Go to Post I think we sometimes forget that FIRST is not just about building robots. Its purpose is to educate and inspire young people in the field of science and technology. - amanda [more]
Unread 06-01-2017, 16:42
Jordan11v Jordan11v is offline
FRC #0858 (Demons 858)
Rookie Year: 2016
Jordan11v is an unknown quantity at this point
Re: Radio Config Tool errors
Originally Posted by billbo911 View Post
This evening we downloaded the 2017 radio config tool and attempted to configure two of the OM5P-AC radios we had purchased at the end of last year.
Our step was to try to load firmware as it is our understanding that the base firmware on these radios is incorrect for use in FRC.
Upon clicking on the button to load firmware, we got an error message stating the drivers for the NIC could not be found, and to reset the radio and try again.
Now we have seen this error intermittently with last years config tool as well, and with the FRC Kiosk tool also, so I can't say it is just an issue with this year's tool. We saw this error on a couple different laptops as well, so it is not just mine.
So, the question is, who else get's this error and is there a work around?
So we have 2 of these radios at my school and we had just configured them recently. Make sure your radio config program is up to date here https://usfirst.collab.net/sf/frs/do...ation_utilit_1
Choose the bottom one not the IL one or whatever thats for a different country. What we did originally was tried to configure it then it gave us the bridge error so then we loaded firmware and it worked. Then configured it. Make sure your ethernet cable is connected to your pc and make sure its connected on the far right port on the radio not the center one.
Unread 06-01-2017, 16:54
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
All these steps were followed. This software was just released 3 days ago.
BTW, the "IL" version is for Israel.
Unread 06-01-2017, 17:23
I'm in Manchester for Kickoff, so I won't be much help until Sunday or so.
You might possibly try walking through a manual firmware update, but the directions/software I have for that are at home, and I'd want to test them to make sure I get it right.
Unread 08-01-2017, 16:50
malkier22 malkier22 is offline
FRC #3011
malkier22 is an unknown quantity at this point
Had the same problem trying to update the firmware on the new OM5P-AC. Failed to get past errors on the first 2 laptops. Tried the FRC Radio Config tool on a desktop and it worked perfectly! Seems there is a configuration issue with the some NICs and the software provided by WPILib. Try a few different NICs before you give up on the software. It does work!
Good luck programming!
Mr Barnes
Programming Mentor
Team 3011 Wiesbaden Germany
Unread 10-01-2017, 02:53
Peter Johnson Peter Johnson is offline
WPILib Developer
Peter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud of
Version 17.2 has been posted that should fix the NPF error: https://usfirst.collab.net/sf/frs/do...ation_utilit_2
Author of cscore - WPILib CameraServer for 2017+
Author of ntcore - WPILib NetworkTables for 2016+
Creator of RobotPy - Python for FRC
2010 FRC World Champions (294, 67, 177)
2007 FTC World Champions (30, 74, 23)
2001 FRC National Champions (71, 294, 125, 365, 279)
Unread 10-01-2017, 09:23
billbo911's Avatar
Thanks Peter!
This version does indeed appear to have fixed the issue. I will confirm tonight when I get to the shop.
