Go to Post "Find a problem? Think of the three I's: Invent and Innovate to Improve!" - yash101 [more]
Unread 06-01-2017, 21:38
Sam Skoglund's Avatar
Sam Skoglund Sam Skoglund is offline
FRC #2232 (Deus Ex Machina)
Sam Skoglund is a jewel in the roughSam Skoglund is a jewel in the roughSam Skoglund is a jewel in the roughSam Skoglund is a jewel in the rough
3D Printable Mag Encoder Mount
There is a lack of easy mounting solutions for mag encoders. Here is a system I designed to make this easier. I have included CAD files and picture. I hope teams will find this useful!
Talon SRX Mag Encoder Mount
Features:
- 2 3D printed parts
- Locks in place on end of .5" hex shaft with perfect alignment
- Total shaft space used = .738"
- Rotational stability via your own personally designed sheet metal mount bolted to housing hole(s)
- Other required parts:
- .5" Hex Bearing
- 2x .5" Hex Collars
- 2x .0625" .5" Hex Spacers
Let me know if you have any comments, questions, or concerns! Thanks!
Unread 06-01-2017, 21:54
marshall's Avatar
marshall marshall is offline
FRC #0900 (The Zebracorns)
Re: 3D Printable Mag Encoder Mount
I have to confess I'm a bit confused by what the two shaft collars and bearing are doing here to add stability. Still need to drill a hole in the shaft to mount the magnet right?
Unread 06-01-2017, 22:01
Yes you still need to drill a hole for the magnet.
The bearing is there to allow the axle to spin independent of the encoder and casing.
The collars are there to keep the entire assembly from simply sliding off the end of the shaft, or sliding too far onto the shaft and rubbing the magnet against the encoder housing.
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #1072 (MVRT)
Possibly to clamp on the magnet? I agree that the shaft collar can be replaced by hole + set screw most likely.
Love the mount. 2-piece construction and looks easy to print.
EDIT: With clever spacing, a single shaft collar will suffice to mount this directly to a shaft.
