Go to Post That makes it a winning move to, well, win. - EricH [more]
Unread 04-01-2017, 21:27
Michael 4499 Michael 4499 is offline
FRC #4499 (The Highlanders)
Michael 4499 is on a distinguished road
pic: Team 4499's off season gearbox
EDIT: It will go 16ft/s not ft/min and this is with a 6" wheel.
Unread 04-01-2017, 21:28
Owen Busler's Avatar
Owen Busler Owen Busler is offline
Build Captain
FRC #0303 (Test Team)
Owen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant future
Re: pic: Team 4499's off season gearbox
16 ft/min? Did you mean 16 ft/sec? If so with what wheel size?
2016: Deans List Semi-Finalist/MAR Mount Olive District Engineering Inspiration Award/Buckeye Regional Second Alliance Captain/MAR Montgomery District Event Imagery Award/MAR Championship Gracious Professionalism Award
2015: MAR Mount Olive District Chairman's Award/MAR North Brunswick District Winners/MAR Championship Finalists
2014: MAR Clifton District Chairman's Award/MAR Championship Regional Chairman's Award
Unread 04-01-2017, 21:45
TheBoulderite's Avatar
TheBoulderite TheBoulderite is offline
Director of Communications
AKA: Warren Bartlett
FRC #1619 (Up-A-Creek Robotics)
Rookie Year: 2015
TheBoulderite has a reputation beyond reputeTheBoulderite has a reputation beyond reputeTheBoulderite has a reputation beyond reputeTheBoulderite has a reputation beyond reputeTheBoulderite has a reputation beyond reputeTheBoulderite has a reputation beyond reputeTheBoulderite has a reputation beyond reputeTheBoulderite has a reputation beyond reputeTheBoulderite has a reputation beyond reputeTheBoulderite has a reputation beyond reputeTheBoulderite has a reputation beyond repute
Wow! That's awesome! Good luck this season, guys!
2015-now: 1619 (Up-A-Creek Robotics)
???: 2017 Utah Regional, ???: 2017 Colorado Regional
Thanks to all of our alliance partners over the years!
(1583, 1667, 937, 1332, 1158, 1348, 2543, 2261, 1777, 2240, 2036, 3648, 1410, 3200, 3807, 4550, 399, 2594, 1987, 4153, 624, 4334, 1730, 4593, 3618, 3026, 967, 4499, 3009, 1011, 525, 4028, 3352)
Unread 04-01-2017, 21:58
Yes, I messed that up and it is with a 6" wheel.
2016 Galileo & Carson - Gracious Professionalism
2016 Colorado - Chairman's award, Finalists
2016 Arizona North - Engineering Inspiration
Unread 05-01-2017, 00:26
ns3517's Avatar
ns3517 ns3517 is online now
FRC #0316 (Lunatecs)
ns3517 will become famous soon enough
Very nice, this gearbox looks like a solid build. Hope to see it on a robot sometime.
Unread 05-01-2017, 00:57
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Can you explain a little more about what is going on with that top shaft? Why do you have it passing through three bearings? I feel like that is inviting the potential for both misalignment and over constraint. The shaft is short enough that hopefully it wouldn't be a real detriment, but it's also not very useful.
It's hard to see, but does the bottom shaft also have the same issue?
Finally, you may want to consider countersinking those exterior bolt heads in order to allow you to place your wheel slightly closer to your drive rail.
Unread 05-01-2017, 10:52
Chris is me's Avatar
AKA: Pinecone
I would remove the middle bearing for the top shaft. It basically doesn't add any support and just lowers efficiency / causes potential misalignment for no real benefit. Otherwise, seems good.
Unread 05-01-2017, 12:03
The top shaft was an interesting one to constrain. Currently, the reasoning for the middle constraint is because there is an e-clip on the other side of the bearing. This is because we are planning on mounting an encoder on the other end of the shaft. If you have any other ways to eliminate that middle support we are welcome to new ideas.
The bottom shaft is actually 2 separate shafts where one ends in the plate just before the tube and the other one starts in the plate inside the tube.
I completely agree with your last suggestion, we are working on it.
Thanks for the response!
Unread 05-01-2017, 12:12
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Do I correctly understand that you are transmitting torque through an e-clip groove? If so, that's going to be a weak spot in your drive train. Putting an e-clip between the load-bearing gears and the future encoder should be OK, and between the gears and the end bearings would not be as good as the outside, but much better than between the gears transmitting torque to/from the shaft.
Unread 05-01-2017, 12:24
AKA: Pinecone
Putting an E-clip between loads on a shaft is often a dangerous idea. It weakens the shaft substantially when something like a spacer could do the same job. I would just use a spacer between the two gears (that goes through where the bearing is currently located) and then put your encoder on one of the outer ends of that shaft.
Unread 05-01-2017, 12:56
Ty Tremblay's Avatar
Robotics Engineer
FRC #0319 (Big Bad Bob)
I personally think 16ft/s single speed with 4-cims on 6" wheels is a bit fast. If you find that out too, are you able to increase your final reduction? VEXpro's 82-tooth gear spacing is nice since it allows for a lot of various reductions with the gears they have in stock.
Unread 05-01-2017, 12:59
Great idea, I think I can see a few changes that we can make to the gearbox to incorporate this.
Thanks for the suggestion, we will look into implementing it.
Unread 05-01-2017, 13:05
Yes, we are able to make our own gears and change them out, we are using a 72 tooth spacing. We were just planning on making a fast drive base while learning the basics of gearbox manufacturing.
