Go to Post RoboRIO brownout (v, n): The GDC's alternative to limiting the number of motors allowed on a robot. - GeeTwo [more]
Unread 06-01-2017, 12:34
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
Re: Locating a Part
Tubing Plug These are from Automation Direct. You have a voucher in the virtual KOP. Available from other places as well.
Unread 06-01-2017, 12:35
crollison crollison is offline
AKA: Chris Rollison
FRC #4809 (Black Knight Robotics)
crollison is an unknown quantity at this point
Re: Locating a Part
That's the animal. Thanks.
Unread 06-01-2017, 12:37
Ari423's Avatar
Ari423 Ari423 is online now
LabVIEW aficionado and robot addict
AKA: The guy with the yellow hat
FRC #5987 (Galaxia)
Ari423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud of
Re: Locating a Part
You can always use a T fitting and connect the two outputs to each other to make a quick plug if you're short on parts or in the rush of competition.
2017-present: Mentor FRC 5987
2017-present: CSA for FIRST in Israel
2012-2016: Member FRC 423
2013: Programmer
2014: Head Programmer, Wiring
2015: Head Programmer, Wiring
2016: Captain, Head Programmer, Wiring, Manipulator, Chassis, CAD, Business, Outreach (basically everything)
Unread 06-01-2017, 21:44
daniellieb01 daniellieb01 is offline
FRC #5190
Team Role: CAD
daniellieb01 is an unknown quantity at this point
Re: Locating a Part
Its not the best but it works and my team used a few on our competition bot last year. You take a piece of hose about 4-5 inches and fold over about 2 inches of it. Zip tie it down with a couple small size zip ties and you have a cap. We usually use these if you are prototyping or need a cap right this second and don't have time to make a hose fitting with a brass cap on it.
Another way that a sophomore on my team came up with is you put a rivet in the end of a hose and it will seal it. Please don't ever put a rivet in a piece of hose and call it a cap because you are just asking to make a bullet by doing so. (on a side note it held up to 150 psi from our shop compressor and we didn't have anything with a higher pressure to test it with)
Unread 11-01-2017, 08:51
Wren Hensgen's Avatar
Wren Hensgen Wren Hensgen is offline
Alum, Mentor, Volunteer
AKA: Wren Hensgen
FTC #10353 (MetalWorks)
Wren Hensgen is a jewel in the roughWren Hensgen is a jewel in the roughWren Hensgen is a jewel in the rough
Re: Locating a Part
Just letting you know that the T or cap methods are the only legal way of doing this. A screw, a rivet, or any of the ziptie approaches would not be considered competition legal.
For your use case, it might be better to simply use a 3/2 valve, if you have one, rather than a 5/2. That would give you just a single output that's either on or off.
