Go to Post To offer an opinion is fine, to demand that others adhere to your opinion is laughable. - JVN [more]
Unread 04-01-2017, 15:21
YairZiv's Avatar
YairZiv YairZiv is offline
FRC #5951 (Makers Assemble)
Rookie Year: 2016
YairZiv is an unknown quantity at this point
Driving Straight
Hey, so as we get close to the season, there's one thing we wanna understand how to do. We wanna understand how to drive straight using autonomous period. Using a PIDController for distance will not work since the two sides of the chassis may drive in a different speed. Using a PIDController for speed might work a little better though it will be hard to land in the distance we tried to go to. So how do we go into doing something like that?
Good luck in the season everybody!
Unread 04-01-2017, 15:28
Poseidon5817's Avatar
Poseidon5817 Poseidon5817 is online now
Founder and CEO, DeadMemes Studios
AKA: Mitchel Stokes
FRC #5817 (Uni-Rex)
Poseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud of
Re: Driving Straight
If you have a gyro, you can run a PID on the angle so that if it turns one way or the other, it will increase/decrease the outputs on the sides to help it turn back.
My FRC History:
2014 - Team 1671: Central Valley Regional Finalist and Chairman's Award Winner, Sacramento Regional Finalist, Archimedes Quarterfinalist
2015 - Team 1671: Central Valley Regional Semifinalist, Sacramento Regional Semifinalist and Chairman's Award Winner, Newton Winner, Einstein Winner
2016 - Team 5817: Central Valley Regional Finalist and Rookie All-Star, Orange County Regional Quarterfinalist and Rookie All-Star, Newton Division
2017 - Team 5817: Return of the bench grinder
AustinShalit's Avatar
AustinShalit AustinShalit is offline
AKA: אוסטין
no team (WPILib Suite Developer)
AustinShalit is a glorious beacon of lightAustinShalit is a glorious beacon of lightAustinShalit is a glorious beacon of lightAustinShalit is a glorious beacon of lightAustinShalit is a glorious beacon of lightAustinShalit is a glorious beacon of light
When WPILib 2017 is released, take a look at the gyro example. It is a sample program to demonstrate how to use a gyro sensor to make a robot drive straight. The program uses a joystick to drive forwards and backwards while the gyro is used for direction keeping. You can replace the joystick in the example with the output from a PIDController to drive straight for a certain distance.
You can get to the Gyro example by:
File -> New -> Other -> WPILib Robot Java Development -> Example Robot Java Project -> Gyro
Unread 04-01-2017, 19:08
BenBernard BenBernard is offline
FRC #5687 (The Outliers)
Rookie Year: 2015
BenBernard is on a distinguished road
If you simply can't wait that long, feel free to look at our AutoDrive command, which locks onto the current heading (yaw) from our navX when it starts and uses PID to maintain that heading as it drives. The same approach could be used for any gyro.
Unread 04-01-2017, 20:48
mikets's Avatar
mikets mikets is offline
Software Engineer
FRC #0492 (Titan Robotics)
mikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of light
You can also look at our library in which you will find a PidDrive class that provides a method named "setTarget". It allows you to set the target distances in X or the Y direction. It also let you specified the "heading" you want to maintain relative to current heading. Don't worry about it being a FTC project. Our library is shared between FTC and FRC, so the TrcLib portion of the library is platform independent. So it would be identical code between FTC and FRC.
https://github.com/trc492/FtcSamples...cPidDrive.java
