Go to Post Don't let my students know I skimmed that blog and didn't read it thoroughly. - rlance [more]
Unread 30-12-2016, 14:12
nheft nheft is offline
FTC #0533 (Psichotics)
nheft is a jewel in the roughnheft is a jewel in the roughnheft is a jewel in the roughnheft is a jewel in the rough
FRCSim, Gazebo v7, and GearsBot example
Having difficulty getting FRCsim to work.
I installed the FRC simulator in accordance with the latest WPI procedure with the exception that I installed Gazebo version 7 instead of 6.
I start frcsim as follows:
frcsim ~/wpilib/simulation/worlds/GearsBotDemo.world
Next I bring up the driver station with sim_ds.
Finally I start up eclipse neon, open up the GearsBot demo project, and run it as a WPILib Java Simulation.
The Gazebo window shows the robot on a simple playing field with a few cans and a platform similar to the video demo. However when I enable autonomous or teleop the robot does nothing.
In the console I get a few "Failed to initialize simulator/dio/1/2: does the encoder exist?" messages, eventually getting a message that ends with "Overload me!"
Meanwhile in the terminal I get a bunch of messages as follows
"Failed to load plugin /home/team533/wpilib/simulation/plugins/libdc_motor.so: libgazebo_physics.so.6: cannot open shared object file : No such file or directory".
Are the simulation plugins somehow hard wired to Gazebo version 6?
Any help would be appreciated.
Regards,
Neil Heft
Engineer - Mentor, Team 533
Unread 01-01-2017, 11:19
DaveFrederick's Avatar
DaveFrederick DaveFrederick is offline
FRC #1895
DaveFrederick is a jewel in the roughDaveFrederick is a jewel in the roughDaveFrederick is a jewel in the rough
Re: FRCSim, Gazebo v7, and GearsBot example
I noticed that some of the sensors files need to be renamed.
( e.g., cp libencoder.so libgz_encoder.so )
See lesson learned #4 below.
Watch for errors on startup and create copies of the files as required.
Stick with FRCSIM. I think this will be an important tool once we learn and document how to use it.
Dave Frederick
Team 1895 Mentor
Limitations:
1) The FRCSIM can take a few tries to start.
2) Joystick methods are not working correctly (getX(), getY() and getZ() )
Use: Robot.oi.joystick1.getRawAxis(0)
// Robot.driveTrainSubSystem.ArcadeDrive(Robot.oi.joy stick1.getY(),Robot.oi.joystick1.getX());
Robot.driveTrainSubSystem.ArcadeDrive(Robot.oi.joy stick1.getRawAxis(0), Robot.oi.joystick1.getRawAxis(1));
Notes: Joystick
- Axis 0 - Left(-) and Right(+)
- Axis 1 - forward (-) and Back (+)
- Axis 2 - Rotate forward (-) and Back (+)
Seems like getX(), getY() and getZ() are not working - wrong order
3) The Analog Gyro does not support the “setSensitivity” method. Comment out in RoboMap.
4) Needed to rename a few sensors (one Time).
/home/robot/wpilib/simulation/plugins/
cp libgyro.so libgz_gyro.so
