Go to Post Oh great, look what you just did. The GDC will probably find ways to use this to torture teams in 2011. I hope you're happy now. - synth3tk [more]
Unread 06-01-2017, 18:02
Drew_trak's Avatar
Drew_trak Drew_trak is offline
AKA: Drew Petrak
FRC #0599 (Robodox)
Drew_trak is an unknown quantity at this point
Team 599 Off Season Chassis Design
https://static1.squarespace.com/stat...G?format=1000w
The CAD model displays a standard WEST COAST DRIVE system.
The gear box used is a Modified SR Slim Gearbox Triple purchased from: http://www.team221.com/viewproduct.php?id=143
You can access our CAD files at http://therobodox.org/cads/
Unread 06-01-2017, 19:01
Ari423's Avatar
Ari423 Ari423 is offline
LabVIEW aficionado and robot addict
AKA: The guy with the yellow hat
FRC #5987 (Galaxia)
Ari423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud of
Re: Team 599 Off Season Chassis Design
I'm assuming one of my assumptions here is wrong, otherwise you're going to run into a problem with this drivetrain.
According to the 221 Systems website, the SR Slim has a maximum reduction of 11:60 (1:5.45). From your render, it looks like you are using that gearbox with 3 CIMs to direct drive a 6" treaded wheel. According to the JVN Calculator*, that should give you a free speed of ~20.7 ft/s at 106A per motor. That is dangerously high, and you are likely to pop breakers just changing directions, let alone in a pushing match.
*using a CoF of 1.1, which is conservative for a treaded wheel, and a weight of 154lbs, the max a robot could weigh in 2016
2017-present: Mentor FRC 5987
2017-present: CSA for FIRST in Israel
2012-2016: Member FRC 423
2013: Programmer
2014: Head Programmer, Wiring
2015: Head Programmer, Wiring
2016: Captain, Head Programmer, Wiring, Manipulator, Chassis, CAD, Business, Outreach (basically everything)
Unread 06-01-2017, 21:07
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Originally Posted by Ari423 View Post
I'm assuming one of my assumptions here is wrong, otherwise...
Nominated for spotlight
