Go to Post Don't fix mechanical problems with software, ever. - Chris is me [more]
Old 28-12-2016, 21:13
Skyehawk's Avatar
Skyehawk Skyehawk is offline
Nuts N' Bolts
AKA: Skye Leake
FRC #0876 (Thunder Robotics)
Skyehawk is a name known to allSkyehawk is a name known to allSkyehawk is a name known to allSkyehawk is a name known to allSkyehawk is a name known to allSkyehawk is a name known to all
Vision co-processor Raspberry Pi (Raspbian Jessie/OpenCV)
Hello all,
Machine vision routinely finds it's way into every few programming threads. FIRST has yet to give us a task that cannot be solved with the basic control system, but speed is almost always better in vision system, which can become an intensive process. A co-processor is a good way to offload some vision related tasks. The Raspberry pi 3 is readily available and low cost; a good entry level co-processor.
Open-CV is almost a necessity in machine vision, and can sometimes be an issue to get up and running (despite taking a few hours to build and install). I have a image of Raspbian Jessie with Open-CV installed that I am willing to share. I think there may be some licensing issues with my posting a download link, but PM me and I'll get you set up with the image and some documentation. I am not overly knowledgeable on the install process, so I will not be a huge help if issues arise, but the community is a great resource. The image is a bare bones Open-CV install built to run with python 2/3, no vision code or Pi/robot-Rio interface code is included.
Regards,
Skye Leake
My time in FIRST has made me a better person, frankly I don't know where I'd be without it.
2011 Lake Superior Regional Champs
2015 Central Illinois Regional Engineering Inspiration Award recipients
2016 Central Illinois Regional Champs
Old 29-12-2016, 18:01
SamCarlberg's Avatar
SamCarlberg SamCarlberg is offline
GRIP, WPILib. 2084 alum
AKA: Sam Carlberg
SamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to behold
Re: Vision co-processor Raspberry Pi (Raspbian Jessie/OpenCV)
Take a look here for some samples. I've built OpenCV python bindings for the pi 3, and there's some examples for python code to get people started.
WPILib
GRIP, RobotBuilder
Old 29-12-2016, 22:51
SamcFuchs's Avatar
SamcFuchs SamcFuchs is offline
Programmer
AKA: Sam Fuchs
FRC #0236 (TechnoTicks)
SamcFuchs will become famous soon enoughSamcFuchs will become famous soon enough
In case you don't want to use an image, here's a script that automatically sets up an opencv python development environment on a raspberry pi.
Sam Fuchs
236 TechnoTicks, Old Lyme, CT
2015 - Programming, Electrical
2016 - Lead Programmer, Co-Driver
2017 - Lead Programmer, Co-Driver
Old 30-12-2016, 05:03
Michael Hill's Avatar
If anyone has figured out how to utilize the H.264 hardware decoder on the Pi with OpenCV without virtual hardware, that would be awesome. I have a C920 camera, which has H.264 compressed output (which is why you pay so much for it). Just changing the fourcc capture property doesn't seem to do the business. I have heard of setting up a gstreamer pipeline (which does use to hardware decoder) and setting the sink to /dev/video1 can work, but I'd like a cleaner solution.
Old 30-12-2016, 13:27
euhlmann's Avatar
euhlmann euhlmann is offline
CTO, Programmer
AKA: Erik Uhlmann
FRC #2877 (LigerBots)
Rookie Year: 2015
euhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud of
Have you considered using libavcodec/libavformat?
Creator of SmartDashboard.js, an extensible nodejs/webkit replacement for SmartDashboard
https://ligerbots.org
Old 30-12-2016, 15:21
Hm, I hadn't heard of that. I'll see if I can get something to work with it. Thanks
Old 30-12-2016, 17:38
BenBernard BenBernard is offline
FRC #5687 (The Outliers)
Rookie Year: 2015
BenBernard is an unknown quantity at this point
@Skyehawk, does your image include the java artifacts for OpenCV?
Old 30-12-2016, 17:56
Skyehawk's Avatar
Nuts N' Bolts
AKA: Skye Leake
No, it is very barebones. However the build files for OpenCV have not been purged so it can be rebuilt and reinstalled. But if you are going to go through all that trouble you may as well work from scratch...
Sorry I couldn't be more help,
Skye Leake
Old 30-12-2016, 22:51
Rookie Year: 2015
No problem, and thanks. I have a build almost complete...and once I'm sure it's working properly I'll image it too--for the Java addicts among us.
Old Yesterday, 08:40
Rookie Year: 2015
FYI, I was finally able to get OpenCV fully built with Java 8 bindings and installed on a Pi 3 running Jessie.
I'll try to find a way to share an image (my card is 32GB, so a full image would be prohibitive) but in the meantime, here are the "Installing OpenCV 3.1.0 on Raspberry Pi Debian Jessy with Java Library" instructions I followed from Robin Henniges.
I also compared notes along the way with Adrian Rosebrock's excellent "Raspberry Pi 3 + Raspbian Jessie + OpenCV 3" instructions.
Following the two together should allow you to build an OpenCV build with Java and Python bindings, but my image will only have Java.
Full credit and thanks to both bloggers for their work and diligent documentation!
