Go to Post ...we are all winners when people come out of this program and strive to make the world a better place. - Patrick Wang [more]
Old 01-01-2017, 18:17
fast OPR computation with R using sparse matrix technology
Thread created for discussion of this paper.
Old 01-01-2017, 19:27
brennonbrimhall brennonbrimhall is offline
Free Agent
AKA: Brennon Brimhall
brennonbrimhall is a name known to allbrennonbrimhall is a name known to allbrennonbrimhall is a name known to allbrennonbrimhall is a name known to allbrennonbrimhall is a name known to allbrennonbrimhall is a name known to all
Re: fast OPR computation with R using sparse matrix technology
Thanks for posting this Ether. Out of curiosity, have you quantified the time savings?
Team 20, 2012-2014: 4 blue banners, 5 medals, and 9 team awards.
Church of Jesus Christ of Latter-day Saints, 2014-2016: Missionary, Colorado Denver South Mission.
Old 01-01-2017, 20:40
Look at the timings in the log file in the ZIP file.
Then compare those to this.
Unread 04-01-2017, 11:56
Any questions?
Unread 05-01-2017, 13:27
Caleb Sykes's Avatar
Caleb Sykes Caleb Sykes is online now
FRC #4536 (MinuteBots)
Any questions?
I don't have any experience with R (on my to do list though). Here is what I think is going on, please correct me if I am wrong.
Stacy Irwin used Rs "solve" method to calculate season OPRs, more info here. She created functions to generate the A and b matrices and used R's "solve" method to get OPRs. I'm having trouble finding good documentation on this method, the best I could get was this. The problem is that this method requires A to be square, which it isn't. This method seems to use LU decomposition. Solving for OPRs after creating the A and b matrices took approximately 3 seconds.
You used the sparseM package to calculate season OPRs. The key difference from Stacy's method was that you converted the A matrix into a sparse matrix and then used the slm method to get OPRs. This method uses Cholesky decomposition. Solving for OPRs after creating the A and b matrices took approximately 0.50 seconds.
These results are roughly in line with the fact that Cholesky decomposition is around twice as fast as LU decomposition.
from Wikipedia
The [Cholesky decomposition] algorithms described below all involve about (n^3)/3 FLOPs, where n is the size of the matrix A. Hence, they are half the cost of the LU decomposition, which uses (2n^3)/3 FLOPs (see Trefethen and Bau 1997).
Unread 05-01-2017, 18:48
Stacy created N = A'A, which is square. See below.
No. I created a sparse matrix representation of the design matrix A directly from the raw qual score data, in one pass through the raw data, with no nested loops, and with no intermediate dense matrix. This is where the bulk of the time savings is. The b and T vectors are created in the same single pass that creates the sparse design matrix. See below.
Let A be the 17842-by-2696 dichotomous (ones and zeros) design matrix of the overdetermined linear system
corresponding to the raw qual match data (alliances & scores) in the file "8col Hill.dat".
Let b be the 17842-by-1 column vector of alliance scores
Let N be the 2696-by-2696 matrix of the coefficients of the normal equations N=A'A
Let d be A'b
Using Stacy's R code as a dense matrix performance baseline, it takes 10 seconds to create the N matrix and d vector, and another 3 seconds to compute the OPR from Nx=d
Using sparse matrix technology, it takes 0.68 seconds to create the b column vector and the sparse matrix A, and 0.27 seconds to compute OPR from Ax=b.
Unread 10-01-2017, 01:43
Reps to the first R guru who will write an R script that reads the file "8col Hill.dat" and creates data frames for Aij, Adim, b, and T in less than half a second. See the file "8col to A b T.AWK" for example code.
