Go to Post When you boil it down, the name “FIRST-a-holic” represents our passion for changing the world, our energy for difficult challenges, and our bravery in facing unknowns. - Ken Leung [more]
Unread 07-01-2017, 12:46
MikLast's Avatar
MikLast MikLast is offline
CAO/Drive Coach
AKA: Mikal Dieatrick
FRC #4513 (Circuit Breakers)
MikLast has a reputation beyond reputeMikLast has a reputation beyond reputeMikLast has a reputation beyond reputeMikLast has a reputation beyond reputeMikLast has a reputation beyond reputeMikLast has a reputation beyond reputeMikLast has a reputation beyond reputeMikLast has a reputation beyond reputeMikLast has a reputation beyond reputeMikLast has a reputation beyond reputeMikLast has a reputation beyond repute
Moving lift to put gear on peg easier
When the gear is being loaded by the robot on the peg, is the Pilot able to move the Lift up? The idea is to move the lift up a bit to center it where the robot holds the gear to put the gear on the peg easier. From my readings i see nothing explicitly forbidding it, but im still not sure its fully okay. Is there any rules that forbid this?
Check out the FRC Discord!
2014: programmer, scout
2015: programmer, admin, drive team
Innovation in control award, WVHS district event
Innovation in control award, CWU district event
finalist, PNW district championship
2016: CAO, Drive team.
Excellence In Engineering awad, WVHS District event
Unread 07-01-2017, 14:25
6401mark 6401mark is offline
FRC #6401
6401mark is an unknown quantity at this point
Re: Moving lift to put gear on peg easier
In the field videos they made it a huge deal that safety was a priority for human players on the field. I can't imagine they would allow for something like that if the robot and the human are in contact
Unread 07-01-2017, 14:45
RoboChair's Avatar
AKA: Devin Castellucci
You are correct, as written now it is allowable to move the lift while a robot interacts with it.
12 Years and counting! Over a third of my life has been spent with FRC.
Unread 07-01-2017, 16:31
Aidan H.'s Avatar
Aidan H. Aidan H. is offline
Unregistered User
FRC #3260 (SHARP)
Aidan H. will become famous soon enough
I combed the rules, and though it emphasizes safety (and this act seems to not be very safe, strictly speaking) it does not lay out any explicit rules for the robot->lift->pilot exchange of the gear, other than it has to come up through the hole.
But of note, in the field walk-through videos it seems to say that "once the pilot has determined that the robot has safely put the gear on the peg, they can lift it up and away from the robot" (@0:57 here https://youtu.be/ZeOevMTC_rw?t=57s).
What confuses me is that this seems to be a significant hole in the rules, as it's the difference between a mostly passive system and a significantly more complicated active system. Though I would not be surprised if the GDC simply didn't think about it, and adds a rule prohibiting lift movement while a robot is touching the gear on the peg, there is a chance that they intentionally left the rule out to make the gear movement an easier task.
Does anyone else think it will be corrected? If so, doesn't it seems like quite a large rules change? Is there a precedent from previous years for a significant change like this?
2016 - Greater Pittsburgh Regional Engineering Inspiration Award
2014 - Greater Pittsburgh Regional Winner
2013 - Pittsburgh Regional Finalists
2013 - Buckeye Regional Finalists
Unread 07-01-2017, 17:01
MikLast's Avatar
CAO/Drive Coach
That thought also came to us as one of our groups talked about the idea. Personally this may be something that does need to be fixed, this could easily mess up someones robot (or a person if things go really wrong) if the LIFT gets yanked away.
Unread 07-01-2017, 19:47
Cal578 Cal578 is offline
Passionate FIRST-er, CD donor
AKA: Gerry
FRC #0578 (Red Raider Robotics)
Cal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant future
What's unsafe about a pilot moving the string a little while a robot attempts to load a gear? It seems to me that the worst that would happen is that the robot jiggles the spring, which transmits some of the jiggle to the string, so the pilot feels some jiggle and maybe loses grip of the string. That doesn't sound dangerous, so I think it makes sense that there's no rule prohibiting it.
Cal
R3: Red Raider Robotics (FRC Team 578)
Fairport, NY, USA
www.FairportRobotics.org
2016 Finger Lakes Regional: Semifinalist on Alliance 7 (1128, 2010, 578)
2016 NYC Regional: Finalist on Alliance 3 (3419, 578, 3017), 4th seed team, Team Spirit Award
2015 Finger Lakes Regional: 8-3-0 in qualification, 7th seed, Quarterfinalist
2014 NY Tech Valley Regional: 8-4-0 in qualification, 13th seed, Semifinalist
2013 Finger Lakes Regional: 4-5-0 in qualification, 26th seed, Alliance 6, 1-2 in tournament
2012 Buckeye Regional: Gracious Professionalism Award, 7-3-0, 14th seed
2011 Finger Lakes Regional: Engineering Inspiration Award
Unread 07-01-2017, 21:06
Ginger Bread's Avatar
Ginger Bread Ginger Bread is offline
Official Ginger of Team #4941
AKA: Landon J.
