Re: Best Time Savings
I can hopefully provide some tips in the CAD modeling section of work...
Our team is quite small and I am essentially the only individual who knows how to use CAD on our team. Here is how I am able to work efficiently to try and match the CAD achievements of teams with many more people: First of all, don't start the actual CAD model until you can't visualize it in your head in any more detail. The more you design in your head, the more you can fix before it is CAD modeled. That way you don't have to go through and redo entire subsystems quite as many times. Also before starting the CAD model, draw the entire frame out on paper in all the different views (sides, top, bottom). This allows for the CAD to go quick once started because you can copy off of a piece of paper. This goes for other mechanisms as well but in a less detailed manner. Don't CAD model anything unnecessary. Make sure to think about where bolts and wires and tubing will be fitting, but don't spend the time modeling them all in. While CAD modeling, the biggest time saver for me has been this spreadsheet that I created. I used to end up with about 20 windows open on my laptop, but now with this I only need solidworks and the spreadsheet. It has info on all of the parts our team uses, and calculators for all types of power transmission and pneumatics. Also in other tabs it has an inventory, a space for pasting values from the calculators for future notice, and the CAW. It wont work for you when viewing it because the files are on my hard drive, but the titles of each part are hyperlinked to the drawings for quick mechanical reference. I would highly suggest designing a spreadsheet like this tailored to your team's specific mechanical design style. I hope some of this helps! |
Yes! I have a zip file made. Can someone explain how I put that zip file into this forum?
Don't know if that was the best way to do it, but the zip file is in the most recent white paper! There is also a discussion forum for it now. Glad people are interested!
thanks for posting that
#7
One thing I have tried in the past few seasons was giving the programmers a heads up on what to expect.
Telling them that the team intends to use X motor for a function or Y drivetrain style really helps give them time to work. Even though it might be a week before a robot is ready to have the code loaded to be tested, the programmers can use this time to layout a basic framework for what the code will look like based on what is being designed/CAD'ed/built. |
#8
I'm hoping to try a new approach to electronics this year. Usually, our wiring process takes about a week, since we do it very neatly. Also, we usually wait until the frame is all machined, welded, and back from powder coat. This time, I'm going to try to work with the students to start on the electronics layout on Day 1, and mount it all to a sub-plate, that the rest of the design will have to accommodate later. That way, we can start wiring right away, and have it all ready to go whenever the robot is mechanically done. At least we can wire everything from main breaker to motor controllers and everything in between. Frame comes back from powder coat, assemble mechanical things, plop the electronics plate in, plug in motors and encoders, and you're up and running. I think it would get us running about a day after powder coat instead of a week after powder coat.
#9
I would recommend doing the electronics layout more in parallel with the chassis, rather than have it drive the robot design. That is, once the basic requirements are known (e.g. six motor controllers, four solenoids, and a raspberry pi vision processor), do a quick layout to determine how much space you need (don't forget battery and main breaker), and make sure that it's included in the chassis design. Then, after the chassis is drawn out, do the detail design and build the control board while the frame is being machined, welded, and powder coated. You should still be ready to install and plug in by the time the mechanical systems are assembled. Edit: If you do this, make sure to coordinate between your board wiring sub-team and your chassis wiring sub-team as to where (and what type) your connectors will be. It's no fun to come up a few inches short, or a foot too long. Even if it's the same two people, it's better to decide before you start terminating wires. Last edited by GeeTwo : Yesterday at 12:36 PM. |
#10
Single biggest time saver I can remember is learning to draft. CAD is great but takes an awful lot of time to learn how use it efficiently. I just sketch my ideas and only CAD when total precision is necessary. you'd be surprised the precision that can be achieved with pencil and paper. I saved countless hours.
#11
I'm a mechanical stuff guy, and the best way I've found to save time is to think simple. Every year I see lots of teams invest a ton of time (we've been guilty too) into ideas or mechanics that were too complicated to sort out in the short build season. Every idea I come up with I try to think "how can I make this more simple?" This includes making it mechanically simple (less mechanisms/moving parts,) build simple using easy to work with parts (COTS vs. custom, or builder friendly stock like versatube, 80/20 etc.) making it easy to assemble/service/upgrade and more. The time you spend thinking about and simplifying your designs will be returned many times over in the long run.
Often times the more mechanically simple a concept is, the easier it is to CAD (saves time) the easier it is to build (saves time) and the easier it is to program (saves time.) I also encourage our team to find a good balance between COTS and Custom parts. We have limited machining resources (all manual machines, except one DRO mill, still requires manual entry) so deciding when to make vs. buy is an important decision, and can often save a lot of time. Think smart, plan ahead, and keep it simple! You'll save a TON of time, and probably end up with a more reliable and competitive machine. |
