Go to Post Eventually, the "less effective" tweaks will settle to the bottom, and the more effective ones will be assimilated by the group. Then someone will tweak the tweak. That's when the fun begins. - Billfred [more]
Unread 07-01-2017, 19:06
Ichlieberoboter's Avatar
Ichlieberoboter Ichlieberoboter is offline
Awards and Programming
AKA: Maria Valentini
FRC #2499 (Industrial Revolution)
Ichlieberoboter has much to be proud ofIchlieberoboter has much to be proud ofIchlieberoboter has much to be proud ofIchlieberoboter has much to be proud ofIchlieberoboter has much to be proud ofIchlieberoboter has much to be proud ofIchlieberoboter has much to be proud ofIchlieberoboter has much to be proud ofIchlieberoboter has much to be proud ofIchlieberoboter has much to be proud of
Gear hole diameter?
Looking through the manual, we saw the gear dimensions but we couldn't seem to find anything that had the dimensions of the hole in the gear? Obviously the easiest solution would be to just measure it, but our coach has our kop until Monday and we are trying to work on design ideas today! We may have just missed it, sorry if we did, but thank you for any help!
Team 2499-Industrial Revolution
2015 Lake Superior Regional Judges Award
Head Programmer Chairman's Award Presenter Awards Submitter Electrical Team Website Designer Strategy Team
Unread 07-01-2017, 19:16
engunneer's Avatar
Alumni turned Mentor
AKA: Branden Gunn
FRC #4761
Re: Gear hole diameter?
the peg on the airship where the pilot installs the gear has a diameter of 7/8". the gear is a very loose fit, so i would estimate between 15/16" and 1" diameter.
Unread 07-01-2017, 19:18
nickbrickmaster's Avatar
nickbrickmaster nickbrickmaster is offline
Not Allowed Near Power Tools
AKA: Nick Schatz
FRC #3184 (Blaze Robotics)
nickbrickmaster is an unknown quantity at this point
1"
Source: http://files.andymark.com/LayoutPrin...0T+gear+v1.PDF
I have approximate knowledge of many things.
FRC 3184: 2014-, FTC 10648: 2015-
Unread 07-01-2017, 20:16
MasterEric's Avatar
MasterEric MasterEric is offline
Bacon. 'nuff said.
AKA: Eric Myllyoja (E2)
FRC #2137 (Oxford Robocats)
MasterEric is an unknown quantity at this point
Keep in mind, the peg is 1-3/8 inches wide. In order to put the gear on the peg you must put it in one of the large side holes between the "spokes".
Unread 07-01-2017, 21:07
engunneer's Avatar
AKA: Branden Gunn
FRC #4761
the peg I meant in this case is on the railing as part of a GEAR TRAIN. The LIFT also has a peg, which is as you described.
