Go to Post All tools are powered by magic angry noise. - artdutra04 [more]
Old 02-01-2017, 00:22
RobotsQ RobotsQ is offline
FRC #1155
RobotsQ is an unknown quantity at this point
Easy Bumper Switching?
Last season we attached our bumpers to the robot by putting grenade pins through L-brackets, but after having them jarred loose and finally having them fall off of the robot in our first match of competition, we were forced to make the switch to nuts and bolts. However, even those fell loose in our second match, forcing us to use nylock nuts. This was less than ideal, as all 12 nuts had to be held from the underside while being attached or detached by a vice grip, pliers, or socket wrench, which in turn forced us to tilt the robot up on end and stop work on any mods or fixes for the five or six minutes it took to change bumpers.
Simply put, there has to be a better way.
How do you and your team usually attach bumpers, and does anyone have ideas for quick and secure bumper changes?
I know that a lot of teams just use Velcro to change colors, but in an intense physical game like stronghold we were concerned about its integrity.
Sent from my iPhone using Tapatalk
Old 02-01-2017, 00:57
PopeRyanI PopeRyanI is offline
FRC #2410 (Metal Mustangs Robotics)
PopeRyanI is an unknown quantity at this point
Re: Easy Bumper Switching?
My team uses Velcro to change colors and have never had a problem with the Velcro not working any more or anything like that. It is a super nice system overall because it makes the transition in the pit so much faster (or even in the queue if you forget).
Old 02-01-2017, 01:01
troy_dietz's Avatar
troy_dietz troy_dietz is offline
3D printing and Alliance Captain
FRC #0330 (The Beach Bots)
Team Role: Human Player
Rookie Year: 2015
troy_dietz is on a distinguished road
We use a similar system with grenade pins, but with c-channel. This past year we also used "hook and loop fastener" where the bumpers ended (creating a gap) to prevent them from being bent.
Old 02-01-2017, 01:07
This last season, we built 1-piece bumpers, then put an L-angle along the sides. On the robot, we welded some toggle clamps. Pop the clamps, pull the bumper off, put the other one on, lock the clamps down. Didn't lose a bumper all season (though we did do a rebuild for Champs). I want to say we "borrowed" the idea from Citrus or Poofs or someone up that way.
Another good method is to embed T-nuts in the bumper plywood, on the noodle side. (Glue 'em in thoroughly, though--you do NOT want them coming out!) Then all you need is long enough bolts, strategically placed for easy access.
Old 02-01-2017, 01:35
BigBen's Avatar
BigBen BigBen is offline
FRC #3494 (The Quadrangles)
BigBen will become famous soon enough
We have a mentor that does a decent amount of sewing and have had the students do reversible bumpers in house the last few years, similar to the RoboPromo kit:
http://www.robopromo.com/product_p/rp-2004.htm
The video at the bottom of the page does a decent job of walking through the process. Words of caution, make sure they are centered vertically on the board, as tight on the board as possible and that the Velcro on top and bottom has several staples through it. That keeps the Velcro from loosening due to movement of the cloth on the wood backing. Also we use full strips of Velcro at on the top and bottom.
This allows us to permanently mount the bumpers.
Old 02-01-2017, 01:37
chadr03's Avatar
chadr03 chadr03 is offline
FRC #2582 (PantherBots)
chadr03 has a spectacular aura aboutchadr03 has a spectacular aura aboutchadr03 has a spectacular aura about
The key to easy bumper switching is use as few bumper pieces as possible. The past few times we have had to use bumpers we have built one piece bumpers where a single bumper wraps around the entire robot. I think most bots I have seen could be build with one or two piece bumpers.
With one piece bumpers we have had success using four mounting bolts (one on each corner). The bolts will go through our frame vertically with the head at the bottom and the threads pointing upward. They are held in place with a nylock nut. A long enough bolt is used that there is thread protruding from the nylock nut. The bumpers have angle aluminum brackets attached that have holes drilled through them that allow the bumper to drop onto the bolts. A second nylock nut is used to secure the bumper to the frame.
This makes a very secure connection and with only four nuts designed for easy access allows for quick changes. Two students can easily change bumpers in less than a min.
In the past we have tried pins, clips, t-nuts, and velcro reversing bumpers, but simply using nylock nuts and bolts and as few bumpers as possible has been the best solution.
Old 02-01-2017, 02:26
Bryce2471's Avatar
Bryce2471 Bryce2471 is offline
Alumnus
AKA: Bryce Croucher
FRC #2471 (Team Mean Machine)
Bryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud of
Last year 2471 used home made plastic latches, and bolts that fell into slots. This was by far the best attachment method we have ever used. It was very secure and could be put on or taken off in about 15 seconds. Just push down on the bumper to attach, or pull the plastic tabs and lift to remove.
