Go to Post Calling the refs "zebras" is just fine. Just don't call 'em late for dinner (or visually impaired). - EricH [more]
Unread 07-01-2017, 16:01
dcarr's Avatar
dcarr dcarr is offline
#HoldStrong
AKA: David Carr
FRC #3309 (Friarbots)
dcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond repute
Steamworks Rules Quiz
We put together a quick quiz this morning to spark discussion about rules and scoring. Thought I'd share it here in case it's useful to anyone else. As our understanding of the rules evolves, it may become apparent that there are mistakes on the quiz - if so, please let me know!
https://goo.gl/forms/sFxgJK5uyucrPwJ73
Team 3309
2016 Los Angeles Chairman's Award Winner
2016 Orange County Regional Winner with 3476 & 6220
Team3309.org
Orange County Robotics Alliance
Unread 07-01-2017, 19:37
tpvagnini tpvagnini is offline
FRC #3236 (Tri-Force)
tpvagnini is an unknown quantity at this point
Re: Steamworks Rules Quiz
I like this resource. It goes over most of the important game play and robot rules this year.
A couple of minor errors I found were on the scoring questions.
On question 7: I calculated the answer to be 189 points, 3RP. In auto 39 high goals = 39 points. One rotor = 60 points. 30 fuel in high goal in teleop = 30/3 = 10 points. 4 gears on the lift can only start 2 rotors even with the spare gear so that's another 2*40 points. The rope climb does not award any points due to insufficient time. 39+60+10+80=189.
On quesiton 8: According to 7.3 G13 contact between opposing robots in the retrieval zone is a tech foul which is 25 points according to section 4.4.
So the correct answer should be 128 points and 25 foul points.
I of course may be wrong in my calculations so I would appreciate it if someone would double check my work.
Again, for the most part it was really useful, I'll definitely share it with my team. Thanks for putting this together.
Unread 07-01-2017, 21:06
dcarr's Avatar
#HoldStrong
AKA: David Carr
Thanks for the feedback. Let me share how we arrived at these answers:
For question 7:
Auto: 39 Fuel points, 60 Rotor points, 5 Baseline points. This was mistakenly omitted from the description - it is possible to place gears without crossing the baseline. I've corrected that mistake.
Teleop: 10 fuel points, 40 rotors (rotor two requires 2 gears, rotor three requires another 4 gears, which we don't have).
Total = 39 + 60 + 5 + 10 + 40 = 154.
For question 8:
The 25pt tech foul for contact in the retrieval zone is correct. However, there is also another tech foul at play. The question states that the pilots engage two Rotors during Auto, but only 2 Gears were delivered to the Airship during auto. The reader is left to conclude that the Reserve Gear was used by the pilots in auto, generating another tech foul per A05 for a total of 50 foul points.
Team 3309
Team3309.org
Unread 07-01-2017, 21:20
RNRice2 RNRice2 is offline
All-Around Member
AKA: Ryan Rice
FRC #4514 (Calvert STEAMWorks)
Team Role: Student
RNRice2 is an unknown quantity at this point
For question 7, I think I see a context problem.
During AUTO, a robot can start with up to 10 FUEL. With their being only 3 robots per alliance, their is a maximum of 30 FUEL. It appears that it would be impossible for an alliance to score 39 FUEL during AUTO.
If a team was to somehow score 39 shots, is there another way for the alliance to obtain FUEL during AUTO?
Unread 07-01-2017, 21:24
NShep98's Avatar
NShep98 NShep98 is online now
AKA: Nathan Shepherd
FRC #2079 (4H ALARM Robotics)
Rookie Year: 2015
NShep98 is a glorious beacon of lightNShep98 is a glorious beacon of lightNShep98 is a glorious beacon of lightNShep98 is a glorious beacon of lightNShep98 is a glorious beacon of light
A team could release extra fuel from the hoppers and attempt to score it.
FRC 2079 - 4H ALARM Robotics 2015 - 2017
FLL 2011, 2013
dcarr's Avatar
#HoldStrong
AKA: David Carr
The hoppers
Team 3309
Team3309.org
Unread 07-01-2017, 21:29
All-Around Member
AKA: Ryan Rice
Team Role: Student
That makes sense. Thanks for clarifying that.
Unread 08-01-2017, 03:26
Chak Chak is offline
AKA: Thomas
FRC #4159 (Cardinalbotics)
Team Role: CAD
Chak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant future
Yet, for this question:
Originally Posted by The Quiz
Pilots can use the Reserve Gear to activate a Rotor during auto
The answer key says "no", but on that other question you take into account that the pilot could do it and take the foul; it's just not worth it at all. So why is that ignored in this question?
Also, there's unclear wording in this question:
The Red alliance does the following during Auto: 5 Fuel in the Low Efficiency goal, 2 Gears delivered to the Airship, cross Baseline. The pilots engage two Rotors during Auto. The same robot scores the following in Teleop: 4 Fuel in the High efficiency Goal. It contacts a Blue alliance robot in its retrieval zone. How many points did the Red alliance score, and how many foul points did the Blue alliance get? *
emphasis mine
"It" presumably refers to the red alliance robot. But does "its" refer to the blue alliance robot, or does it refer to the red alliance robot (it/its in the same sentence)? The answer key seems to indicate that "its" referred to the blue alliance robot, but that wasn't clear.
Well, I'm just nitpicking details. This is a great resource! I enjoyed the trick questions.
Unread 08-01-2017, 14:45
Lady-of-Fandoms Lady-of-Fandoms is offline
AKA: Lenna Weiss
FRC #4131 (Iron Patriots)
Team Role: Scout
Rookie Year: 2015
Lady-of-Fandoms is an unknown quantity at this point
Thumbs down Re: Steamworks Rules Quiz
This is a great quiz! My team does a comprehensive rules test at the end of build season, so would you mind if I used some of these?
Unread 08-01-2017, 15:37
dcarr's Avatar
#HoldStrong
AKA: David Carr
Absolutely
Team 3309
Team3309.org
Unread 08-01-2017, 16:16
dcarr's Avatar
#HoldStrong
AKA: David Carr
Good feedback, I clarified the language on those questions
Team 3309
Team3309.org
Unread 20-01-2017, 20:16
RoboRebels5988 RoboRebels5988 is offline
FRC #5988
RoboRebels5988 is an unknown quantity at this point
Thanks for shAring this quiz. We would love to use it for our prep👍🏼😀
Unread 20-01-2017, 23:38
hhoover hhoover is offline
Programming Mentor
FRC #3219 (TREAD)
hhoover is an unknown quantity at this point
I think an update is in order.
"2 Gears delivered to the Airship, cross Baseline. The pilots engage two Rotors during Auto"
Ummm... if only 2 gears get delivered, only ONE rotor can be engaged.
Also, with the baseline moved, I don't think you can deliver a rotor WITHOUT crossing the baseline (as opposed to the original rules).
I think it's appropriate to update the quiz as the rules morph during Q&A and Team Updates.
Thanks for this, though! I do think it's a useful resource!
--Hugh
Unread 20-01-2017, 23:42
--Hugh
Please take into account the Reserve Gear. It's entirely possible to start 2 rotors during Auto.
That being said, your opponents thank you for the 25 points you gave them by taking the Reserve Gear out of its slot.
Unread 21-01-2017, 19:52
Programming Mentor
FRC #3219 (TREAD)
Check rule A05: "PILOTS: don't take the "free" GEAR yet."
