Go to Post Don't let Dean's homework assignment enter into the equation; his homework is about spreading his organization and has nothing to do with you doing what you want to do. - jonathan lall [more]
Unread 24-01-2002, 11:45
Tyler Olds Tyler Olds is online now
FUN Show Host
no team (First Updates Now)
Tyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond repute
Problems rendering
Hey its me again a few questions......
When I go to render my rough draft of my animation with out the playing field it runs just fine. But when I import the playing field (roughly 300 polygons) and render it the program stops responding. What strandge is that i have an object that has over 2000 polygons and it works just fine.
If anybody has some advice please help!!!!!!!
Also I just put in a GeforceDDR and it still doesnt render!!!!!!
Thanks
Tyler Olds
Head Animator
Team 93
Unread 24-01-2002, 20:07
Zeinin Zeinin is offline
#0449 (Blair Robot Project)
Zeinin is an unknown quantity at this point
Send a message via AIM to Zeinin Send a message via Yahoo to Zeinin
okay system specs? you running windows ME? if you are go but win2k NOW!
could be your ram, as in not having enough.. but more probably, somthing is wrong with your surfaces on the feild, perhaps
1.4 gzh athlon TBIRD
512mbs ddr
GeForce 3
SBLIVE 5.1
Unread 24-01-2002, 20:37
FUN Show Host
problem
Oh i forgot to mention is that the field and the goal were both made on inventor. When I remove these two It renders just fine. So is anybody else havin problems with inventor to 3ds max conversion? Please let me know how I could help/solve these problems.
Thanks,
Tyler Olds
Head Animator
Team 93
email Tman_86@yahoo.com (there's an _ )
Aim: soccerreffreak
Unread 24-01-2002, 20:42
ouuuuuuuuuuch
are you using that inventor-to-max plugin?
if you are not, use that, that may fix the problem
512mbs ddr
GeForce 3
SBLIVE 5.1
Unread 24-01-2002, 20:47
FUN Show Host
Where do i get that? or what is it? Does it come with the kit of everything?
God I feel dumb lol
Unread 24-01-2002, 20:49
there was a link for it recently on the foruims....
512mbs ddr
GeForce 3
SBLIVE 5.1
FUN Show Host
ok thanks dude ill give it a try,
do you have a IcQ or an AOl sn?
Unread 24-01-2002, 20:50
Zeinin is my AIM name
512mbs ddr
GeForce 3
SBLIVE 5.1
Unread 24-01-2002, 22:34
Daishichimaru Daishichimaru is offline
Daishichimaru is an unknown quantity at this point
Send a message via AIM to Daishichimaru
Assuming you have Inventor 5, open MAX and go to the "configure paths" dialogue from the customize menu, tab to the plugins options, and add a path to your Inventor installiation. There's your import plugin. Beware what file types you try to import from, too, since some of those tend to lock up MAX.
Do you all have problems with.... Munkaboo Website Design/Showcase 19 03-03-2003 19:51
Any problems with PBASIC 2.5 Editor v2.0 Carl Owenby Programming 7 10-02-2003 10:00
Joystick problems archiver 2001 3 24-06-2002 02:40
Radio problems -- not archiver 2000 1 23-06-2002 22:23
Speed Controller/PWM problems.... Clark Gilbert Technical Discussion 8 08-01-2002 00:14
