Go to Post So, you're saying there's a correlation between hard work and success? Who woulda thunk it?! - Tom Bottiglieri [more]
Unread 06-01-2017, 12:30
crollison crollison is offline
AKA: Chris Rollison
FRC #4809 (Black Knight Robotics)
crollison is an unknown quantity at this point
Locating a Part
Can anyone point me to where to find plugs to top off pneumatic lines? For example the other side of a pneumatic solenoid that needs blocked off. Had some given to us but can't find any more and don't' want to go back to what we used to do. Thread a screw into the tubing and bend it over and zip tie.
Thanks.
Unread 06-01-2017, 12:34
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
Re: Locating a Part
Tubing Plug These are from Automation Direct. You have a voucher in the virtual KOP. Available from other places as well.
Unread 06-01-2017, 12:35
AKA: Chris Rollison
Re: Locating a Part
That's the animal. Thanks.
Unread 06-01-2017, 12:37
Ari423's Avatar
Ari423 Ari423 is offline
LabVIEW aficionado and robot addict
AKA: The guy with the yellow hat
FRC #5987 (Galaxia)
Ari423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant future
Re: Locating a Part
You can always use a T fitting and connect the two outputs to each other to make a quick plug if you're short on parts or in the rush of competition.
2017-present: Mentor FRC 5987
2017-present: CSA for FIRST in Israel
2012-2016: Member FRC 423
2013: Programmer
2014: Head Programmer, Wiring
2015: Head Programmer, Wiring
2016: Captain, Head Programmer, Wiring, Manipulator, Chassis, CAD, Business, Outreach (basically everything)
Unread 06-01-2017, 21:44
daniellieb01 daniellieb01 is offline
FRC #5190
Team Role: CAD
daniellieb01 is an unknown quantity at this point
Re: Locating a Part
Its not the best but it works and my team used a few on our competition bot last year. You take a piece of hose about 4-5 inches and fold over about 2 inches of it. Zip tie it down with a couple small size zip ties and you have a cap. We usually use these if you are prototyping or need a cap right this second and don't have time to make a hose fitting with a brass cap on it.
Another way that a sophomore on my team came up with is you put a rivet in the end of a hose and it will seal it. Please don't ever put a rivet in a piece of hose and call it a cap because you are just asking to make a bullet by doing so. (on a side note it held up to 150 psi from our shop compressor and we didn't have anything with a higher pressure to test it with)
Unread 11-01-2017, 08:51
Wren Hensgen's Avatar
Wren Hensgen Wren Hensgen is offline
Alum, Mentor, Volunteer
AKA: Wren Hensgen
FTC #10353 (MetalWorks)
Wren Hensgen is a jewel in the roughWren Hensgen is a jewel in the roughWren Hensgen is a jewel in the rough
Re: Locating a Part
Just letting you know that the T or cap methods are the only legal way of doing this. A screw, a rivet, or any of the ziptie approaches would not be considered competition legal.
For your use case, it might be better to simply use a 3/2 valve, if you have one, rather than a 5/2. That would give you just a single output that's either on or off.
