Go to Post If winning that individual match is more important to you than being there in the first place, then I believe you've got your priorities in the wrong spot. - Tom Bottiglieri [more]
Unread 06-01-2017, 13:08
Chris Hapstack's Avatar
Chris Hapstack Chris Hapstack is offline
Design Mentor
FRC #0342 (Burning Magnetos)
Chris Hapstack is a splendid one to beholdChris Hapstack is a splendid one to beholdChris Hapstack is a splendid one to beholdChris Hapstack is a splendid one to beholdChris Hapstack is a splendid one to beholdChris Hapstack is a splendid one to beholdChris Hapstack is a splendid one to behold
pic: Swerve Module in a Tube
Unread 06-01-2017, 13:10
Design Mentor
Re: pic: Swerve Module in a Tube
CAD can be found here!
This view has the tube transparent.
This shows the pocketing on the bottom of the turning gear which leaves room for the VersaPlanetary's mounting hardware.
2017 -------- Team 342 mentor (Charleston, SC)
2015-2016 - Team 85 mentor (Zeeland, MI)
2007-2010 - Team 281 student (Greenville, SC)
Unread 06-01-2017, 13:34
marshall's Avatar
marshall marshall is offline
FRC #0900 (The Zebracorns)
What's the gear ratio for the VP?
Unread 06-01-2017, 14:01
Design Mentor
I figure if we actually build this I'll go with 90:1. The Robostangs' off-season swerve had the same steering setup but they used 50:1 (which I thought was surprisingly low when compared to something like the AndyMark Swerve & Steer module, but they said it worked well for them). I think you'd need something like 120:1 in order to match the steering RPM of the AndyMark module, but I didn't want a 3rd VersaPlanetary stage because I felt that put the BAG motor too close to the ground.
Unread 06-01-2017, 14:17
Chris is me's Avatar
AKA: Pinecone
Have you considered putting an idler gear on there and doing one reduction in the spur gear stage? Probably a bit more weight and part count but it would give you some flexibility.
Unread 06-01-2017, 14:24
Design Mentor
I was thinking about that, but wondered if it would compromise the steering encoder setup. Currently the steering encoder is a VP integrated encoder after the last stage, and the external gears are 1:1, which means the encoder is 1:1 with the wheel. Does that mean you can use the VP encoder as an absolute encoder? I should probably make a point of knowing more about the encoders needed here... If you had such an external reduction, would you need to mount a separate absolute encoder somewhere else?
Unread 06-01-2017, 14:30
AKA: Pinecone
You don't need a 1:1 reduction for an absolute encoder to work, you just need to be sure you account for reduction in the code (and if your encoder has a deadband or something you need to make sure that isn't a problem). The VP encoder can be used as an absolute encoder. I don't know too much more about the details of electronics, but your mechanical design isn't necessarily constrained by your encoder here.
Unread 06-01-2017, 15:18
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Adding idler gears after your encoder increases the potential for cumulative position error from backlash. Granted, there's already a 1:1 spur gear relationship after the encoder, so that risk exists already. But more gears just compounds that risk further.
