Go to Post So yeah, everyone please remember that lathes are one of the most dangerous machine tools you'll encounter. And keep your hand on the chuck key whenever it's in the chuck. If you never let it go till it's out of the chuck, it's stupendously less likely to take flight. - Kevin Sevcik [more]
Unread 01-01-2017, 12:05
aeastet aeastet is offline
Programming Mentor
AKA: Tim Easterling
FRC #6043 (Allegan Tigers Robotics)
aeastet is an unknown quantity at this point
Write to Flash Drive on the RoboRio
Has anyone here developed a method to write to the flash drive through LabVIEW to the RoboRio flash drive?
Unread 01-01-2017, 12:51
jman4747's Avatar
jman4747 jman4747 is offline
Just building robots
AKA: Josh
FRC #4080 (Team Reboot)
Team Role: CAD
jman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond repute
Re: Write to Flash Drive on the RoboRio
Plug in a flash drive and open up the Rio web based configuration. Then in the file browser find what the flash drive directory is called. Ours was "/u".
Once you know what the directory is called you can use the File I/O VI's in the Programming section on the Function pallet.
An example file path would be: /u/auto_programs/Program-1.txt
/u is the flash drive
/auto_programs would be a user created folder in this case
/Program-1.txt would be a text file you are saving data to
Alumni, CAD Designer, machinist, and Mentor: FRC Team #4080
Mentor: Rookie FTC Team "EVE" #10458, FRC Team "Drewbotics" #5812
#banthebag
#RIBMEATS
#1620
Unread 01-01-2017, 13:11
Programming Mentor
AKA: Tim Easterling
Thank you for that information. It is an interesting way to think about what we could do.
I was actually thinking about writing tot he RoboRio drive. Has anyone done that through LabVIEW?
Unread 01-01-2017, 13:34
jman4747's Avatar
AKA: Josh
Team Role: CAD
Same thing just start with the main directory of the Rio instead of the flash drive directory.
#banthebag
#RIBMEATS
#1620
Unread 01-01-2017, 13:53
Programming Mentor
AKA: Tim Easterling
What are you using to do this? I tried the create file and it tells me that it does not exists. Are you using a standard LabVIEW function to do this?
Any chance you have example code. A picture would do.
Unread 01-01-2017, 14:09
jman4747's Avatar
AKA: Josh
Team Role: CAD
See the attached example.
#banthebag
#RIBMEATS
#1620
Unread 04-01-2017, 07:58
Jonathan L. Jonathan L. is offline
FRC #1094
Jonathan L. is a jewel in the roughJonathan L. is a jewel in the roughJonathan L. is a jewel in the roughJonathan L. is a jewel in the rough
See "File IO" at http://wpilib.screenstepslive.com/s/...e-2014-to-2015
You may need to use the base path /home/lvuser to write files to the roboRIO. Also, remember to use the Create Folder function BEFORE the Create File function if you are not sure that the folder has been created yet.
The File I/O functions are in the Programming\File I/O palette and the Create Folder function is in the Programming\File I/O\Advanced File Functions palette.
You can read and write to a simple text file or to your own binary file (as long as you keep track of the LabVIEW Data Type that the file uses). There is a subPalette that contains VIs for making .ini configuration files (caution: the configuration file is not actually saved until it is closed). Also, if you want to save a cluster of data in a human readable format, you can use the Flatten JSON or XML functions in the Programming\String\Flatten/Unflatten String palette.
Unread 04-01-2017, 12:41
Programming Mentor
AKA: Tim Easterling
Hey thanks Jonathan. That was helpful info.
