Go to Post This has to be the hardest, most complicated game I've ever seen the GDC develop - that's what makes it so much fun! - SteveGPage [more]
Unread 07-01-2017, 14:12
livia.13's Avatar
livia.13 livia.13 is offline
AKA: Liv
FRC #0716 (WHO'S C-TEKS)
Rookie Year: 2016
livia.13 is an unknown quantity at this point
What's the best rope?
For the 2017 game, if you are going to use your own rope, what is the best kind to use and where would you get it?
Unread 07-01-2017, 14:17
josh milkey josh milkey is offline
FRC #3593
josh milkey is an unknown quantity at this point
Re: What's the best rope?
It depends on your individual robot design, and how you plan to try to climb it.
Unread 07-01-2017, 14:27
icomella icomella is offline
FRC #0639
icomella is an unknown quantity at this point
Keep in mind that whatever rope you use, you can put knots in it to make it easier for your robot to scale.
Unread 07-01-2017, 15:48
MooreteP's Avatar
MooreteP MooreteP is offline
Zen Archer
AKA: Senor Mas
FRC #0571 (Team Paragon)
MooreteP has a reputation beyond reputeMooreteP has a reputation beyond reputeMooreteP has a reputation beyond reputeMooreteP has a reputation beyond reputeMooreteP has a reputation beyond reputeMooreteP has a reputation beyond reputeMooreteP has a reputation beyond reputeMooreteP has a reputation beyond reputeMooreteP has a reputation beyond reputeMooreteP has a reputation beyond reputeMooreteP has a reputation beyond repute
But if you choose a specifically different type of rope, you will be limited to that specific position.
Unread 07-01-2017, 15:52
carpedav000's Avatar
carpedav000 carpedav000 is offline
Studenting is hard, but worth it!
AKA: David Carpenter
no team (Jerry-Rigg school of DuctTapeology)
carpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant future
Unless you're the only climber on the alliance or you cheesecake your partners. Then you could give your alliance partners your rope.
It isn't shiny enough.
Unread 07-01-2017, 15:54
runneals's Avatar
runneals runneals is offline
FTC Mentor - The Robot Corps 7491
FRC #3928 (Team Neutrino)
runneals has a spectacular aura aboutrunneals has a spectacular aura about
You would probably want a static rope. I was also potentially thinking of slackline.
David Runneals
FRC 3928 Team Neutrino 4-H: Mentor (2015 Off-Season - ?)
FTC North Super Regional Championship: Game Announcer (2015)
FTC 7491 The Robot Corps 4-H: Mentor (2013 - ?)
FRC 2167 Mentor (2014)
FRC 3928 Team Neutrino 4-H: Member, Co-Captain, & Media Coordinator (2013)
Unread 07-01-2017, 15:55
Eric Scheuing's Avatar
Eric Scheuing Eric Scheuing is offline
FRC #0999 (MechaRAMS)
Eric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud of
I am going to push to use the default rope. The knots are nice, but if something happens to your own rope(s), you risk losing out on climbing points if you're forced to use the field rope.
2005-2007: Bobcat Robotics 177
2015-20XX: MechaRAMS 999
Unread 07-01-2017, 16:15
Moonsault's Avatar
Moonsault Moonsault is offline
It's only plywood and pool noodles.
AKA: Alex Sharpe
FRC #5484 (Memento Vitam)
Team Role: Human Player
Rookie Year: 2015
Moonsault is an unknown quantity at this point
Does this mean it can be looped also?
Unread 07-01-2017, 16:25
So according to the rules, velcro may be considered a rope as it's flexible and non metallic. Is this correct?
Unread 07-01-2017, 18:27
SpadeSeveren's Avatar
SpadeSeveren SpadeSeveren is offline
AKA: Judah
FRC #1339 (East Angelbotics)
Team Role: Tactician
Rookie Year: 2016
SpadeSeveren will become famous soon enoughSpadeSeveren will become famous soon enough
It seems to my team that you can do any number of things to your rope, so long as it follows the few guidelines. This means you could climb very reliably. I personally think that you should supply your own rope, and have one or two backup ropes, in case one gets damaged. Using the supplied rope creates inconsistency and is overall not reliable, and you can't get the benefits of knots or special material.
My team has strongly considered using a certain climbing rope that has retroreflective fabrics weaved into it, to help with positioning, similar to the one shown here: http://searchgear.com/pmiretroreflectiverope.aspx
However, to answer your question, there is not a definite "best kind" of rope, as it depends on your team.
Unread 07-01-2017, 21:32
engunneer's Avatar
Alumni turned Mentor
AKA: Branden Gunn
FRC #4761
As an inspector, that rope would not pass my inspection and would be brought to the LRI as it contains glass beads (which are not fibers or flexible, per I04).
Unread 07-01-2017, 22:18
Thayer McCollum's Avatar
Thayer McCollum Thayer McCollum is offline
[Insert Name Here]
FRC #0159 (Alpine Robotics)
Rookie Year: 2015
Thayer McCollum will become famous soon enoughThayer McCollum will become famous soon enough
I agree that using a dynamic rope would be a bad idea. But I don't think a slackline would work because I have never seen a slackline that is 1 inch strap, most slacklines I have used are typically 2-3 inches. You could definitely use nylon (or other material) strap, but it probably would not be designed as a slackline.
Unread 07-01-2017, 22:20
Fusion_Clint's Avatar
Fusion_Clint Fusion_Clint is offline
AKA: Clint Brawley
FRC #0364 (Fusion)
Fusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond repute
And you would be wrong. Please read the whole rule. Assuming the linked rope would not extend up more than 12 inches from the point it is held is should be deemed legal. Glass is certainly non-metallic, and "fiber" can really mean anything.
IO4
D. consist entirely of flexible, non-metallic fibers twisted, tied, woven, or braided together except for the last 4 in. (~10 cm) of each end which may be whipped, fused, covered in heat shrink or tape, or dipped in a coating material to prevent fraying.
Blue note "Flexible means that if the ROPE is held at any point, it should not extend more than 12” above the point where it is held. ROPES are meant to be pulled, not pushed."
Clint Brawley
USAF 1992-2013
Fusion 364, 2014 Season to present
Unread 07-01-2017, 23:03
engunneer's Avatar
AKA: Branden Gunn
FRC #4761
you'd be hard pressed to argue that glass beads are "flexible, non-metallic fibers". entirely means entirely. Sure, the linked rope likely meets the definition given for flexible, but the rule describes more properties of the rope than that. It would be legal IMO to have a rope made of glass fibers, as long as it also meets every other rule, such as safety rules.
also, it is never wrong for an inspector to bring a questionable item to the LRI for a ruling.
Lastly, I assure you that i have indeed read the rule multiple times. I have a few years of experience inspecting bots, and over a dozen years reading FRC rulebooks.
Unread 07-01-2017, 23:09
AKA: Clint Brawley
FRC #0364 (Fusion)
The blue note explicitly tells you what flexible means in this context. You can be that guy if you need to be.
Clint Brawley
USAF 1992-2013
