open up the GearsBot demo project, and run it as a WPILib Java Simulation. The Gazebo window shows the robot on a simple playing field with a few cans and a platform similar to the video demo. However when I enable autonomous or teleop the robot does nothing. In the console I get a few "Failed to initialize simulator/dio/1/2: does the encoder exist?" messages, eventually getting a message that ends with "Overload me!" Meanwhile in the terminal I get a bunch of messages as follows "Failed to load plugin /home/team533/wpilib/simulation/plugins/libdc_motor.so: libgazebo_physics.so.6: cannot open shared object file : No such file or directory". Are the simulation plugins somehow hard wired to Gazebo version 6? Any help would be appreciated. Regards, Neil Heft Engineer - Mentor, Team 533 |
Re: FRCSim, Gazebo v7, and GearsBot example
I noticed that some of the sensors files need to be renamed.
( e.g., cp libencoder.so libgz_encoder.so ) See lesson learned #4 below. Watch for errors on startup and create copies of the files as required. Stick with FRCSIM. I think this will be an important tool once we learn and document how to use it. Dave Frederick Team 1895 Mentor ============================================== Limitations: 1) The FRCSIM can take a few tries to start. 2) Joystick methods are not working correctly (getX(), getY() and getZ() ) Use: Robot.oi.joystick1.getRawAxis(0) // Robot.driveTrainSubSystem.ArcadeDrive(Robot.oi.joy stick1.getY(),Robot.oi.joystick1.getX()); Robot.driveTrainSubSystem.ArcadeDrive(Robot.oi.joy stick1.getRawAxis(0), Robot.oi.joystick1.getRawAxis(1)); Notes: Joystick - Axis 0 - Left(-) and Right(+) - Axis 1 - forward (-) and Back (+) - Axis 2 - Rotate forward (-) and Back (+) Seems like getX(), getY() and getZ() are not working - wrong order 3) The Analog Gyro does not support the “setSensitivity” method. Comment out in RoboMap. 4) Needed to rename a few sensors (one Time). /home/robot/wpilib/simulation/plugins/ cp libencoder.so libgz_encoder.so cp libgyro.so libgz_gyro.so |
