Re: Connector on Andymark Hall Effect Sensor
That's not what I want.
I want to not solder. I have breakout boards so I'd rather solder to that, but if I can find an IDC connector then I can just snap in a cable and be good |
My team was in the progress of putting together a drivetrain using the Andymark swerve modules (am-3009) and were faced with the same problem, as the modules use hall effect sensors on the steering motors. We wanted to connect them directly to the TalonSRX's just as you do, and we ended up just using breakout boards; I'm guessing we could not find any of the cables you are looking for.
if you get the above noted cable cut the power pole connectors off and solder to breakout board you would be done
