Go to Post Seriously, I figured we had until january before we started lawyering things again. - JamesBrown [more]
Unread 04-01-2017, 03:46
cad321 cad321 is offline
Jack of all trades, Master of none
AKA: Brian Wagg
FRC #2386 (Trojans)
cad321 is just really nicecad321 is just really nicecad321 is just really nicecad321 is just really nice
GRIP code gen on RPI3
I have been trying to get OpenCV setup on my RPI3 while following the steps outlined in the readme on github. I am able to install numpy and pynetworktables with no problems at all. However when I try to install OpenCV with the line
sudo pip3 install opencv-python
I am told, "No distributions found at all for opencv-python".
I am running Jessie Lite and made sure to install Python 3.4 aswell. Has anyone else run into this issue or see where it is I'm going wrong? Note that my experience with the RPI in general is limited, so if I haven't found it in the GRIP ReadMe's, I probably haven't done it.
Unread 04-01-2017, 07:37
BenBernard BenBernard is offline
FRC #5687 (The Outliers)
Rookie Year: 2015
BenBernard is an unknown quantity at this point
Re: GRIP code gen on RPI3
It looks like you need to skip ahead to the "Binaries" section of that readme.
If that doesn't work, try to more in-dpeth approach described in the articles I link here. It will take much longer, but I the python one does work.
Edit: Note that I have not tried either of these with Jessie Light.
Unread 04-01-2017, 19:25
jojoguy10's Avatar
jojoguy10 jojoguy10 is offline
Programming/Controls Mentor
AKA: Joe Kelly
FRC #0997 (Spartan Robotics) and FRC #2990 (Hotwire Robotics)
jojoguy10 is a glorious beacon of lightjojoguy10 is a glorious beacon of lightjojoguy10 is a glorious beacon of lightjojoguy10 is a glorious beacon of lightjojoguy10 is a glorious beacon of light
I got the same error. I just used the instructions posted by Adrian over at PyImageSearch: http://www.pyimagesearch.com/2016/04...ssie-opencv-3/. Worked perfectly.
Unread 04-01-2017, 19:36
SamCarlberg's Avatar
SamCarlberg SamCarlberg is offline
GRIP, WPILib. 2084 alum
AKA: Sam Carlberg
SamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to behold
PyPi doesn't support binaries for the raspberry pi (or maybe even ARM at all).
I've built OpenCV python bindings for the pi 3 available here under the 'python' directory. (This will not work for other raspberry pi's -- only the 3!)
Just follow the instructions in the 'Binaries' section of the README
WPILib
GRIP, RobotBuilder
Unread 05-01-2017, 21:36
nardavin nardavin is online now
FRC #2403 (Plasma Robotics)
nardavin is on a distinguished road
This does not work for me. When I call the command, nothing appears to happen. It just goes to the next line in the terminal.
Team 2403: Plasma Robotics
Member 2014-2017, Head Programmer 2015-2016, Leadership Team 2016-2017, Co-President 2017
Unread 05-01-2017, 21:46
AKA: Sam Carlberg
Which command did you run?
WPILib
GRIP, RobotBuilder
Unread 05-01-2017, 22:04
python3 -m wheel install opencv_python_rpi3-3.1.0+39f5a48-cp34-cp34m-linux_armv7l.whl
Unread 07-01-2017, 01:48
AKA: Brian Wagg
FRC #2386 (Trojans)
Ok. So upon trying to run the wheel command using the following:
sudo python3 -m wheel install ~/GRIP-code-generation/python/libs/opencv_python_rpi3-3.1.0+39f5a48-cp34-cp34m-linux_armv7l.whl
I receive the following error:
Traceback (most recent call last):
  File "/usr/lib/python3.4/runpy.py", line 170, in _run_module_as_main
    "__main__", mod_spec)
  File "/usr/lib/python3.4/runpy.py", line 85, in _run_code
    exec(code, run_globals)
  File "/usr/local/lib/python3.4/dist-packages/wheel/__main__.py", line 17, in <module>
    sys.exit(main())
  File "/usr/local/lib/python3.4/dist-packages/wheel/__main__.py", line 14, in main
    sys.exit(wheel.tool.main())
  File "/usr/local/lib/python3.4/dist-packages/wheel/tool/__init__.py", line 356, in main
    args.func(args)
  File "/usr/local/lib/python3.4/dist-packages/wheel/tool/__init__.py", line 299, in install_f
    args.wheel_dirs, args.force, args.list_files)
  File "/usr/local/lib/python3.4/dist-packages/wheel/tool/__init__.py", line 221, in install
    wf.install(force=force)
  File "/usr/local/lib/python3.4/dist-packages/wheel/install.py", line 326, in install
    raise ValueError("Wheel file {0} would overwrite {1}. Use force if this is intended".format(k, dest))
ValueError: Wheel file opencv_python_rpi3-3.1.0+39f5a48.dist-info/metadata.json would overwrite /usr/local/lib/python3.4/dist-packages/opencv_python_rpi3-3.1.0+39f5a48.dist-info/metadata.json. Use force if this is intended
I am running Jessie Lite on an RPI3. The only things I have done on the Pi (in said order) are:
sudo Apt-get install python3
sudo Apt-get install python3-pip
sudo Pip3 install wheel
sudo Apt-get install git
sudo Git clone https://github.com/WPIRoboticsProjects/GRIP-code-generation.git
Any suggestions?
