Go to Post Building a 'bot is kinda like washing your hair, but instead of "rinse, lather, repeat"... you should "engineer, test, repeat". - Andy Baker [more]
Unread 05-01-2017, 14:01
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
Re: Mindsenors CAN Splitter
Originally Posted by EricVanWyk View Post
Been a little while... I'm a grad student now. Thesis's rocket pitch is: terminate a high speed digital communication bus with biological goop instead of a resistor to make a cheap bio sensor. Time Domain Reflectometry that uses improved math to get away with worse (but cheaper!!) hardware.
Or put another way, I'm using the stuff that make e.g CAN busses fail for good instead of evil.
Does that have anything to do with the chip inside my head that tells me to do things? It is getting really hard to sort out the voices.
