Go to Post You don't want down time during build, eh? - dtengineering [more]
Unread 07-01-2017, 15:41
icomella icomella is offline
FRC #0639
icomella has a little shameless behaviour in the past
Knots in the rope?
I've read the manual extensively and can't find anything that says you can or cannot put knots in your rope to assist with climbing. If no one knows, I'll just wait until the Q&A opens in four days.
Unread 07-01-2017, 15:45
SteveGPage's Avatar
SteveGPage SteveGPage is offline
Mentor - Scouting and Strategy
AKA: Steve
FRC #0836 (RoboBees)
SteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond repute
Re: Knots in the rope?
You can. Rule is <I04>
FRC 836, The RoboBees www.robobees.org
growingSTEMS www.growingSTEMS.org
2017: Southwest VA, Northern MD, Chesapeake District Championships, Championships
Unread 07-01-2017, 17:06
amesmich's Avatar
amesmich amesmich is offline
FRC #4638 (Jagbots)
amesmich is an unknown quantity at this point
I didn't see anything about putting a metal ring on the end closest to the floor? Would that be legal? There is not a whole lot about the rope other than diameter and material and length.
Unread 07-01-2017, 17:11
mman1506's Avatar
mman1506 mman1506 is offline
Hater of Tiny Molex Connectors
AKA: Marcus Quintilian
no team (WARP7)
104.D
consist entirely of flexible, non-metallic fibers twisted, tied, woven, or braided together
except for the last 4 in. (~10 cm) of each end which may be whipped, fused, covered
in heat shrink or tape, or dipped in a coating material to prevent fraying.
I would not consider a metal ring to be within those rules. They are very specific about what is allowed.
2016: FRC 865 Mentor
Unread 07-01-2017, 17:23
amesmich's Avatar
FRC #4638 (Jagbots)
Those exact rules seem to give permission to have the last 4 inches as NOT flexible and being a exception to the requirements of the rope itself thus a ring allowed. I guess its a Q&A thing.
Unread 07-01-2017, 17:37
I cannot read the rule that way. The last 4 inches are allowed to have anti-fraying measures added. Having a ring in the last 4 inches would not be an anti-fraying measure.
The way I break it down is:
-entirely of non-metal fibers
-[that are] twisted, tied, woven, or braided together
-except for the last 4 inches of each end, which may be whipped, fused, covered in heat shrink or tape, or dipped in a coating material to prevent fraying.
Basically, you can make a rope out of non-metal fibers, and the whole thing needs to be together using legal methods, but in the last little bit you can add something to keep the whole thing from coming apart.
The real question is, how does a splice count?
Hitchhiker 42's Avatar
Hitchhiker 42 Hitchhiker 42 is offline
Roboter
AKA: Mark Lavrentyev
FRC #4557 (FullMetal Falcons)
Rookie Year: 2015
Hitchhiker 42 has a reputation beyond reputeHitchhiker 42 has a reputation beyond reputeHitchhiker 42 has a reputation beyond reputeHitchhiker 42 has a reputation beyond reputeHitchhiker 42 has a reputation beyond reputeHitchhiker 42 has a reputation beyond reputeHitchhiker 42 has a reputation beyond reputeHitchhiker 42 has a reputation beyond reputeHitchhiker 42 has a reputation beyond reputeHitchhiker 42 has a reputation beyond reputeHitchhiker 42 has a reputation beyond repute
Going off of that, how about a rope loop at the bottom (like a noose)? I'd assume yes, but I wanted to clarify.
2016 - NE District Championship Entrepreneurship Award
2016 - Hartford District Industrial Design Award
2016 - Waterbury District Engineering Inspiration Award
Unread 07-01-2017, 17:38
MrBasse MrBasse is offline
FRC #3572 (Wavelength)
MrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond repute
I think it's a bit of a stretch to classify a metal ring as a coating material though...
Andrew Basse
Coach - FRC Team 3572 - Wavelength
Unread 07-01-2017, 17:58
mman1506's Avatar
no team (WARP7)
The rules do not leave room for a metal ring and specifically defines allowed exceptions (may be whipped, fused, covered
in heat shrink or tape, or dipped in a coating material to prevent fraying.)
A metal ring would no longer meet the listed criteria of being a "rope" and thus cannot be installed on the field. If you tied the end of the rope to a chair would you then be able to bring that chair on on the field? Why is a metal ring any different?
Unread 07-01-2017, 18:04
Jonny_Jee's Avatar
Jonny_Jee Jonny_Jee is offline
FRC #2085 (Robodogs)
Jonny_Jee is a splendid one to beholdJonny_Jee is a splendid one to beholdJonny_Jee is a splendid one to beholdJonny_Jee is a splendid one to beholdJonny_Jee is a splendid one to beholdJonny_Jee is a splendid one to beholdJonny_Jee is a splendid one to behold
Hmmmm so can you tape the bottom of the rope with retroreflective tape?
Keep It Simple Silly!
Unread 07-01-2017, 18:09
markmcgary's Avatar
markmcgary markmcgary is online now
Software Mentor
FRC #4322 (Clockwork Oranges)
markmcgary is just really nicemarkmcgary is just really nicemarkmcgary is just really nicemarkmcgary is just really nicemarkmcgary is just really nice
We've already found a vendor for retroreflective rope.
Unread 07-01-2017, 18:57
amesmich's Avatar
FRC #4638 (Jagbots)
I believe a loop is legal so long as it meet the size constraints. 12" I think off memory. I would not consider tying a ring to it but a loop woven into it. I suppose I could accomplish the same thing by making a loop with the rope and adding a hard "anti fray" polymer coating. Not sure we even want do it but generating ideas. Thanks for your thoughts.
Unread 07-01-2017, 19:00
amesmich's Avatar
FRC #4638 (Jagbots)
Because the chair would violate i04-G
Unread 07-01-2017, 19:01
10", actually, per I04.
I still want to see how the GDC handles splices--I suspect they'd be considered "woven" or "braided", and if they're done right they can be nearly the size of the original rope, or thicker, depending on the type used. But they can be very stiff...
Unread 07-01-2017, 19:25
mman1506's Avatar
no team (WARP7)
1.5
The intent of this manual is that the text means exactly, and only, what it says.
Yes the loop is legal but why does putting the metal ring in the loop make the metal ring legal. When you add tape to the end of the rope it becomes part of the rope as it is still within the criteria of the rope according to the rules. A metal ring does not.
Anyway ask Q&A.
