Re: GRIP 1.5 is now available!
Can't get it to install in windows 10 x64.
Get message "Error installing Method" then "Failed to launch JVM" Googled, and only found this, not sure what I am doing wrong. http://stackoverflow.com/questions/3...-to-launch-jvm |
It sounds like the same issue I was having. After searching through the issues section of the GitHub page I found that the issue has already been reported and the current solution involves compiling it on your computer. The exact steps I followed can be found near the bottom of this issue.
The issue is that grip is trying to use port 8080 on your network (a port i've found to be rather common among programs I use) and is finding that another program is using it. When this happens, grip crashes and spits out the error that you're getting. Last edited by cad321 : Yesterday at 04:03 PM. |
