Go to Post This thread is a reminder to myself that I have 29 more days to sleep. :) - Seth Mallory [more]
Go Back   Chief Delphi > Technical > CAD > SolidWorks
Unread 01-01-2017, 18:09
Mike Schreiber's Avatar
Mike Schreiber Mike Schreiber is offline
FRC #0067 (The HOT Team)
Mike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond repute
Z-Up Modeling in Solidworks
I'm trying to reset my part and assembly templates in Solidworks so that +Z is up (instead of the default of +Y) with +X as the front of the robot. I'm using the update standard views technique that can be seen in this video. He has Y+ as front, but the concept is the same.
This works great until I want to put a sketch on the front plane. This makes the sketch orientation turned 90 degrees from where I want it - by that I mean when you use the 'Normal to' view command on the sketch the Z+ (top of your robot) is now the left side of the screen and constraining a line to vertical actually ends up being horizontal in the sense of the robot (parallel to the XY plane). I know you can change view orientation easily using the Front view or clicking axis, but the more annoying part is the vertical and horizontal constraints being non-intuitive. This can be remedied with the command Tools -> Sketch Tools -> Modify and reorienting that individual sketch by 90 degrees. But it's slow and I don't want to have to do that for every sketch I make.
If that explanation wasn't clear I've attached a picture of my axis. You can see the text for the Front Plane on the plane is oriented sideways. Solidworks wants where that text is to be the top left corner when I create a sketch on that plane.
Curious how other Solidworks users deal with this? Anyone else use Z-up?
Mike Schreiber
Kettering University ('09-'13) University of Michigan ('14-'18?)
FLL ('01-'02), FRC Team 27 ('06-'09), Team 397 ('10), Team 3450/314 ('11), Team 67 ('14-'??)
