Go to Post Programmer says autonomous will work 100% perfectly...Great way to clear the room of all mechanicals and all but the boldest electricals - EricH [more]
Go Back   Chief Delphi > Competition > Rules/Strategy > Scouting
Old 12-31-2016, 06:23 PM
Skyehawk's Avatar
Skyehawk Skyehawk is offline
Nuts N' Bolts
AKA: Skye Leake
FRC #0876 (Thunder Robotics)
Skyehawk is a name known to allSkyehawk is a name known to allSkyehawk is a name known to allSkyehawk is a name known to allSkyehawk is a name known to allSkyehawk is a name known to all
R, OPR, etc
Hello to the rather specific part of the FIRST community I am targeting,
I was reading over OPR calculation and other such calculations in order to calculate offensive contributions and some ideas started to weasel its way into my head, therefore I must pursue them. I should pick up the R language relatively easily, as it seems to share many common elements with Python and Matlab. I was wondering are there some resources that you guys could point me towards to aid with my learning? I am slowly falling deeper end deeper into the statistical analysis rabbit hole and any help to ease the future confusion I may have is greatly appreciated.
Happy New Year!
Skye Leake
My time in FIRST has made me a better person, frankly I don't know where I'd be without it.
2011 Lake Superior Regional Champs
2015 Central Illinois Regional Engineering Inspiration Award recipients
2016 Central Illinois Regional Champs
Old 12-31-2016, 06:51 PM
Oblarg Oblarg is offline
AKA: Eli Barnett
Re: R, OPR, etc
This textbook is oriented towards psychology students, but is a good introductory textbook for just about anyone:
https://health.adelaide.edu.au/psych.../teaching/lsr/
Be sure to download Rstudio, it's about a billion times easier than using R through the standard shell.
"The breakfast of champions!"
Old 12-31-2016, 06:57 PM
Skyehawk's Avatar
Nuts N' Bolts
AKA: Skye Leake
Re: R, OPR, etc
One of my housemates went through an entire semester of Biometry working straight from the shell, it made my skin crawl. A proper GUI is a must and was installed mere seconds after I installed R.
[EDIT]
I have been using this website as an introduction. It is geared more towards novice programmers but seems to provide strong overviews of the various components of Rstudio.
Old 12-31-2016, 07:06 PM
Re: R, OPR, etc
https://www.chiefdelphi.com/forums/s...7&postcount=24
Old 12-31-2016, 07:16 PM
Skyehawk's Avatar
Nuts N' Bolts
AKA: Skye Leake
Re: R, OPR, etc
The plan is to slowly work to that. I have a lot of learning to do. I have bookmarked that thread for later use, thanks for linking it in though.
I have some concerns about my package palette. I am sure I will find what I need in time through trial and error; but is there anything additional packages that may prove generally useful that are basic 'need-to-haves'?
Thanks,
Skye Leake
Old 12-31-2016, 08:17 PM
AKA: Eli Barnett
Re: R, OPR, etc
Thanks,
Skye Leake
ggplot2, because it's far easier to use than the default plotting package once you learn it, and reshape2 are the two I'd say are "need-to-haves."
Old 12-31-2016, 09:23 PM
Re: R, OPR, etc
...I have a lot of learning to do. I have bookmarked that thread for later use, thanks for linking it in though.
I was reading over OPR calculation and other such calculations in order to calculate offensive contributions and some ideas started to weasel its way into my head, therefore I must pursue them... I was wondering are there some resources that you guys could point me towards to aid with my learning?
If you need any links to posts and threads here on CD that explain the math underlying the computation of OPR let me know.
[IMG] code is Off
