Go to Post And just remember, it's an engineer's world. Without us, everyone is powerless, literally. - JoeXIII'007 [more]
  #31   Spotlight this post!
Unread 03-01-2017, 13:12
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Re: WCP: 2017 Product Launch + MCC 2017
Originally Posted by Monochron View Post
Could you explain how a preload prevents ratcheting? Is a preload just applying some small torque on the pulley shaft?
preload=tension on the belt when system is at rest.
2001-2004: Team 100
2006-Present: Team 254
  #32   Spotlight this post!
Unread 03-01-2017, 13:56
Travis Covington's Avatar Unsung FIRST Hero
Travis Covington Travis Covington is offline
Engineering Mentor
FRC #0254
Travis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond repute
Send a message via AIM to Travis Covington
Originally Posted by R.C. View Post
Nailed it!
Ours are slightly different and include a counterbore to accept a portion of the shoulder bolts shoulder to eliminate the shear/bending force on the threads themselves (where the cross section is smaller and there is an inherent stress concentration in the thread itself). This means the thread/screw is primarily resisting the axial load and does not have to withstand the full shearing force of external loads.
I should note that all of these additions are awesome and we have already ordered a handful of the new stuff to evaluate and likely use this season. Awesome work to RC and all the WCP folks. It's good stuff!
-Travis Covington
2008-2017 - Engineering Mentor of Team 254
2001-2008 - Engineering Mentor of Team 968
1998-2001 - Mechanical Director/Driver/Member of Team 115
  #33   Spotlight this post!
Unread 03-01-2017, 16:45
HD's Avatar
HD HD is offline
AKA: Harrison Drake
HD is a splendid one to beholdHD is a splendid one to beholdHD is a splendid one to beholdHD is a splendid one to beholdHD is a splendid one to beholdHD is a splendid one to beholdHD is a splendid one to behold
Originally Posted by nuclearnerd View Post
I have heard that GT2 belts are built stronger than HTD belts (especially in Gates Carbon), but can you confirm? Are 9mm wide GT2 belts capable of carrying drivetrain loads, when we've only been able to use 15mm HTD belts safely before? If so, could this be a path for West Coast chasses with fixed axles / no tensioners?
5mm GT2 are marginally stronger than 5mm HTD, but note that these sprockets are 3mm GT2. They will not be suitable for drivetrain loads.
9mm wide GT2 (5mm) is VERY borderline for an FRC drivetrain, as it's only rated to around .8 HP at typical WCD high gear wheel rpms (1000+rpm)(with common 24T pulleys). 2 CIM gearbox can output peak ~.9HP. You would need to step up to at least 26T pulleys to meet this requirement with 9mm belts.
  #34   Spotlight this post!
Unread 03-01-2017, 16:48
AdamHeard's Avatar
Lead Mentor
I don't think anyone is recommending the 3mm GT2 for primary drive train loads (they are however final for initial reduction in drives).
We've used them a good deal on intakes, shooters, initial drive reductions, etc... with great success.
  #35   Spotlight this post!
Unread 03-01-2017, 18:16
HD's Avatar
HD HD is offline
AKA: Harrison Drake
The post I quoted and the other follow up reply seemed to pretty specifically be asking about HTD vs. GT2 vs. GT3 in in a tradional WCD style application. Wasn't sure they realized these are 3mm.
  #36   Spotlight this post!
Unread 03-01-2017, 18:33
mman1506's Avatar
mman1506 mman1506 is offline
Focusing on Combat Robots!
AKA: Marcus Quintilian
no team (WARP7)
I know I say this every year but now with even more of your own products you should really consider stocking them in the VEX Ontario warehouse. Shipping times are obviously crucial in FRC and I think the high density of "high performance" teams in Ontario would be well suited to your products. I can recall a couple of times were a product offered by WCP would of been a better solution but we chose something else due to convenience.
2016: FRC 865 Mentor
2017: Free Agent Mentor, Ref, Inspector
  #37   Spotlight this post!
Unread 03-01-2017, 20:22
cad321 cad321 is offline
Jack of all trades, Master of none
AKA: Brian Wagg
FRC #2386 (Trojans)
cad321 is just really nicecad321 is just really nicecad321 is just really nicecad321 is just really nice
In addition to expidited shipping times, it would help reduce costs aswell. I'm not sure if it's just a glitch right now, but when I went to buy a few of the polycord rollers and a few feet (I assume it's sold by the foot at $0.75) of poly cord, the shipping came out to $140us to ship economy to ontario .
  #38   Spotlight this post!
Unread 03-01-2017, 20:34
Tsukunea's Avatar
Tsukunea Tsukunea is offline
Lead Designer, Drive Coach
AKA: Boone Shangle
FRC #6065 (Titanium Dragons)
Team Role: CAD
Rookie Year: 2016
Tsukunea is on a distinguished road
I always re-assemble the gearboxes we look into buying in Solidworks, and that includes the new flipped DS. Was wondering though why there is a 44t gear with a 1/2 hex bore on a 3/8" shaft (See attached screenshot)?
B. Shangle
Lead Designer & Recruiter, Drive Coach of FRC Team 6065 "Titanium Dragons"
Kenowa Hills/Feyen Zylstra
Minister of Publications of Kenowa Hills Applied Technology & Design
"New Ideas for the World"
  #39   Spotlight this post!
Unread 03-01-2017, 20:47
R.C.'s Avatar
R.C. R.C. is online now
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
Let me check on the polycord issue.
R.C.
MadTown Robotics Team 1323
  #40   Spotlight this post!
Unread 03-01-2017, 20:48
R.C.'s Avatar
That guy gets an adapter. Currently there isn't a 44t 3/8 hex gear. There will be one soon
R.C.
  #41   Spotlight this post!
Unread 03-01-2017, 20:50
Cothron Theiss's Avatar
Cothron Theiss Cothron Theiss is offline
Deleted because apparently I can't read.
  #42   Spotlight this post!
Unread 03-01-2017, 21:04
R.C.'s Avatar
Try that now, it should work. Thanks for pointing that out.
R.C.
  #43   Spotlight this post!
Unread 04-01-2017, 00:59
Tangert's Avatar
Tangert Tangert is offline
FRC #4467 (Titanium Titans)
Tangert is an unknown quantity at this point
R.C. Is there an encoder mount on the 2 Cim Flipped gearbox?
  #44   Spotlight this post!
Unread 04-01-2017, 01:03
R.C.'s Avatar
Tangert,
We recommend shoving a shaft based encoder into the back of the output shaft:
https://puu.sh/taxeL/234e7a2eca.png
We will have a manual showing how to mount:
-WCP Dual Output Encoder
-CTRE Mag Encoder
We will also include a 3d print file for anyone who wants a mount. I should have the manual up and ready by Thursday/Friday. Working on getting the roller examples and stuff up now.
Thanks!
R.C.
  #45   Spotlight this post!
Unread 04-01-2017, 01:09
Tangert's Avatar
Thanks,. Good job on these new products.
