Go to Post If your robot doesn't work, it doesn't matter, because the robot is really meaningless, in the long run. What is the important thing, the reason we're all in FIRST then? To better our understanding of Science and Technology, and hopefully make the world a better place. - Ian W. [more]
Unread 06-01-2017, 08:52
AustinShalit's Avatar
AustinShalit AustinShalit is offline
AKA: אוסטין
no team (WPILib Suite Developer)
AustinShalit is a glorious beacon of lightAustinShalit is a glorious beacon of lightAustinShalit is a glorious beacon of lightAustinShalit is a glorious beacon of lightAustinShalit is a glorious beacon of lightAustinShalit is a glorious beacon of light
WPILib Suite 2017
WPILib Suite 2017 has been released! There have been a number of significant changes to WPILib for the 2017 FRC season. Take a look at what is new this year: https://wpilib.screenstepslive.com/s...8-new-for-2017
Teams can get started by downloading the 2017 release through Eclipse by following these instructions: https://wpilib.screenstepslive.com/s...eclipse-c-java
You will not be able to deploy to your roboRIO until you image it with image version 2017v8 which is included with the FRC Update Suite.
We have been working hard updating the ScreenSteps documentation. If you notice anything out of place, please submit a report by completing the form at the bottom of page with the issue.
Unread 06-01-2017, 09:14
Bryan Herbst's Avatar
Bryan Herbst Bryan Herbst is offline
AKA: Bryan
FRC #2052 (KnightKrawler)
Bryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond repute
Re: WPILib Suite 2017
WPILib for C++ and Java are now Open Source projects collectively called WPILib Suite and have moved to GitHub. You can view, download or clone any of the repositories in the WPILib Suite of repositories.
Woohoo!! This is fantastic news!
Team 2052- KnightKrawler
Mentor and volunteer
Unread 06-01-2017, 11:48
fsilberberg fsilberberg is offline
WPILib Developer
AKA: Fred Silberberg
FRC #0190
fsilberberg has a spectacular aura aboutfsilberberg has a spectacular aura aboutfsilberberg has a spectacular aura about
An important clarification: we have always been open source. You receive a full copy of the sources when you install WPILib. However, we used to be on CollabNet, and we moved to GitHub for easier team access.
Unread 06-01-2017, 12:55
mdballard's Avatar
mdballard mdballard is offline
SW and Control Systems Mentor
AKA: Matthew Ballard
FRC #4329 (Lutheran Roboteers)
mdballard is an unknown quantity at this point
I was wondering when the Linux ToolChains will available on the following site: http://first.wpi.edu/FRC/roborio/toolchains/
The windows ToolChains appear to already be available.
Also, can someone confirm which versions of Ubuntu have been tested?
Thanks!
Matt Ballard
Mentor Team 4329
Unread 06-01-2017, 13:12
Philip Arola's Avatar
Philip Arola Philip Arola is offline
You can check out any time you like
AKA: KG7VAM
FRC #2898 (The Flying Hedgehogs), FRC #1510 (Wildcats)
Philip Arola is an unknown quantity at this point
We have moved away from the NIVision libraries in favor of OpenCV as a fully integrated solution.
Cunningham's Law: The best way to get the right answer on the Internet is not to ask a question, it's to post the wrong answer.
Unread 06-01-2017, 14:57
AKA: אוסטין
Thanks!
Matt Ballard
Mentor Team 4329
The linux toolchain should be there now. Please check again. In the instructions link it lists the supported versions of Ubuntu.
Unread 06-01-2017, 16:15
Joe Wilson Joe Wilson is online now
Mentor & FRC West Board Member
FRC #4627 (Manning Robotics)
Joe Wilson is an unknown quantity at this point
Awesome, just installed the update.
I tried following the link to the CTRE libraries to get the CAN Talon library, and I get to the HERO CTRE Toolsuite download page, which claims it comes with the libraries for FRC, but I've DLed and installed it and the only thing it gives me is a tool for imaging the CTRE HERO board, and a CAN and Roborio configurator.
Are the CANTalon libraries just not posted yet, or am I missing something?
