Go to Post I don't remember ever having "attack of the jumbo ball" in FRC! - Beth Sweet [more]
Unread 04-01-2017, 19:36
SamCarlberg's Avatar
SamCarlberg SamCarlberg is offline
GRIP, WPILib. 2084 alum
AKA: Sam Carlberg
SamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to behold
Re: GRIP code gen on RPI3
PyPi doesn't support binaries for the raspberry pi (or maybe even ARM at all).
I've built OpenCV python bindings for the pi 3 available here under the 'python' directory. (This will not work for other raspberry pi's -- only the 3!)
Just follow the instructions in the 'Binaries' section of the README
WPILib
GRIP, RobotBuilder
Unread 05-01-2017, 21:36
nardavin nardavin is offline
FRC #2403 (Plasma Robotics)
nardavin is on a distinguished road
This does not work for me. When I call the command, nothing appears to happen. It just goes to the next line in the terminal.
Team 2403: Plasma Robotics
Member 2014-2017, Head Programmer 2015-2016, Leadership Team 2016-2017, Co-President 2017
Unread 05-01-2017, 21:46
AKA: Sam Carlberg
Which command did you run?
WPILib
GRIP, RobotBuilder
Unread 05-01-2017, 22:04
python3 -m wheel install opencv_python_rpi3-3.1.0+39f5a48-cp34-cp34m-linux_armv7l.whl
Unread 07-01-2017, 01:48
cad321 cad321 is offline
Jack of all trades, Master of none
AKA: Brian Wagg
FRC #2386 (Trojans)
cad321 is just really nicecad321 is just really nicecad321 is just really nicecad321 is just really nice
Ok. So upon trying to run the wheel command using the following:
sudo python3 -m wheel install ~/GRIP-code-generation/python/libs/opencv_python_rpi3-3.1.0+39f5a48-cp34-cp34m-linux_armv7l.whl
I receive the following error:
Traceback (most recent call last):
  File "/usr/lib/python3.4/runpy.py", line 170, in _run_module_as_main
    "__main__", mod_spec)
  File "/usr/lib/python3.4/runpy.py", line 85, in _run_code
    exec(code, run_globals)
  File "/usr/local/lib/python3.4/dist-packages/wheel/__main__.py", line 17, in <module>
    sys.exit(main())
  File "/usr/local/lib/python3.4/dist-packages/wheel/__main__.py", line 14, in main
    sys.exit(wheel.tool.main())
  File "/usr/local/lib/python3.4/dist-packages/wheel/tool/__init__.py", line 356, in main
    args.func(args)
  File "/usr/local/lib/python3.4/dist-packages/wheel/tool/__init__.py", line 299, in install_f
    args.wheel_dirs, args.force, args.list_files)
  File "/usr/local/lib/python3.4/dist-packages/wheel/tool/__init__.py", line 221, in install
    wf.install(force=force)
  File "/usr/local/lib/python3.4/dist-packages/wheel/install.py", line 326, in install
    raise ValueError("Wheel file {0} would overwrite {1}. Use force if this is intended".format(k, dest))
ValueError: Wheel file opencv_python_rpi3-3.1.0+39f5a48.dist-info/metadata.json would overwrite /usr/local/lib/python3.4/dist-packages/opencv_python_rpi3-3.1.0+39f5a48.dist-info/metadata.json. Use force if this is intended
I am running Jessie Lite on an RPI3. The only things I have done on the Pi (in said order) are:
sudo Apt-get install python3
sudo Apt-get install python3-pip
sudo Pip3 install wheel
sudo Apt-get install git
sudo Git clone https://github.com/WPIRoboticsProjects/GRIP-code-generation.git
Any suggestions?
