Go to Post I owe a debt, as many FIRSTers do, to the entire organization as a whole. Every team, every student, every person involved has help make FIRST what it is today. This is my Thank You. ~Anonymous - BandChick [more]
Unread 01-01-2017, 12:05
aeastet aeastet is offline
Programming Mentor
AKA: Tim Easterling
FRC #6043 (Allegan Tigers Robotics)
aeastet is an unknown quantity at this point
Write to Flash Drive on the RoboRio
Has anyone here developed a method to write to the flash drive through LabVIEW to the RoboRio flash drive?
Unread 01-01-2017, 12:51
jman4747's Avatar
jman4747 jman4747 is offline
Just building robots
AKA: Josh
FRC #4080 (Team Reboot)
Team Role: CAD
jman4747 has a brilliant futurejman4747 has a brilliant futurejman4747 has a brilliant futurejman4747 has a brilliant futurejman4747 has a brilliant futurejman4747 has a brilliant futurejman4747 has a brilliant futurejman4747 has a brilliant futurejman4747 has a brilliant futurejman4747 has a brilliant futurejman4747 has a brilliant future
Re: Write to Flash Drive on the RoboRio
Plug in a flash drive and open up the Rio web based configuration. Then in the file browser find what the flash drive directory is called. Ours was "/u".
Once you know what the directory is called you can use the File I/O VI's in the Programming section on the Function pallet.
An example file path would be: /u/auto_programs/Program-1.txt
/u is the flash drive
/auto_programs would be a user created folder in this case
/Program-1.txt would be a text file you are saving data to
Alumni, CAD Designer, machinist, and Mentor: FRC Team #4080
Mentor: Rookie FTC Team "EVE" #10458, FRC Team "Drewbotics" #5812
#banthebag
#RIBMEATS
Unread 01-01-2017, 13:11
Programming Mentor
AKA: Tim Easterling
Thank you for that information. It is an interesting way to think about what we could do.
I was actually thinking about writing tot he RoboRio drive. Has anyone done that through LabVIEW?
Unread 01-01-2017, 13:34
jman4747's Avatar
AKA: Josh
Team Role: CAD
Same thing just start with the main directory of the Rio instead of the flash drive directory.
#banthebag
#RIBMEATS
Unread 01-01-2017, 13:53
Programming Mentor
AKA: Tim Easterling
What are you using to do this? I tried the create file and it tells me that it does not exists. Are you using a standard LabVIEW function to do this?
Any chance you have example code. A picture would do.
Unread 01-01-2017, 14:09
jman4747's Avatar
AKA: Josh
Team Role: CAD
See the attached example.
#banthebag
#RIBMEATS