FRC #4941 (Team RoboBibb)
Team Role: Human Player
Ginger Bread is an unknown quantity at this point
I was also having this question and am very happy that there's nothing specifically against it
FRC 4941
Unread 07-01-2017, 21:26
engunneer's Avatar
Alumni turned Mentor
AKA: Branden Gunn
FRC #4761
at a minimum, if the driver loses grip on the lift handle, it will probably fall outside the porthole, and it would be illegal and unsafe to try to get it back. pilots must be very careful with handles!
FIRST almost always limits cases such that the robot and the human can't be touching game pieces at the same time. since there is a field element in between them, and the pilot is also connected through a flexible element, it may remain as it is currently written. I know it was in our discussion that the pilot would lift the gear out of the robot with the lift, though thinking about it more, that's not a good idea if the pilot is not paying attention.
Unread 07-01-2017, 23:11
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Another thing to note is that the "peg" that the robot must place the gear upon is actually a spring, not a solid item. It can presumably be easily deflected up/down/left/right. 3946 currently intends to exploit this feature in our gear hanger.
Unread 07-01-2017, 23:16
TDav540's Avatar
TDav540 TDav540 is offline
Questionable Decisionmakers
AKA: Trevor Davidson
FRC #1648 (G3 Robotics)
TDav540 has much to be proud ofTDav540 has much to be proud ofTDav540 has much to be proud ofTDav540 has much to be proud ofTDav540 has much to be proud ofTDav540 has much to be proud ofTDav540 has much to be proud ofTDav540 has much to be proud ofTDav540 has much to be proud of
If the pilot isn't paying attention, they shouldn't be the pilot.
2015-??: FRC 1648, G3 Robotics
2016 Carver Division, Columbus District Chairman's Award, Albany District Finalists
Georgia Tech, Class of 2019; Emcee, Ref, and 2016 Technology Enrichment Presenter
2011-15: FRC 540, TALON 540 Godwin Robotics
Proud Alumnus and Supporter
2015 Newton Division, Virginia Regional Finalist Alliance Captain
2014 Curie Division, Virginia Regional Engineering Inspiration
2013 Curie Division, Virginia Regional Engineering Inspiration
Unread 08-01-2017, 00:42
Aur0r4's Avatar
Aur0r4 Aur0r4 is offline
Engineering Mentor
AKA: Jim Browne
None #1058 (PVC Pirates)
Aur0r4 has a brilliant futureAur0r4 has a brilliant futureAur0r4 has a brilliant futureAur0r4 has a brilliant futureAur0r4 has a brilliant futureAur0r4 has a brilliant futureAur0r4 has a brilliant futureAur0r4 has a brilliant futureAur0r4 has a brilliant futureAur0r4 has a brilliant futureAur0r4 has a brilliant future
Send a message via AIM to Aur0r4
I agree, while FIRST may (and will likely) issue some kind of overly conservative clarification on this issue (and it is a very good question), they idea that this is somehow dangerous is a massive stretch.
I'm a huge proponent of industrial safety and appreciate FIRST having to blend in real world industrial safety standards due to the fact that we are dealing with machines.....they aren't remote controlled bulldozers or mining equipment.
Much of what we must abide by likely originates from insurance requirements, not any eminent source of harm.
Jim Browne, EIT
Team 1058 - PVC Pirates
Unread 08-01-2017, 11:50
andrewytiger andrewytiger is offline
FRC #3929
andrewytiger is an unknown quantity at this point
Question about the lift
Is the pilot allowed to raise the lift to a preferred height before the gear is hooked onto the lift? So could we lift the peg to 2ft for example and then hook the gear to it?
Unread 08-01-2017, 11:52
guniv's Avatar
guniv guniv is offline
Communications / Business
AKA: Josh Witt
FRC #3966 (L&N STEMpunks)
guniv has a spectacular aura aboutguniv has a spectacular aura aboutguniv has a spectacular aura about
Re: Question about the lift
Our team is wondering this too. I can't find anything that says a pilot can't operate a lift unless a gear is on it.
2016 | World Championships - Media and Technology Innovation Award
2016 | Rocket City - Entrepreneurship Award | 2nd Place - Microsoft Imagine This
2015 | Smoky Mountains - Imagery Award
2014 | 3rd Place - Safety Animation Award
Unread 08-01-2017, 19:52
nickn_01 nickn_01 is offline
FRC #0179
nickn_01 is an unknown quantity at this point
There is no rule that prohibits the pilot from doing so. Which is something to take advantage of as you can have your gear in a fixed position to simplify the mechanism.
Sent from my iPad using Tapatalk
Unread 08-01-2017, 21:09
nixiebunny nixiebunny is offline
AKA: David Forbes
FRC #4183 (Bit Buckets)
nixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond repute
There are no words that I have seen in the rules, prohibiting pilots from operating the lift at any time. However, designing your robot to require pilot cooperation to dispense a gear will reduce the game playing speed. What if the pilot is doing something else at the time?
--David Forbes
Mentor, Bit Buckets team 4183. Assistant cat herder and dispenser of legendary tales.
Need a Nixie watch? Yes, you do. Ask me.
