Go to Post The weight sounds about right, too. If you need more than 65 pounds for your manipulator, then the drivetrain isn't the part you should be redesigning... - s_forbes [more]
Unread 21-12-2016, 10:50
tr6scott's Avatar
tr6scott tr6scott is offline
Um, I smell Motor!
AKA: Scott McBride
FRC #2137 (TORC)
tr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond repute
Re: Steampunk wiring - wiring color
https://www.chiefdelphi.com/forums/s...d.php?t=109855
FIRST and the inspectors, are pretty set on the rules.
A couple of years ago, we wired our dc motor power with black wire with yellow tracers, and the inspectors at Waterford made us cover the yellow tracer with black tape during inspection.
I work in industrial controls, we are panel build shop, and I have access to a bunch of wire, that is donated to the team, so I like to use tracer colors to segregate function and amperage loads, but after that, we stick with red and black.
Don't poke the bear.
The sooner we get behind schedule, the more time we have to catch up.
Unread 21-12-2016, 11:31
Team34Guy's Avatar
Team34Guy Team34Guy is offline
Controls/Programming Mentor
AKA: Chris Southard
FRC #0034 (Rockets Team 34)
Team34Guy is a jewel in the roughTeam34Guy is a jewel in the roughTeam34Guy is a jewel in the rough
Originally Posted by Ed Sparks View Post
Please don't make an already difficult job unbearable ........ Color coding is there for a reason and you shouldn't poke bears with a sharp stick.
I wondered when you would weigh in on this.
After our own wiring snafu last season... I, for one, am not going to risk poking bears with sticks this year
Turbo Encabulator Installation and Repair
Unread 21-12-2016, 12:04
tjf's Avatar
tjf tjf is offline
FIRST Year, Best Year
AKA: Tim Flynn
FRC #1257 (Parallel Universe)
Rookie Year: 2016
tjf is a splendid one to beholdtjf is a splendid one to beholdtjf is a splendid one to beholdtjf is a splendid one to beholdtjf is a splendid one to beholdtjf is a splendid one to beholdtjf is a splendid one to behold
As said by others, it's probably best to not poke the bear. Sleeving would likely be your safest bet.
However, it's an odd thing to note that FRC doesn't always follow standards to the letter. Battery connectors (Anderson SB50s) are traditionally red for 24V and yellow for 12V. FRC teams use red on everything (on every robot I've ever seen, with the exception of grey for pneumatics.)
1257 (2016) - Student
1257 (2017) - Business Mentor (up in your business!)
KD2KRT
Unread 21-12-2016, 13:15
Foster Foster is offline
Engineering Program Management
VRC #8081 (STEMRobotics)
Foster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond repute
I didn't know there is a "standard", thanks.
Yellow - 12v
Orange - 18v
Red - 24v
Gray - 36v
Blue - 48v
Green - 72v
Black - 80v
Brown - 96v
Purple - 120v
White - 144v
Foster - VEX Delaware - 17 teams -- Chief Roboteer STEMRobotics.org
2010 - Mentor of the Year - VEX Clean Sweep World Championship
2006-2016, a decade of doing VEX, time really flies while having fun
Downingtown Area Robotics Web site and VEXMen Team Site come see what we can do for you.
Unread 21-12-2016, 13:40
Logan Byers Logan Byers is offline
Roaming Mentor & Referee
no team (Team Indiana)
Logan Byers has much to be proud ofLogan Byers has much to be proud ofLogan Byers has much to be proud ofLogan Byers has much to be proud ofLogan Byers has much to be proud ofLogan Byers has much to be proud ofLogan Byers has much to be proud ofLogan Byers has much to be proud ofLogan Byers has much to be proud of
Yellow - 12v
Orange - 18v
Red - 24v
Gray - 36v
Blue - 48v
Green - 72v
Black - 80v
Brown - 96v
Purple - 120v
White - 144v
Note: Those colors are for the Anderson connectors specifically, not the wire colors (which is the OP's focus). As far as I remember, I've never seen a rule dictating specific connector coloring for FIRST robots.
As for following standards:
Last edited by Logan Byers : 21-12-2016 at 13:41. Reason: XKCD Standards Inclusion
Unread 21-12-2016, 13:59
Billfred's Avatar
Billfred Billfred is offline
No rule, but SB-50 connectors are keyed by color. So a purple one wouldn't fit a red one. (Pink is an exception, presumably so donated connectors are obvious.)
Unread 21-12-2016, 14:01
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
The SB50 data sheet notes that black and grey housings have matching keys; other colors will not cross mate. If you use anything other than red (or pink, which is a special connector with the same keying as red) they will not mate with batteries or connectors of other teams, or standard chargers. They are not illegal as far as I have read, but I would strongly discourage using anything but red or pink SB50s.
Unread 02-01-2017, 22:09
snorthey snorthey is offline
snorthey is an unknown quantity at this point
What if you spray painted a wiring wrap... not the wiring... like the cord keeper... and other devices like the zip ties...
Unread 02-01-2017, 23:15
GeeTwo's Avatar
Technical Director
AKA: Gus Michel II
Sorry, but not at all secific enough. Why, and what colors would you spray over other colors?
And then, remember the whole point of color coding - so that people KNOW what voltage/polarity/signal the wire is carrying. If your spray paint obscures or miselads people as to what is going on, my advice is DON'T DO IT, even if it is legal under the letter of the game manual.
Unread Yesterday, 09:12
IKE's Avatar
IKE IKE is offline
Not so Custom User Title
AKA: Isaac Rife
no team (N/A)
This might be going a bit too cautious. Any color of loom applied makes it difficult to do a wire trace, but have not generally been illegal. Often those get kudos for such a neat wiring job. I suspect that loom/wrap will continue to not be illegal.
A couple of words of caution:
If you paint the loom, make sure you find a flexible enough paint. Otherwise it will tend to chip and flake. I have seen this a lot on harnesses outside of robotics. While it looks cool initially, the flaking of paint can make it look trashy later on.
Use wire labels or indicators to help trace your wires if you are using wiring loom. This can also help if you make a wiring diagram which will get you browny points towards things like Quality award.
Unread Yesterday, 10:58
pmangels17's Avatar
pmangels17 pmangels17 is offline
Mechanical Marauders - Alumnus
AKA: Paul Mangels
FRC #0271 (Mechanical Marauders)
pmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond repute
Before you go through all sorts of fun coloring and sheathing (which can be perfectly acceptable and often really nice looking), make sure to ask yourself:
Are the aesthetic changes I am about to make going to impact the functional performance or maintainability of the robot?
All the strange colored wires might be fun and all, and the paint could be wonderful, but I'm willing to wager a corndog that there are reasons other than the rules themselves that the Cheesy Poofs paint everything on their robot except the wires. (And electronics, etc)
Junior at the University of Notre Dame, Mechanical Engineering
Got questions (about Notre Dame, robots, college, etc), don't hesitate to ask.
**Bang Boom Pop!** "Was that the robot?" "I don't know, do it again"
**BANG BOOM POP** "Oh, now it's on fire."
