Spike Relay Replacement
Does anyone know of a legal Spike Relay replacement device?
I understand the PCM module output, but looking for a "controllable voltage" output for this season..... |
Re: Spike Relay Replacement
http://www.ctr-electronics.com/gadge...er-module.html Plus this: http://www.ctr-electronics.com/breakoutmodule.html And you'll need a cable between them and you still need to connect it to the RoboRIO's outputs with .1" cables. You could also connect it to CAN via a HERO board: http://www.ctr-electronics.com/hro.html |
Ask again on Saturday when the rules are posted!
Until then, this would fall under the 2016 R52: Quote:
I would STRONGLY expect similar rules this year. Look for them! |
For driving motors and other actuators, the list is pretty short; the spike is the only relay module available with enough current for the PGs and automotive motors. (OK, the compressor port on the PCM could do it, but I doubt the rules will allow it.)
For driving lights or other custom circuits, (provided the rules are much like recent years) you can use just about any suitably rated mechanical or solid state relay as long as it doesn't violate another rule somewhere. Google "12V relay module" and you can find dozens of inexpensive options for custom circuits. |
Could the PCM be used to control this servo? I used to mentor up until 2013 when the Spike H-Bridge Relay were still available, so I'm a bit lost as to the replacements for these.
That servo would connect to a PWM output and an analog input (for the pot sensor) |
#7
I'm not sure I understand the question, but the roboRIO MXP port provides 2 0-5V analog outputs. Analog output 0 (AO0) is on pin 2 and analog output 1 (AO1) is on pin 4. I've never tried to use them, so YMMV.
