Go to Post I am sad that the Patriots lost, and I am happy for both teams that won...but I am even more thrilled that for the next two weeks robot building in the midwest comes to a standstill. ;) - Jessica Boucher [more]
Unread 07-01-2017, 11:55
inventor_phild inventor_phild is offline
inventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant future
FRC 2017 Competition Field
Here are the links to the models of this years field.
Autodesk Inventor 2017
https://autodesk.box.com/s/k0cuhqx5d...07dtuu94hhgjxm
Fusion 360
https://autodesk.box.com/s/uka5vn381...pv04r4ga19t645
STEP
https://autodesk.box.com/s/mkoxp5x4i...uboqwhppqck6wk
I will be posting some additional information and a short video to explain the motion I added to the assembly. We get to know how the competition works at the same time as yourself so I added motion where I thought it would be required.
Check later to today for more information.
Phil Dollan
Autodesk Inc.
Autodesk Inventor and Fusion 360
Unread 07-01-2017, 12:57
Re: FRC 2017 Competition Field
Here is a short video overview of the Autodesk Inventor 2017 field model.
https://autodesk.box.com/s/f5as7ooo4...d4ts057dw6d7jc
I didn't have my studio quality audio equipment handy, so I had to settle for a cheapo headset!!
Phil Dollan
Autodesk Inc.
Unread 07-01-2017, 13:32
Tweekme Tweekme is offline
FRC #1261
Tweekme is an unknown quantity at this point
Phil, Is it possible to get the Inventor files ion the 2015 version of Inventor? Our school system is still on Inventor 2015 unfortunately.
Thanks!
Unread 07-01-2017, 13:59
swodaem's Avatar
swodaem swodaem is offline
FRC #2197 (Las Pumas)
Team Role: Photography
swodaem is an unknown quantity at this point
Correct me if I am wrong, but shouldn't the STEP files work for you since they are a universal 3D file format?
Las Pumas 2197
Steps to a Successful Program
1. Load labview software
2. Try to build program
3. Fail to save program on cRIO
4. Look on internet for help
5. Throw chair
6. Drop computer out window
7. Hate life
8. Want to strangle your mentor
-seathroath
Unread 07-01-2017, 14:07
FRC #1261
You can import your part as a step file, but you won't have the same editing capabilities.
Unread 07-01-2017, 14:08
Unfortunately not. If you download the STEP file you can do the following,
1. Select all items in the browser, then ground the parts / subassemblies.
2. Identify the parts you want to move then open the subassembly and start removing any grounding and adding constraints. See my short video on this.
3. Color of the parts is another issue. The only major changes will be the floor markings and the transparent sections that I changed to Polycarbonate (Clear).
I will pass along your comments in regards to creating the model in one or two releases earlier than the current release.
Phil Dollan
Autodesk Inc.
Unread 07-01-2017, 14:16
FRC #1261
Thanks Phil!
Unread 07-01-2017, 18:36
MrRoboSteve MrRoboSteve is offline
AKA: Steve Peterson
FRC #3081 (Kennedy RoboEagles)
MrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond repute
Thanks for posting this. FWIW, we noticed that the four lines defining the retrieval zone and key aren't the correct colors in all cases.
2016-17 events: 10000 Lakes Regional, Northern Lights Regional, FTC Burnsville Qualifying Tournament
2011 - present · FRC 3081 Kennedy RoboEagles mentor
2013 - present · event volunteer at 10000 Lakes Regional, Northern Lights Regional, North Star Regional, Lake Superior Regional, Minnesota State Tournament, PNW District 4 Glacier Peak, MN FTC, CMP
http://twitter.com/MrRoboSteve · www.linkedin.com/in/speterson
Unread 07-01-2017, 18:45
Thanks. As I noted in my video the lines were a concern when I created the Inventor model from the supplied files. Now we have the official competition video etc. I will check them against my file.
Phil Dollan
Autodesk Inc.
Unread 07-01-2017, 19:07
Nbot's Avatar
Nbot Nbot is offline
FRC #4488 (ShockWave)
Team Role: Electrical
Rookie Year: 2015
Nbot is an unknown quantity at this point
First of all, thank you and Autodesk for putting the Field CAD together every year, it's a fantastic resource which I am extremely grateful for. However, while taking some measurements from the alliance wall to the base line I noticed some discrepancies between the CAD and the game manual. The game manual states "BASE LINE: a green line that spans the width of the FIELD and is 9 ft. 4 in. (~284 cm) from the ALLIANCE WALL diamond plate." Measuring that same distance in CAD returns 7.787 feet. Is this just an error in my copy of the CAD or does the official field CAD have this as well?
Unread 07-01-2017, 19:26
Nbot,
Thanks for the comments. I don't have access to the game manual before Kick Off so there may be some discrepancies between the CAD model I was supplied with and the Inventor model I create and posted today.
Easy fix, the green line is grounded in Inventor. Remove the grounding, then apply the necessary constraints to place it 93.3" from the alliance wall.
I also applied a green color to the line.
I have updated my model for official posting on the Autodesk site on Monday.
I am also checking the other lines supplied to me against the Inventor model.
Phil Dollan
Autodesk Inc.
Unread 07-01-2017, 20:38
I am looking over the final drawings provided today on the FRC page and am finding some differences on the locations of the markers based on previous information I received.
They are mostly easy fixes such as modifying constraints I have already placed based on previous information.
I am working my way through all the numbers and will provide a summary tomorrow morning.
Phil Dollan
Autodesk Inc.
Unread 07-01-2017, 21:18
Bpk9p4's Avatar
Bpk9p4 Bpk9p4 is offline
FRC #1756
Bpk9p4 has a brilliant futureBpk9p4 has a brilliant futureBpk9p4 has a brilliant futureBpk9p4 has a brilliant futureBpk9p4 has a brilliant futureBpk9p4 has a brilliant futureBpk9p4 has a brilliant futureBpk9p4 has a brilliant futureBpk9p4 has a brilliant futureBpk9p4 has a brilliant futureBpk9p4 has a brilliant future
Thanks for posting these. These are great
2016 Tesla Division Finalist
2016 Central Illinois Regional Finalist
2015 Newton Division Finalist
2015 Newton Quality Award
Unread 07-01-2017, 21:54
lphung lphung is offline
FRC #5994
lphung is an unknown quantity at this point
Awesome! Thank you for modeling the field
Unread 08-01-2017, 02:12
Dukenator76's Avatar
Dukenator76 Dukenator76 is offline
AKA: Ducati
FRC #1458 (Red Tie Robotics)
Dukenator76 is an unknown quantity at this point
Im new to inventor is there anyway to get a view from the alliance station wall like what I would see if I were driving the robot?
Team 1458 Alumni/Mentor
Team 1458 Student 2 Year Co-President
2014 Calgames Finalist
2013 Engineering Excellence Award -Central Valley Regional
2008 Johnson & Johnson Gracious Professionalism -UC Davis Sacramento Regional
2005 Safety Award -Silicon Valley Regional
