Go to Post I know you've finished the first 75% of the robot, but do you have enough time left to finish the other 75%? - Rick TYler [more]
Go Back   Chief Delphi > Competition > Championship Event
Unread 18-04-2003, 21:14
234EP
Posts: n/a
Nationals Video System
I had a VCR set up in the Curie area, and was told that I would get the feed from the main stage during events there, and matches from the Curie field when they were going on. I have watched two days worth of tape and only have the main stage events and then the "FIRST" logo and animations. It appears I only recorded the main FIRST feed and nothing from matches.
Did I miss something in the system set up or did others experience the same????
Unread 18-04-2003, 21:31
FRANK(WGH) FRANK(WGH) is offline
Webmaster - delphielite.com
AKA: Frank
FRC #0048 (Delphi E.L.I.T.E.)
Team Role: Webmaster
FRANK(WGH) will become famous soon enough
Send a message via AIM to FRANK(WGH)
Well FIRST confused some of the people at curie and set up 2 Hook ups in that area.
The one nearest to Curie field was the feed u should have hooked into.
that's where i had our stuff at and it worked the whole time.
I wish they would have set that up better but we will have to mention that for next year.
If u have some certain matches that u need i might be able to help u or i can give u what i have on some VHS tapes or something.
E-mail me and we should be able to work someting out.
Frank Bosak
Collegiate Mentor Association
Team 48 - Delphi E.L.I.T.E.
Unread 18-04-2003, 22:25
Steve W Steve W is offline
Grow Up? Why?
Steve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond repute
There was 2 feeds at Curie. 1 for the Curie field and 1 for the main field. I have 6 - 2hr tapes (standard format) of the Curie field if needed. I could probably get certain matches for you if needed.
Unread 18-04-2003, 23:43
234EP
Posts: n/a
Thanks to both. I will get the match numbers and PM one of you.
I wish the areas had been labeled - I just thought they were making enough space for several people to connect.
2004 Championship Eligibility Criteria!!! dez250 General Forum 214 28-12-2003 20:11
Please help make the Nationals in Houston AWESOME ... You be the Tournament Director Natchez General Forum 42 13-12-2002 18:50
control system worth more than $500 archiver 2001 8 24-06-2002 02:00
Good video footage miketwalker General Forum 0 28-03-2002 17:14
Making heads or tails of the new announcement... Jessica Boucher General Forum 66 26-09-2001 11:13
