Go to Post I have learned so much from this program and am forever changed by FIRST and its community. You have made me a better person in so many ways. Thank you. - Jessica Boucher [more]
Unread 07-01-2017, 15:00
Bennetster Bennetster is offline
FRC #1730
Bennetster is an unknown quantity at this point
Any idea for how many balls the boilers can hold?
I've have been going through the CAD and I can't seem to find any of the internals of the boilers. Does anyone know roughly how many balls each goal can hold without overflow? Was this discussed at New Hampshire field?
Unread 07-01-2017, 15:02
icomella icomella is offline
FRC #0639
icomella has a little shameless behaviour in the past
Re: Any idea for how many balls the boilers can hold?
Find the dimensions for the bin that holds the balls after they go through the boiler. That should give you a pretty good idea of how many balls you can insert without overflow.
ATannahill ATannahill is offline
AKA: Alex Tannahill
I suggest you check this video.
- Arizona North
Unread 07-01-2017, 15:03
mman1506's Avatar
mman1506 mman1506 is offline
Hater of Tiny Molex Connectors
AKA: Marcus Quintilian
no team (WARP7)
The boiler automatically feeds into loading lanes. The balls are then recycled onto the field
The capacity should be practically infinite.
2016: FRC 865 Mentor
Unread 07-01-2017, 15:08
And FIRST helpfully put the ballcount info into the Manual. 50-60/bin, per 3.11.5.
Unread 07-01-2017, 15:09
Eugene Fang's Avatar
Eugene Fang Eugene Fang is offline
The Blue Alliance
Eugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond repute
What if you score 300 balls in 10 seconds?
Eugene Fang
2010 Silicon Valley Regional Dean's List Finalist
Various FLL Teams - Student (2000-2006), Mentor (2007-2010)
FRC Team 604 - Student (2007-2010), Mentor/Remote Advisor (2011-2015)
FRC Team 1323 - Mentor/Remote Advisor (2011-2014)
The Blue Alliance | TBA GameDay | TBA Android App
Unread 07-01-2017, 15:12
smitikshah's Avatar
smitikshah smitikshah is offline
Drive Coach
AKA: Smiti
FRC #2869 (Regal Eagles)
Rookie Year: 2015
smitikshah has a reputation beyond reputesmitikshah has a reputation beyond reputesmitikshah has a reputation beyond reputesmitikshah has a reputation beyond reputesmitikshah has a reputation beyond reputesmitikshah has a reputation beyond reputesmitikshah has a reputation beyond reputesmitikshah has a reputation beyond reputesmitikshah has a reputation beyond reputesmitikshah has a reputation beyond reputesmitikshah has a reputation beyond repute
https://youtu.be/bJQ4kMwOGtI?t=1m50s
No specifics, but helpful.
Unread 07-01-2017, 15:16
mman1506's Avatar
no team (WARP7)
According to the manual you'd have to wait about 60 seconds for it to count the fuel. The Fuel would still be sent to the return and overflow bins at the same rate.
Unread 07-01-2017, 15:26
Kpchem Kpchem is offline
FTA, CSA, and all things technical
AKA: Kevin Emery
Kpchem is a splendid one to beholdKpchem is a splendid one to beholdKpchem is a splendid one to beholdKpchem is a splendid one to beholdKpchem is a splendid one to beholdKpchem is a splendid one to beholdKpchem is a splendid one to behold
The also talk about the goal overflowing. I am betting that the boiler cannot hold 300 balls, so we need to know how much it can hold so we know to not make our hoppers any larger than that (if the internal capacity is smaller than what we can fit on the robots).
FRC 360: 2008-2011
Full-time Volunteer: 2012 - forever
Unread 07-01-2017, 16:04
mman1506's Avatar
no team (WARP7)
From purely speculation I'd bet that the goal can handle at least one bins worth (~50-60) of balls in each goal at a time which seems like a reasonable maximum amount of balls for one robot to hold. From the video the return mechanism looks like it can run at a rate of about 10 balls per second. Considering that fuel that has not be counted after tele op will not be scored It seems like it would be a somewhat poor idea to put in more than it can count in a 10 second period. I can't find mention of capacity outside the team videos so it's probably a good question for the Q&A.
Unread 07-01-2017, 18:58
Ari423's Avatar
Ari423 Ari423 is offline
LabVIEW aficionado and robot addict
AKA: The guy with the yellow hat
FRC #5987 (Galaxia)
Ari423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud of
The manual disagrees with your estimate from the video.
Originally Posted by 3.11.4 Boiler
A BOILER processes FUEL in to steam at an average rate of five (5) FUEL per second per GOAL, but actual rate is dependent on the amount and packing of FUEL in the GOALS (i.e. the tighter the packing in a GOAL, the faster the FUEL processing rate).
2017-present: Mentor FRC 5987
2017-present: CSA for FIRST in Israel
2012-2016: Member FRC 423
2013: Programmer
2014: Head Programmer, Wiring
2015: Head Programmer, Wiring
2016: Captain, Head Programmer, Wiring, Manipulator, Chassis, CAD, Business, Outreach (basically everything)
Unread 07-01-2017, 19:00
mman1506's Avatar
no team (WARP7)
5*2=10
Unread 07-01-2017, 19:17
Jarren Harkema's Avatar
Jarren Harkema Jarren Harkema is offline
Dancing Drive Coach
FRC #4967 (That ONE Team)
Jarren Harkema is a name known to allJarren Harkema is a name known to allJarren Harkema is a name known to allJarren Harkema is a name known to allJarren Harkema is a name known to allJarren Harkema is a name known to all
We tried to do this and came up with some rough numbers.
The Cylinder itself appears to be ~ 1.78 cubic feet, and the funnel is ~ 1.63. Assuming that the trapezoid below the cylinder is used for processing fuel, thats ~ 3.41 cubic feet total.
The large clear bins used in the videos look like they hold approximately 50 balls, and are 4.24 cubic feet.
Using this, the number of balls that could be held in the boiler stack is approximately 40. If you were shooting at a rate of 6 balls per second non-stop, the boiler stack would fill up in 40 seconds. So you need 240 balls going in non-stop.
Obviously the voids in a rectangular container will be different than the voids in a cylindrical container, but it's close enough for me tonight. There are bigger fish to fry, like figuring out how to flood the boiler in the first place.
Unread 07-01-2017, 19:21
Ari423's Avatar
FRC #5987 (Galaxia)
5*2=10
Sorry I assumed you were only scoring in one goal at a time. Scoring in both goals at the same time would be an interesting thing to think about. Not sure whether the decreased time is worth the decreased points (unless it's right at the end of the match) but to each his own
2013: Programmer
Unread 07-01-2017, 22:25
Here's a photo of the Boiler innards used to index the Fuel and pit the balls out the back.
Back of the boiler photo is in post 23
