Go to Post Looks to me like they have a tasty robot. - Andy Baker [more]
Unread 06-01-2017, 17:52
AndromedaOne AndromedaOne is offline
AKA: Bill Walter
FRC #4905 (Andromeda One)
AndromedaOne is an unknown quantity at this point
3D Printed Gearbox for Denso Throttle Motor Available
Team #4905 (Andromeda One) was taking inventory this year and noticed we have a lot of Denso Throttle Motors and thought it would be nice if we could use them somehow. Not finding any readily available gearboxes we decided to try and design one that we could 3D print as an off season activity. What started out mostly as a lark, turned into something that could actually be useful. The printed PLA gears and gearbox seem to be plenty strong for the limited power of the Denso motor.
After discussing this with the team we decided to publish the design and open it up for all teams to use in hopes that some of the Denso motors could be used for more than just paper weights. If you decide to print one please let me know your experience. If other teams find this useful We will endeavor to improve it. The files for 3D printing can be downloaded at:
http://www.thingiverse.com/thing:2016224
Unread 06-01-2017, 18:49
Ari423's Avatar
Ari423 Ari423 is offline
LabVIEW aficionado and robot addict
AKA: The guy with the yellow hat
FRC #5987 (Galaxia)
Ari423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud of
Re: 3D Printed Gearbox for Denso Throttle Motor Available
Good thing you decided to share it, otherwise you wouldn't have been able to use it because it was designed before kickoff.*
I know I've seen a few others of these gearboxes floating around CD but I can't find them right now. They tend to not get a lot of use in this age of infinite motors because you can just use a 775Pro on a VP or a BB775 on a banebots gearbox instead and for a little more weight you get less volume and much more power, but I could see a few instances where this might be a good solution.
If it's not too late, you might consider adding a second throttle motor to add more power and wiring them in parallel. According to 2016 rules*, you can use two throttle motors on one motor controller (2016 R53). If you're already designating a motor controller for this gearbox, you might as well get more power out of it.
*Standard disclaimer that this year's rules may differ
2017-present: Mentor FRC 5987
2017-present: CSA for FIRST in Israel
2012-2016: Member FRC 423
2013: Programmer
2014: Head Programmer, Wiring
2015: Head Programmer, Wiring
2016: Captain, Head Programmer, Wiring, Manipulator, Chassis, CAD, Business, Outreach (basically everything)
Unread 06-01-2017, 18:56
pilleya's Avatar
pilleya pilleya is offline
Elec+Mech
AKA: Alastair Pilley
FRC #4613 (Barker Redbacks)
pilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond repute
Looks like a great looking gearbox, our team developed something similar last year. We manufacture the plates from polycarbonate and the gears from acrylic and have donated them to a lot of teams, especially those outside of North America who have problems getting parts.
http://www.team4613.org/redbox
What reduction is it? We found a single stage 7.5:1 spur reduction to be ideal for running intakes, conveyors and wheels in our testing.
The motors don't have a lot of power but they are extremely reliable and unkillable, coupled with a decent gear reduction, Plenty of different mounting holes and a 1/2" hex output shaft they can be very useful.
We have a 3D printed design and I'll happily share it with you once I get back to my PC after kickoff tomorrow.
Unread 07-01-2017, 15:52
PAR_WIG1350's Avatar
AKA: Alan Wells
FRC #1350 (Rambots)
Based on photographs on Thingiverse, it seems that the motor mount doesn't account for the flanges on the face of the motor. I would suggest using one of the following features to provide a better load path for the compression load resulting from the mounting screws:
  • A boss around each mounting screw hole between the gearbox face and the motor face
  • A boss on the gearbox face that fits between the flanges on the motor face and surrounds the mounting screws
  • Grooves in the gearbox plate for the flanges to sit in. This option could be problematic since it changes the axial placement of the motor.
Unread 07-01-2017, 19:57
AKA: Bill Walter
Ari423 - I like the idea of using adding a second motor, I'll definitely do that.
