Go to Post If you squeeze cost out hard enough, any component can become a failure point. - EricVanWyk [more]
Unread 07-01-2017, 16:56
Ranger645 Ranger645 is offline
AKA: Gregory Foss
Team Role: Electrical
Ranger645 is an unknown quantity at this point
Gears in the Kit of Parts?
The FRC 2017 kit of parts says that it contains 2 gears. When I first opened it up I thought this was true until I began to watch some of the field explanation videos on youtube. In those it appears that the gear is much thicker than the ones I received and did not have a hollow side like the ones in the kit of parts.
Upon further inspection, I realized the two gears I had fit together back to back to form one gear. Did this happen to anyone else? Is a gear one half and the fact that they fit together is a coincidence? Or is it both halves fitted together?
Unread 07-01-2017, 16:58
ATannahill ATannahill is offline
AKA: Alex Tannahill
Re: Gears in the Kit of Parts?
Based on this page I feel that they are meant to be assembled into one piece.
- Arizona North
Unread 07-01-2017, 17:32
vaxheadroom vaxheadroom is offline
FRC #5492
Rookie Year: 2015
vaxheadroom is an unknown quantity at this point
The two gear halves get assembled into a single gear. There is a small bag in the KOP which contains the screws.
Unread 07-01-2017, 19:02
maxnz's Avatar
maxnz maxnz is offline
AKA: Max Narvaez
FRC #2855 (BEASTBot)
Team Role: Student
Rookie Year: 2016
maxnz is a glorious beacon of lightmaxnz is a glorious beacon of lightmaxnz is a glorious beacon of lightmaxnz is a glorious beacon of lightmaxnz is a glorious beacon of lightmaxnz is a glorious beacon of light
The KOP list states "half" under the gear. So two halves.
As a senior that will be leaving the team, I have to teach others how to:
1. Know the manual extremely well
2. Wire the robot
3. Organize the shop
4. Help people find parts when they need them
5. Find parts to order and give the detailed list to the coach in charge of buying the parts
6. Keep track of team updates, Q & A responses and FIRST blog posts
7. Be active on CD
8. Plan and execute drive team strategy
And more that won't fit on this list...