Here is a picture of one corner:
https://scontent-dft4-2.xx.fbcdn.net...0aa3f859 22b7
FLL Team Future imagineers
2010 Oregon State Championships: Winners
2011 International Invite: First place Robot design, Second Place Robot Performance
FRC Team Mean Machine
2012 Seattle: Winning alliance
2013 Portland: Winning alliance
2013 Spokane: Winning alliance
2014 Wilsonville: Winning alliance
2014 Worlds: Deans List Winner
Old 02-01-2017, 02:41
runneals's Avatar
runneals runneals is offline
FTC Mentor - The Robot Corps 7491
FRC #3928 (Team Neutrino)
runneals has a spectacular aura aboutrunneals has a spectacular aura about
We use some button latches. They are super nice to just drop the bumpers on and clip the latches into place. Also
check out these photos of us making bumpers with one of our super amazing alumni mentors that came to Iowa from Chicago to help us make them (We used to have a page on bumper stuff, but apparently it got taken down). Let me know if you have any questions and I can get them answered.
David Runneals
FRC 3928 Team Neutrino 4-H: Mentor (2015 Off-Season - ?)
FTC North Super Regional Championship: Game Announcer (2015)
FTC 7491 The Robot Corps 4-H: Mentor (2013 - ?)
FRC 2167 Mentor (2014)
FRC 3928 Team Neutrino 4-H: Member, Co-Captain, & Media Coordinator (2013)
Old 02-01-2017, 05:05
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
We have used velcro covers, the "four captive bolts" similar to chadr03, and tee nuts (behind a noodle, with a stud at the other for alignment). The four captive bolts was best, with wing nuts to secure the bumper - fastest and more reliable. When you have an interruption in the bumper for an intake (as most teams did in 2016), the bolts should be moved away from the corner and closer to the gap. A few extra bolts without wing nuts will help alignment and provide a backup if you strip threads or otherwise lose use of the main bolts and don't have time to swap out the extended bolt through nylock.
Old 02-01-2017, 10:29
FRC #1155
That's brilliant. Will totally look into some toggle clamps this season.
Old 02-01-2017, 11:06
Rainydaymaker's Avatar
Rainydaymaker Rainydaymaker is offline
AKA: Jim
FRC #1983 (Skunk Works)
Rainydaymaker is on a distinguished road
One piece bumpers, aluminum angle near the top edge, secured with double locking toggle clamps. https://www.mcmaster.com/#4961a11
Jim Smith
FLL Coach
FTC Coach 3721
FRC Mentor 1983
Old 02-01-2017, 11:21
MonroeM MonroeM is offline
FRC #3570
MonroeM is an unknown quantity at this point
We used the standard bumper mounting kit this past year. To switch colors is a pain with the thumb screws so a few years ago we came up with a concept. We always have the blue bumpers on and when we need red we just pull the slipcover we made over the blue bumpers. The red cover is just one piece that wraps around all of the bumpers with elastic along the top and bottom. To make sure it says we put a staple in at the ends and one along the top on each side. We have never had a bumper come off using this method.
Old 02-01-2017, 13:16
bstew's Avatar
bstew bstew is offline
Team Role: CAD
Rookie Year: 2015
bstew is a splendid one to beholdbstew is a splendid one to beholdbstew is a splendid one to beholdbstew is a splendid one to beholdbstew is a splendid one to beholdbstew is a splendid one to beholdbstew is a splendid one to behold
This thread from a while back had quite a few good solutions. I would reccomend reading it through.
Old 02-01-2017, 13:25
Travis Schuh Travis Schuh is offline
FRC #0971 (Spartan Robotics)
Travis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant future
We used these latches last year for our first time and had problems with them latching by the end of the season. The bumper had shifted size a little, so it was hard to get the latches over the latching pegs. Also, the little metal pieces got bent and so they didn't stay latched well. Part of what contributed to that was if you put the bumper down on accident with the latches in the closed position, it would bend the metal.
They worked great for the first 2 competitions, it wasn't until the tail of the off-season that we could no longer get the bumpers on or off. Have you seen any of these issues with these latches? Perhaps you were using them in a way that was better for the latches.
Old 02-01-2017, 13:44
bstew's Avatar
Team Role: CAD
Rookie Year: 2015
Originally Posted by Travis Schuh View Post
xWe used these latches last year for our first time and had problems with them latching by the end of the season. The bumper had shifted size a little, so it was hard to get the latches over the latching pegs. Also, the little metal pieces got bent and so they didn't stay latched well. Part of what contributed to that was if you put the bumper down on accident with the latches in the closed position, it would bend the metal.
It looks like we played around half as many matches overall (season and offseason) in 2016, so we probably don't see as much wear as you do. That being said, we build pretty rigid (one piece) bumpers out of bent 1/8 6061 T6 aluminum sheetmetal. They really don't change shape at all during the season. This probably helps the latches avoid some problems.
Could you provide more information on your mounting setup? We mount our latches so that the 1/8 L brackets supports them and should take all horizontal forces. All the latch should be doing is holding the bumper down.
When putting the bumpers on, we always have two people, one for every two latches. We are pretty careful to set them on the peg without bending the latch.
Even with these precautions, we still do experience some wear, but nothing that renders them unusable. Our 2014 bumpers lasted 4 competitions and several years of outreach and we never had to do any maintenance on the bumpers that I know of.
