Go to Post Give yourself the best chance to win at the event you're at by picking the best possible alliance partners available - always. - Rich Kressly [more]
Unread 07-01-2017, 20:47
NathanStro's Avatar
NathanStro NathanStro is offline
Webmaster for 5980
AKA: Nathan Strodtbeck
FRC #5980 (East Grand Rapids Robotics)
Team Role: Webmaster
Rookie Year: 2016
NathanStro is an unknown quantity at this point
Ranking Points in Steamworks unclear
On page 14 of the game manual, there are the guidelines for how to earn ranking points.
It states, "Alliances are seeded in the Qualification tournament using ranking points which are awarded based on a combination of their Win-Loss-Tie record (2 points for a win, 1 point for a tie), the number of times they reach a 40 kiloPascal (kPa) pressure threshold (1 point), and the number of times they start all rotors (1 point)."
I am very confused about the points for KiloPsacals. Does this state that every time you get 40 Kilopascals you get a ranking point or do you just get it the first time you get 40?
Thanks for the help in advance and good luck from team 5980!
Its not about the robot
Unread 07-01-2017, 20:51
g_sawchuk's Avatar
g_sawchuk g_sawchuk is offline
Hmm.
AKA: Griffin Sawchuk
FRC #4476
g_sawchuk is just really niceg_sawchuk is just really niceg_sawchuk is just really niceg_sawchuk is just really niceg_sawchuk is just really nice
Re: Ranking Points in Steamworks unclear
It's a threshold, it's a value that you must surpass.
Although the STEAM TANK lights as described in Section 3.6 STEAM TANK have an upper limit to the
amount of Pressure they can display, there is no limit on the Pressure an ALLIANCE can accumulate.
Since there is no reset it seems clear to me that you can only achieve this RP once per match.
tldr; You just get a ranking point the first time you hit 40.
FRC 2013-2015 (K-Botics #2809)
VEX 2015 - 2016 (W.A.F.F.L.E.S. #4476)
FLL 2015 - ??? (MechMasters #16931)
FRC 2016 - ??? (W.A.F.F.L.E.S. #4476)
2016 Dean's List Finalist
My thoughts and ideas do not necessarily reflect those of my team.
Unread 07-01-2017, 20:55
NShep98's Avatar
NShep98 NShep98 is offline
AKA: Nathan Shepherd
FRC #2079 (4H ALARM Robotics)
Rookie Year: 2015
NShep98 has much to be proud ofNShep98 has much to be proud ofNShep98 has much to be proud ofNShep98 has much to be proud ofNShep98 has much to be proud ofNShep98 has much to be proud ofNShep98 has much to be proud ofNShep98 has much to be proud ofNShep98 has much to be proud of
D. Each Team on an ALLIANCE that achieves at least 40 kPa receives one (1) Ranking
Point
This makes it more clear that it is a one RP opportunity. I would be kind of concerned if it were more, because you could essentially ignore a win at that point.
FRC 2079 - 4H ALARM Robotics 2015 - 2017
FLL 2011, 2013
Unread 07-01-2017, 21:06
Cal578 Cal578 is offline
Passionate FIRST-er, CD donor
AKA: Gerry
FRC #0578 (Red Raider Robotics)
Cal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant future
Table 4-1 says a team can only get one ranking point per match for pressure accumulation.
The only thing I'm not clear on (and this is only a corner case):
Table 4-1 says "If ALLIANCE exceeds a threshold pressure of 40 kPa".
Section 10.4.3-D says "Each Team on an ALLIANCE that achieves at least 40 kPa receives one (1) Ranking Point."
(bolding is my emphasis)
So, if the alliance gets exactly 40 kPa, do they get ranking points or not?
Cal
R3: Red Raider Robotics (FRC Team 578)
Fairport, NY, USA
www.FairportRobotics.org
2016 Finger Lakes Regional: Semifinalist on Alliance 7 (1128, 2010, 578)
2016 NYC Regional: Finalist on Alliance 3 (3419, 578, 3017), 4th seed team, Team Spirit Award
2015 Finger Lakes Regional: 8-3-0 in qualification, 7th seed, Quarterfinalist
2014 NY Tech Valley Regional: 8-4-0 in qualification, 13th seed, Semifinalist
2013 Finger Lakes Regional: 4-5-0 in qualification, 26th seed, Alliance 6, 1-2 in tournament
2012 Buckeye Regional: Gracious Professionalism Award, 7-3-0, 14th seed
2011 Finger Lakes Regional: Engineering Inspiration Award
Unread 07-01-2017, 21:07
KosmicKhaos's Avatar
KosmicKhaos KosmicKhaos is offline
Calm Cool Collected
AKA: Andrew Thompson
FRC #1126 (SparX)
Rookie Year: 2015
KosmicKhaos has a spectacular aura aboutKosmicKhaos has a spectacular aura about
I too would agree. The game manual seems to contradict it self.