Pilleya - The gearbox is designed with 10:1 and 18:1 gear ratios and is designed to drive 1/2" Thunderhex shaft. It could easily be modified for 1/2" hex. We use a lot of Thunderhex so I designed the gears to fit that. Total weight is less than one pound. I'll look into adding a lower gear ratio, but that will probably be a new gearbox with a single gear off the main motor. Probably even more useful in this case to add the second motor option.
WIG1350 - The design does include grooves for the gearbox plate, but they are not deep and the motor does ride proud. I agree that bosses would be nice but including them would have required support material for most of the gearbox face. Recessing the motor would make the gearbox thicker by that amount. I do agree with you that the motor mount design is not optimal. What might work is printing a standoff plate that would mount on the engine before mounting to the gearbox. That would actually allow me to thin the whole gearbox down a little.
Thanks for the positive feedback everyone. I'll look into these improvements as time allows.
Unread 15-01-2017, 18:35
blturner blturner is offline
FRC #5013 (Trobots)
blturner is on a distinguished road
I 3D printed a gear for this motor for aerial assist. I was trying to get as compact as possible and could not get enough reduction in the space allowed, so I used a ring gear on a flat plate. Regular ring gears are expensive, seldom available in the size you want and can't be made on a flat plate. The ring gear also makes a slightly stronger contact area.
The gear is sized to mount on a 1/4 inch bolt centered in a 1 inch square tube. I strapped the motor to the tube with a hose clamp and some double faced tape.
It was not strong enough for handling the huge balls in aerial assist but would have no problem with this years small ones.
I would also like to see a gearbox that matched the mount holes of the versa planetary but that might be too compact.
As to the usefulness of this gearbox/motor verses the more powerful ones. Most teams can 3D print this for less than 1/4 the cost of a versaplanetary and you can stall this motor for a lot longer than a 775pro.
Name:	ring gear15hole.png
Unread 15-01-2017, 18:51
Ari423's Avatar
FRC #5987 (Galaxia)
Does anyone have the motor specs for these? I did some searching but all I could find were old posts with now broken links. I would really like to get some data on the motors' power before I use them on a robot.
I don't know the exact motor specs, but I am 100% certain that these motors are nowhere near as powerful as a 775pro. If you don't need a lot of power, that's fine. But I would definitely not call this a better replacement for a 775pro. That being said, I would love to get the STL or STP for that ring gear if you don't mind PMing it to me.
2013: Programmer
Unread 15-01-2017, 19:00
pilleya's Avatar
Elec+Mech
18watt peak power and no load RPM around 5500( very similar to a CIM in terms of rpm)
Unread 15-01-2017, 19:02
Yeah... but not within an order of magnitude of a CIM's power.
Unread 18-01-2017, 22:49
FRC #5013 (Trobots)
Motor specs are here: https://firstfrc.blob.core.windows.n...rManual-V1.pdf
That is linked from this page: http://www.firstinspires.org/resourc...ical-resources
Unread 18-01-2017, 23:41
s_forbes's Avatar
s_forbes s_forbes is online now
anonymous internet person
FRC #0842 (Falcon Robotics)
We are actually going to use this motor this year, I never thought the day would come! We are also 3D printing a gear and gearbox for it, intended to turn a turret or two. Just a single reduction for us though, 80:12. Printed on a Makerbot. The total assembly weighs less than any of the window motors in the KOP, which is nice.
Can send CAD files if anyone is interested, this is the first iteration. The next one should be a little better.
https://www.youtube.com/watch?v=xYpqUxyOp68
Unread 19-01-2017, 08:16
FRC #5013 (Trobots)
Lets see if I can post the stl of my ring gear.... Had to zip it.
The holes are for mounting a vex 2 inch wheel because that was what we had.
I never thought I would use this again so I never bothered posting it.
The actual CAD file was done in the program that came free with the CUBE printers they gave us that year. So I don't think that would be useful.
But let me know.
