Go to Post work? I can't remember when the last time i did that was... - Carolyn Duncan [more]
Go Back   Chief Delphi > Technical > CAD > SolidWorks
Unread 01-01-2017, 06:09 PM
Mike Schreiber's Avatar
Mike Schreiber Mike Schreiber is offline
FRC #0067 (The HOT Team)
Mike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond repute
Z-Up Modeling in Solidworks
I'm trying to reset my part and assembly templates in Solidworks so that +Z is up (instead of the default of +Y) with +X as the front of the robot. I'm using the update standard views technique that can be seen in this video. He has Y+ as front, but the concept is the same.
This works great until I want to put a sketch on the front plane. This makes the sketch orientation turned 90 degrees from where I want it - by that I mean when you use the 'Normal to' view command on the sketch the Z+ (top of your robot) is now the left side of the screen and constraining a line to vertical actually ends up being horizontal in the sense of the robot (parallel to the XY plane). I know you can change view orientation easily using the Front view or clicking axis, but the more annoying part is the vertical and horizontal constraints being non-intuitive. This can be remedied with the command Tools -> Sketch Tools -> Modify and reorienting that individual sketch by 90 degrees. But it's slow and I don't want to have to do that for every sketch I make.
If that explanation wasn't clear I've attached a picture of my axis. You can see the text for the Front Plane on the plane is oriented sideways. Solidworks wants where that text is to be the top left corner when I create a sketch on that plane.
Curious how other Solidworks users deal with this? Anyone else use Z-up?
Mike Schreiber
Kettering University ('09-'13) University of Michigan ('14-'18?)
FLL ('01-'02), FRC Team 27 ('06-'09), Team 397 ('10), Team 3450/314 ('11), Team 67 ('14-'??)
Unread 01-01-2017, 06:32 PM
Michael Hill's Avatar
Michael Hill Michael Hill is online now
Re: Z-Up Modeling in Solidworks
I've thought about using Z-up in SolidWorks because it makes sense to me, but it ended up being more trouble than it was worth. I defined a new coordinate system and I think the view planes worked themselves out. However, if you want moments of inertia, you have to select your new reference frame rather than the default one. You'll still have the "wrong" vectors being shown in the lower left. See my attachment.
Unread 01-01-2017, 07:10 PM
I'm on Solidworks 2015 until we get our new licenses for this season (should be any day now). Can you save a backwards compatible version?
Mike Schreiber
Unread 01-01-2017, 07:27 PM
Unfortunately I don't think SolidWorks lets you. But basically, in a part/assembly (you can even do it with a part/assembly and save it as a template part/assembly), with the Features tab selected, go to Reference Geometry and select Coordinate Frame. (Sorry, screen shots are huge)
http://imgur.com/fy4L3sN
Then use the following settings:
http://imgur.com/Jcf3FdH
The selected axis will be normal to the plane you select.
