Go to Post Sure, it's just a robotics competition, but some of us actually care about the robots... - Karthik [more]
Unread 05-01-2017, 19:43
Hess1113's Avatar
Hess1113 Hess1113 is offline
AKA: Christopher Hess
FRC #0291 (CIA)
Rookie Year: 2017
Hess1113 is an unknown quantity at this point
Question Help with CAN Talon SRX set-up and use.
Hello I am new with CAN for the Talon SRX. We are using the LabView program for programming. I am confused on how to program the CAN for the talon motors. I have read the reference manuals for the talons. Anything helps. Thanks.
Unread 05-01-2017, 19:52
forbes's Avatar
forbes forbes is offline
Software developer
AKA: Evan Forbes
FRC #3507 (Ubotics), 694 (StuyPulse)
forbes is a splendid one to beholdforbes is a splendid one to beholdforbes is a splendid one to beholdforbes is a splendid one to beholdforbes is a splendid one to beholdforbes is a splendid one to beholdforbes is a splendid one to beholdforbes is a splendid one to behold
Re: Help with CAN Talon SRX set-up and use.
This is the reference manual you are referring to?
In section 3.2.1 it shows the LabVIEW code for setting up a simple CAN Talon and setting the motor value to a joystick value. Do you have any specific questions about that code?
Unread 06-01-2017, 10:58
Hess1113's Avatar
FRC #0291 (CIA)
Rookie Year: 2017
Thumbs up Re: Help with CAN Talon SRX set-up and use.
I had not seen this manual. I believe this will help. Thank you very much.
Unread 06-01-2017, 11:13
There are two other SRX manuals in addition to the one Evan linked for you.
You can find them on the manufacturer's web site.
Unread 07-01-2017, 21:39
Hess1113's Avatar
FRC #0291 (CIA)
Rookie Year: 2017
Thank you for the other two manuals.