Unread 06-01-2017, 16:51
Joey1939's Avatar
Joey1939 Joey1939 is offline
AKA: Joey Holliday
FRC #1939 (Kuhnigits)
Joey1939 has a spectacular aura aboutJoey1939 has a spectacular aura aboutJoey1939 has a spectacular aura about
I used the Non-installer version which just has the libraries with instructions on where to place them. I would guess that the installer put the necessary files in your wpilib folder already. Go to C:/Users/you/wpilib/user/language/lib and check for the ctre library.
The updated wpilib is really nice because anything in that lib folder is automatically included in your eclipse robot projects.
Unread 06-01-2017, 17:23
Jacob C. Jacob C. is offline
Engineer at CTR Electronics
FRC #4130 (The Blue Devils)
Jacob C. is a glorious beacon of lightJacob C. is a glorious beacon of lightJacob C. is a glorious beacon of lightJacob C. is a glorious beacon of lightJacob C. is a glorious beacon of light
*snip*
Originally Posted by Joey1939 View Post
*snip*
Joey is correct.
The CAN Talon SRX Libraries are in the Installer - when you get to the component tree page of the installer you should see LabVIEW and C++/Java options. These contain all CTRE Libraries (outside of PCM/PDP).
The libraries are then installed in the background during the installation process - there's nothing else you need to do to have them integrated with Eclipse. Just put the appropriate include or import statement in your code.
Just as a note, there will be a final pre-kickoff installer uploaded later tonight that has several updates. Don't worry if you've already run the current installer - you can just run the new one and it will update everything appropriately.
FiM Volunteer
Since 2015: Controls Mentor for FRC 4130, The Blue Devils (Richmond, MI)
2009-2014: FRC Team 1718, The Fighting Pi
Full Disclosure: I am an Engineer for CTR Electronics
Unread 06-01-2017, 20:40
Painless and easy, nice work folks!
Unread 07-01-2017, 21:05
demosthenes2k8's Avatar
demosthenes2k8 demosthenes2k8 is offline
Graduated but not gone
AKA: Matt Soucy
FRC #0166 (Chop Shop 166)
demosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to behold
Send a message via AIM to demosthenes2k8 Send a message via Yahoo to demosthenes2k8
Are there any plans for setting up a purely-release download that can be used for something like TravisCI? Last year my team relied on manually copy-pasting the Java distribution into a repo that the Travis script would clone. This felt dirty and I always felt guilty about it. Either something like another PPA or similar would be hugely helpful.
GSR Dean's List Finalist 2011
Unread 07-01-2017, 22:15
MrNick's Avatar
MrNick MrNick is offline
FRC #0088 (TJ^2)
MrNick is an unknown quantity at this point
Is there something wrong with the Java plugin? I just tried updating and while it looks like I have the new version (2017.1.1) I don't see any of the new features and none of the jar files have been touched. I tried uninstalling the plugin and deleting the files and then re-installing, but still no luck.
2016 Granite State District Event Winner
Unread 07-01-2017, 22:16
bdaroz's Avatar
bdaroz bdaroz is offline
Programming Mentor
AKA: Brian Rozmierski
FRC #5881 (TVHS Dragons)
Rookie Year: 2016
bdaroz has much to be proud ofbdaroz has much to be proud ofbdaroz has much to be proud ofbdaroz has much to be proud ofbdaroz has much to be proud ofbdaroz has much to be proud ofbdaroz has much to be proud ofbdaroz has much to be proud ofbdaroz has much to be proud of
I was really hoping for a more standardized library installation method (eg maven) this year. With the separating of the libraries this seems to significantly complicate anything but a "standard" installation, which can be difficult on some school locked-down computers.
Unread 07-01-2017, 22:29
WPILib Developer
FRC #0190
We support Maven as an alternative download method, this might be what you're looking for. See the article here: http://wpilib.screenstepslive.com/s/...ource/l/480976.
We do support Maven! I'd suggest checking out GradleRIO, which probably does what you want. Find it here: https://github.com/Open-RIO/GradleRIO. Note, however, that this is just for the standard WPILib libraries. We don't publish artifacts for 3rd party libraries.
As far as we're aware, there are no issues with the plugin like that. What version of Eclipse are you using? If you delete the ~/wpilib folder and restart Eclipse, what happens? It should re-extract the wpilib binaries.
Unread 07-01-2017, 22:44
MrNick's Avatar
FRC #0088 (TJ^2)
Tried that, no luck. Took a look in the plugins folder and found some older version jars. Deleted them and the wpilib folder, restarted and now I'm good. Thanks!
