Go to Post Many people follow that advice, as if Ohio is Mordor or something. - Travis Hoffman [more]
Old Yesterday, 02:51 PM
Kevin Thorp's Avatar
Kevin Thorp Kevin Thorp is offline
AKA: Kevin Thorp
FRC #3489 (Category 5)
Kevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond repute
pic: Quick-Change Motor Drive Module 1
Old Yesterday, 02:52 PM
dradel's Avatar
dradel dradel is offline
FRC #4557 (Full Metal Falcons)
dradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to behold
Re: pic: Quick-Change Motor Drive Module 1
what gear box is that?
Old Yesterday, 03:11 PM
Ari423's Avatar
Ari423 Ari423 is offline
LabVIEW aficionado and robot addict
AKA: The guy with the yellow hat
FRC #5987 (Galaxia)
Ari423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant future
Pretty sure its a worm gearbox from this series from SDP-SI. We used a higher reduction one on our arm last year.
2017-present: Mentor FRC 5987
2017-present: CSA for FIRST in Israel
2012-2016: Member FRC 423
2013: Programmer
2014: Head Programmer, Wiring
2015: Head Programmer, Wiring
2016: Captain, Head Programmer, Wiring, Manipulator, Chassis, CAD, Business, Outreach (basically everything)
Old Yesterday, 09:51 PM
AKA: Kevin Thorp
It's a Nordex GRX-A2-10 (10:1 speed reduction). Link
We've had very good luck using them to drive 6" wheels, but our sister team (342) stripped one or two out driving 12" wheels. I think they used a 20:1 ratio.
Mentor, Team 3489, "Category 5"
Ashley Ridge H.S. & Summerville H.S.
Summerville, SC USA
Old Today, 12:49 AM
ThaddeusMaximus's Avatar
ThaddeusMaximus ThaddeusMaximus is offline
Thaddeus Hughes
FRC #4213 (MetalCow Robotics)
ThaddeusMaximus is a jewel in the roughThaddeusMaximus is a jewel in the roughThaddeusMaximus is a jewel in the rough
What advantage does this yield over VersaPlanetaries?
Edit: I see other pics now. Thought the idea here was swap in different motors.
But why fix your gear ratio?
Formula SAE is now the thing I do. #becauseRacecar
But I'll still be a mentor for like, forever.
Check out what I'm up to: http://ppi.ddns.net/blog
"So, wait, what kind of engineer are you? Mechanical? Electrical? Software?"
"Yeah pretty much."
Old Today, 07:51 AM
AKA: Kevin Thorp
Yes, you have a good point. We already have a number of these worm gearboxes with a 10:1 gear ratio. If that doesn't fit our strategy in 2017 we'll need to add a chain or belt drive to adjust the final drive ratio.
Then our "quick-change drive module" is not so quick to change.
Summerville, SC USA
Old Today, 08:07 AM
AKA: Kevin Thorp
Hmm.. It looks like a few different vendors are selling the same gearbox: Nordex, SPD-SI and Torque Transmission. I wonder which one is the manufacturer?
Summerville, SC USA
Old Today, 08:34 AM
Ari423's Avatar
FRC #5987 (Galaxia)
How are you attaching the shaft to the gearbox? We struggled with that problem when we used them last year and ended up using a 5/8" hollow output and welding in a 5/8" OD to 1/2" ID with 1/8" key adapter so we would have a keyway. In the end this solution didn't work very well because the keyway was oversized which introduced slop into the system. We really didn't want to use the built-in roll pin because we didn't want to machine the pin holes into the shafts and were afraid of them shearing during competition and not being able to replace them. How did you solve this problem?
2013: Programmer
Old Today, 08:53 AM
AKA: Kevin Thorp
We inserted a 5/8" OD shaft then drilled & tapped a couple M4 holes into both the gearbox & shaft, using the existing roll pin hole as a pilot. Then installed a couple M4 screws. This seems to hold up well in competition and doesn't introduce much play.
Nordex said they could manufacture these gearboxes with 1/2" hex hollow shafts if there was enough interest from the FRC community. That would make the wheel shafts super simple!
Summerville, SC USA
Old Today, 08:53 AM
Drivencrazy's Avatar
Drivencrazy Drivencrazy is offline
AKA: Clint Ott
FRC #1011
Drivencrazy has a brilliant futureDrivencrazy has a brilliant futureDrivencrazy has a brilliant futureDrivencrazy has a brilliant futureDrivencrazy has a brilliant futureDrivencrazy has a brilliant futureDrivencrazy has a brilliant futureDrivencrazy has a brilliant futureDrivencrazy has a brilliant futureDrivencrazy has a brilliant futureDrivencrazy has a brilliant future
Just a word of caution: An input torque on the "output" shaft can cause a significant amount of stress in the gearbox casing leading to cracking.
For instance someone pushing you from the front or rear would create a reactionary torque in the wheel. Which would then get transmitted through the gears and into the worm gear shaft which would press against the plastic housing of the gearbox.
We sourced some of these from Torque Trans for the 2011 season and had a similar issue arise several times.
Old Today, 09:18 AM
AKA: Kevin Thorp
Yes, Team 342 had a couple Nordex gearbox failures using 12" wheels. This adds tremendous stress to the gearbox housing during pushing & abrupt stops.
Team 3489 has used them for 3 years, with no failures:
2014: Two worm gearboxes driving four wheels: two 6" Omnis and two 6" HiGrip
2015: Four worm gearboxes driving four 6" Mecanums
2016: Four worm gearboxes driving four 8" pneumatic wheels & six 4" Colsons.
Summerville, SC USA