Section three reads as follows
Alliances are seeded in the Qualification tournament using ranking points which are awarded based on a combination of their Win-Loss-Tie record (2 points for a win, 1 point for a tie), the number of times they reach a 40 kilo Pascal (kPa) pressure threshold (1 point), and the number of times they start all rotors (1 point).
correct me if I'm wrong but it would appear that according to this every 40kPa earns a ranking point.
However, Table 4-1 says
If ALLIANCE exceeds a threshold pressure of 40 kPa - 1 RP
This implies that you can only receive 1 RP at most through means of pressure.
2016 Greater Pittsburgh Regional Winner (With 5406 and 1559) | Finger Lakes Regional Semi-finalist
2015 Greater Pittsburgh Regional Quarter-finalist | Finger Lakes Regional Semi-finalist
Unread 07-01-2017, 21:10
Calm Cool Collected
FRC #1126 (SparX)
Rookie Year: 2015
It says exceeds 40 kPa because you will never be able to score exactly 40 kPa. Each high goal scored is .333333 while each low goal scored is .111111
I've been corrected
Unread 07-01-2017, 21:13
engunneer's Avatar
Alumni turned Mentor
AKA: Branden Gunn
FRC #4761
there are may ways to score 40kPa exactly. exactly 120 high goals in teleop is one way.
Unread 07-01-2017, 21:14
Boltman Boltman is offline
FRC #5137 (Iron Kodiaks)
Boltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud of
To make it simple (per match):
A win is 2 RP (same as last year)
A tie 1 RP (same as last year)
40 kPa is 1 RP (similar to a Breach last year)
4 Rotors turning is 1RP (similar to Capture last year)
Iron Kodiaks Team #5137 San Marcos, CA
2016 Semi-Finalist | Central Valley Alliance Captain #2
2016 Semi-Finalist | San Diego 2nd bot alliance #8
2015 Semi-Finalist | Ventura 3rd bot alliance #3
2015 Quarter-Finalist| San Diego 2nd bot alliance #5
2014 Rookie All-Star | #21 San Diego | Galileo Division #91
Unread 07-01-2017, 21:15
engunneer's Avatar
AKA: Branden Gunn
FRC #4761
A clearer way to state this is "the number of matches in which the alliance reached a 40 kiloPascal (kPa) pressure threshold (1 point)"
Unread 07-01-2017, 21:55
EntropicOsprey EntropicOsprey is offline
FRC #4783
EntropicOsprey is an unknown quantity at this point
I would say it is at least 40kPa, based on the fact that the rule states "at least" while a summary table paraphrases and uses another word. I would consider the summary table to be a helpful reference to the rule, with the rule holding the actual authority on the matter.
Unread 08-01-2017, 00:56
BSV BSV is offline
FTC / FRC mentor
AKA: Travis
FRC #2723
BSV has much to be proud ofBSV has much to be proud ofBSV has much to be proud ofBSV has much to be proud ofBSV has much to be proud ofBSV has much to be proud ofBSV has much to be proud ofBSV has much to be proud ofBSV has much to be proud of
We were working on the assumption that the RP's from shooting are technically unlimited as stated on page 14, although they would be limited by the 4 balls/second processing speed of the boiler. Why else would the 40 kPa only be worth 20 points in the playoffs when getting all the rotors turning is worth 100 points in the playoffs? That seems pretty unbalanced unless you get the 20 points for every 40 kPa, in which case it makes perfect sense.
We'll submit a question to the Q&A when it opens, but hopefully FIRST will clarify before then because it's a pretty important strategy decision.
Unread 08-01-2017, 01:08
Cothron Theiss's Avatar
Cothron Theiss Cothron Theiss is offline
Registered Muser
Cothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond repute
What just about everyone in this thread has said so far, what my interpretation of the rules says, and what my inner voice of (rarely) common sense says is that your assumption is incorrect. I think this will either be clarified soon via update or via Q&A, but I highly doubt that you can earn more than one RP from scoring Fuel.
