Go to Post In real life, you paint the number on your OWN forehead. How you dress, how you look, what expression you have on your face, your body language, etc. You may not see the number but it is there. - Joe Johnson [more]
Unread 07-01-2017, 18:24
tgb20 tgb20 is offline
FRC #4097
tgb20 is an unknown quantity at this point
GRIP Deploy Deprecated
This is my first year using GRIP for vision processing and I was going to Deploy it to a raspberry pi. Today when I went to test it I got the message that the deploy is being deprecated. To anyone who knows more about GRIP/Works with GRIP is there any plan to add the network tables support to the python generator? If not what is the best way to send networktables data with python on the pi.
Thanks
Unread 07-01-2017, 21:00
AKA: Brad
#0190 ( Gompei and the Herd)
Re: GRIP Deploy Deprecated
The generated code doesn't explicitly have network tables support built in. It generates a class for your pipeline that has methods where you can retrieve the results. That's documented here: http://wpilib.screenstepslive.com/s/...code-from-grip
with a sample program in Java in the next article after that.
There is also a prebuilt Raspberry PI version of opencv and network tables available. We're planning on putting together a few sample programs that you can use as a starting point for Raspberry PI programs.
Check out this article, and look at ScreenSteps in a few days and we'll have the sample programs and instructions posted.
There is also a pure Python version of network tables developed by the robotpy guys. It's here: https://github.com/robotpy if you have all the other pieces already.
Brad Miller
Robotics Resource Center
