You make my motors hot!
Unread 07-01-2017, 12:45
Robodawgs2221 Robodawgs2221 is offline
FRC #2221
Robodawgs2221 is an unknown quantity at this point
What objectives are you hoping accomplish in this game??
My team is still in the middle of brainstorming, but does anyone else's team have more solid ideas? What are you guys thinking, gears only, balls only, a little of both? Does anyone have plans to trying climbing the rope?
Unread 07-01-2017, 12:47
wjd13 wjd13 is offline
FRC #4905 (Andromeda One)
Rookie Year: 2015
wjd13 is an unknown quantity at this point
Re: What objectives are you hoping accomplish in this game??
The thing that bothers me about gears is that a: you can only carry 1 at a time (G27). b: the direct path to get gears is very easily blocked/defended and c: you can be bumped as much as anyone wants when you're trying to put the gear on the peg
Unread 07-01-2017, 12:52
FRC #2221
It still seems like the balls just count for too little, so unless a team has a perfected aim and endless balls, gears just seem like the only viable strategy, and it feels like games will be gearbots with the matches being decided by an alliance's ability to climb
Unread 07-01-2017, 12:59
icomella icomella is offline
FRC #0639
icomella is an unknown quantity at this point
A really good point in the manual was that each team can modify and bring their own rope to comps. You can also knot the rope to make it easier for climbing.
DonRotolo's Avatar
OMGweek5whyarentwedoneyet OMGgetgoin
FRC #0832
...until you have placed all the gears, of course.
It seems that gears offer the best scoring opportunity, but that alone won't win, balls up high needs to also be a capability.
I think that perfecting a ball launcher could be worth the effort, while placing gears (ideally using vision) is almost a requirement. Look at the points for placing a single gear (to turn the 'easy' rotor) in auto.
Unread 07-01-2017, 13:06
carpedav000's Avatar
carpedav000 carpedav000 is offline
Studenting is hard, but worth it!
AKA: David Carpenter
no team (Jerry-Rigg school of DuctTapeology)
carpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant future
Placing all the gears is equivalent to 480 high goals. That number just doesnt seem possible in the 2:15 you have. And then you have the 100 point bonus in elims, which would absolutely drown a high goal robot. The only way scoring fuel would even be semi worth it is if both alliances managed to score all gears, making fuel the tiebreaker.
It isn't shiny enough.
Unread 07-01-2017, 13:11
DonRotolo's Avatar
FRC #0832
Originally Posted by carpedav000 View Post
Placing all the gears is equivalent to 480 goals. That number just doesnt seem possible in the 2:15 you have.
An alliance can place up to 13 gears in a match (Page 22). I think 3 teams might do that in 2:15...
Unread 07-01-2017, 13:15
There are 600 balls on the field, with recycling, and with unlimited possession. That's definitely doable with the proper alliance...
Unread 07-01-2017, 13:23
FRC #2221
Just by a rough estimation, based off page 34, 5 balls are processed a second. Going by that, 480 balls would take 96 seconds.(That leaves just under a minute)
So it is doable, but it'd certainly take a lot of coordination between alliance members and skilled drivers on each team. It just doesn't seem feasible to me.
Unread 07-01-2017, 14:04
I wasnt talking about gears.
Unread 07-01-2017, 14:06
toastergod's Avatar
toastergod toastergod is offline
Programming Wizard
AKA: Sam Lehman
FRC #0279 (Tech Fusion)
toastergod is an unknown quantity at this point
Isn't all 4 rotors spinning equivalent to 120 points? With the high goal being 3 fuel per point, how does reaching 120 points take 480 fuel? Wouldn't it be 360? I might have mixed something up, however 480 fuel is equivalent to 160 points, and not 120. Is there an additional bonus I missed? I see the 60 for getting a rotor spinning in autonomous, but that does not add up to 160.
But is it doable with your average alliance?
Unread 07-01-2017, 14:07
40 points per rotor in teleop.
Unread 07-01-2017, 14:13
toastergod's Avatar
Programming Wizard
AKA: Sam Lehman
I'm terribly sorry, I realized my mistake and got mixed up thinking that for some odd reason 4*40 = 120...
Sorry about the mix up, my bad!
Unread 07-01-2017, 14:48
Rookie Year: 2015
I think that towards the start (certainly in qual matches) alliances will focus on getting gears, as they are worth a lot of points and you only need 13 to get a RP.
However, once we hit playoffs and DCMPS, I think the gears will be much more heavily defended, and fuel scoring and climbing will become much more important.
